[SCM] PostGIS branch master updated. 3.5.0-350-g1f7efb045
Thu May 29 00:49:00 PDT 2025
the project "PostGIS".
       via  1f7efb045c38896a5d8f0393fa5dee335941f281 (commit)
      from  76caa8d25b18de99c35f8f3ad4dc7561b247f57c (commit)
revisions in full, below.
commit 1f7efb045c38896a5d8f0393fa5dee335941f281
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu May 29 09:39:47 2025 +0200
    Make GetFaceContainingPoint survive to NULL arguments and EMPTY points
    References #5908 in master branch (3.6.0dev)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 6d1f52770..01c8b98a2 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5527,7 +5527,7 @@ Datum GetRingEdges(PG_FUNCTION_ARGS)
   SRF_RETURN_NEXT(funcctx, result);
-/*  GetFaceContainingPoint(atopology, point) */
+/* GetFaceContainingPoint(atopology, point) */
 Datum GetFaceContainingPoint(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(GetFaceContainingPoint);
@@ -5540,6 +5540,12 @@ Datum GetFaceContainingPoint(PG_FUNCTION_ARGS)
   LWPOINT *pt;
   LWT_TOPOLOGY *topo;
+  if ( PG_ARGISNULL(0) || PG_ARGISNULL(1) )
+    /* should only happen when the SQL function is not declared STRICT */
+    PG_RETURN_NULL();
   toponame_text = PG_GETARG_TEXT_P(0);
   toponame = text_to_cstring(toponame_text);
   PG_FREE_IF_COPY(toponame_text, 0);
@@ -5555,6 +5561,14 @@ Datum GetFaceContainingPoint(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
+  if ( lwpoint_is_empty(pt) )
+    lwgeom_free(lwgeom);
+    PG_FREE_IF_COPY(geom, 1);
+    lwpgerror("Second argument needs be a non-empty point");
+    PG_RETURN_NULL();
   if ( SPI_OK_CONNECT != SPI_connect() )
     lwpgerror("Could not connect to SPI");
diff --git a/topology/sql/query/GetFaceContainingPoint.sql.in b/topology/sql/query/GetFaceContainingPoint.sql.in
index bd48bd2c8..9f84c4da5 100644
--- a/topology/sql/query/GetFaceContainingPoint.sql.in
+++ b/topology/sql/query/GetFaceContainingPoint.sql.in
@@ -27,4 +27,4 @@ CREATE OR REPLACE FUNCTION topology.GetFaceContainingPoint(
 RETURNS INT AS
 	'MODULE_PATHNAME', 'GetFaceContainingPoint'
-LANGUAGE 'c' STABLE;
+LANGUAGE 'c' STABLE STRICT;
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index 16e80ad1a..e1a11b90c 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -54,7 +54,11 @@ SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(43.58 8
 SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 8, 44 9)');
 SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 8, 43.58 8.2)');
+-- Corner case calls
+SELECT 'null1' FROM topology.GetFaceContainingPoint(null, 'POINT(0 0)');
+SELECT 'null2' FROM topology.GetFaceContainingPoint('city_data', null);
+SELECT 'null3' FROM topology.GetFaceContainingPoint(null, null);
+SELECT 'empty' FROM topology.GetFaceContainingPoint('city_data', 'POINT EMPTY');
 -- Get face containing the "point on surface" of each face's geometry
diff --git a/topology/test/regress/getfacecontainingpoint_expected b/topology/test/regress/getfacecontainingpoint_expected
index 9df926e16..fe96a3245 100644
--- a/topology/test/regress/getfacecontainingpoint_expected
+++ b/topology/test/regress/getfacecontainingpoint_expected
@@ -1,3 +1,7 @@
+null1
+null2
+null3
+ERROR:  Second argument needs be a non-empty point
 pos|1|1
 pos|2|2
 pos|3|3
Summary of changes:
 topology/postgis_topology.c                           | 16 +++++++++++++++-
 topology/sql/query/GetFaceContainingPoint.sql.in      |  2 +-
 topology/test/regress/getfacecontainingpoint.sql      |  6 +++++-
 topology/test/regress/getfacecontainingpoint_expected |  4 ++++
 4 files changed, 25 insertions(+), 3 deletions(-)
hooks/post-receive
