[PostGIS] #6015: Server Crash accessing Linestring as MultiLinestring
PostGIS trac at osgeo.org
Wed Nov 12 13:40:02 PST 2025
  Reporter:  fomp     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.6.1
 Component:  postgis  |    Version:  3.6.x
Resolution:           |   Keywords:
Description changed by fomp:
Old description:
> This code produces on a segmentation fault:
> CREATE TABLE geom (geo GEOMETRY(Geometry,31467));
> INSERT INTO geom VALUES ('SRID=31467;LINESTRING(1 1, 2 3, 5 4)');
> SELECT ST_SRID(ST_GeometryN(geo, 1)) FROM geom; -- returns wrong SRID
> SELECT ST_Transform(ST_GeometryN(geo, 1), 4326) FROM geom; -- CRASH!
> The segmentation fault happens only, when the Linestring is stored in a
> table.
> Linux Debian 12.12 on x86_64
> postgresql-16 (16.10-1.pgdg12+1)
> postgresql-16-postgis-3 (3.6.0+dfsg-2.pgdg12+1)
New description:
 table.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6015#comment:1>
