[PostGIS] #6012: Memory leak in function lwcircstring_from_lwpointarray
trac at osgeo.org
Thu Nov 6 00:57:30 PST 2025
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by mschoema):
I believe the issue is actually in lwcircstring_from_lwpointarray and
comes from how the three functions interact. Essentially,
lwcircstring_from_lwpointarray first allocates memory to write the points
in, then calls ptarray_construct_reference_data, then calls
lwcircstring_construct. But this means that at the end of the function,
the resulting LWCIRCSTRING does not own its own pointarry. This will thus
cause memory leaks when trying to free the circstring, because no-one else
owns this pointarray. I believe lwcircstring_from_lwpointarray should
either call ptarray_construct_copy_data (but that's an unnecessary memory
allocation) or change the readonly flag of its pointarray before
returning.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6012#comment:2>
