[PostGIS] #5919: ST_LineFromEncodedPolyline returns different results on centos8_x86_64 and kylin10_arm64
trac at osgeo.org
Wed May 28 20:35:57 PDT 2025
kylin10_arm64
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Keywords: ST_LineFromEncodedPolyline |
The following SQL returns different results when executed on
`centos8_x86_64` and `kylin10_arm64` platforms:
select ST_ASEWKT(ST_LINEFROMENCODEDPOLYLINE('LINESTRING(0 0,1 1)'));
-- centos8_x86_64
SRID=4326;LINESTRING(0.00005 -0.00007,0.00008 -0.00015,-0.00003
-0.00005,0.00002 -0.00015,0.00006 -0.00023,-0.00003 -0.00028,-0.00012
-0.00029,-0.00003 -0.00026,0.00006 -0.00037,0.00005 -0.00032)
-- kylin10_arm64
-0.00005,0.00002 -0.00015,0.00006 -0.00023,-0.16907 681.67784)
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5919>
