[PostGIS] #5983: Data corruption in topology.topogeometry after upgrade to 3.6.0 (was: Data corruption in topology.topoelement and topology.topogeometry after upgrade to 3.6.0)
PostGIS trac at osgeo.org
Wed Nov 12 18:18:49 PST 2025
  Reporter:  packi     |      Owner:  robe
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 3.6.1
 Component:  topology  |    Version:  3.6.x
Resolution:  fixed     |   Keywords:
Changes (by robe):
 * resolution:   => fixed
 * status:  new => closed
 * summary:
     => Data corruption in topology.topogeometry after upgrade to 3.6.0
Old description:
> Our integration-tests caught an error when upgrading from PostGIS 3.5 to
> 3.6 with a very simple topology.topoelement.
> We're calling `SELECT public.postgis_extensions_upgrade();` like the
> documentation suggests but it ends up either erroring out with:
> `ERROR:  column "t" of table "postgis_test" contains values that violate
> the new constraint` (the offending line is in `postgis_topology--ANY--
> 3.6.0.sql`: `ALTER DOMAIN topology.topoelement ADD CONSTRAINT type_range
> CHECK ( VALUE[2] > 0 );`)
> or, worse, silently "corrupting" the data when accessing single members
> of the `topoelement`. It still returns the right values when accessing
> the whole element.
> The problem seems to be that we alter the type of the domain to be
> bigint[] in the catalog which seems to work fine to access the whole
> element, but access to single members yields it returning a negative
> value which means the check will fail for some values.
> Steps to reproduce:
> 1. Create fresh PG17 instance.
> 2. Execute:
> CREATE EXTENSION postgis VERSION '3.5.0';
> CREATE EXTENSION postgis_topology VERSION '3.5.0';
> SELECT version();
> SELECT postgis_version();
> CREATE TABLE postgis_test (t topology.topoelement);
> INSERT INTO postgis_test VALUES (ARRAY[1,2]);
> SELECT t[1], t[2] FROM postgis_test;
> ALTER EXTENSION postgis UPDATE;
> SELECT postgis_extensions_upgrade();
> SELECT * FROM postgis_test;
> SELECT version();
> Output:
> CREATE EXTENSION
> CREATE EXTENSION
>                                                  version
>  PostgreSQL 17.6 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 14.2.1
> 20240912 (Red Hat 14.2.1-3), 64-bit
> (1 row)
>             postgis_version
>  3.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> (1 row)
> CREATE TABLE
> INSERT 0 1
>  t | t
>  1 | 2
> (1 row)
> ALTER EXTENSION
> NOTICE:  Updating extension postgis 3.6.0
> NOTICE:  Updating extension postgis_topology 3.5.0
> INFO:  Upgraded topoelement from integer[] to bigint[]
> INFO:  Upgraded topoelementarray from integer[][] to bigint[][]
> INFO:  Modified topology added useslargeids(BOOLEAN)
> INFO:  Upgraded topogeometry.id from integer to bigint
> INFO:  Upgraded getfaceedges_returntype.edge from integer to bigint
> INFO:  Upgraded validatetopology_returntype.id1 from integer to bigint
> INFO:  Upgraded validatetopology_returntype.id2 from integer to bigint
>  Upgrade to version 3.6.0 completed, run SELECT postgis_full_version();
> for details
> (1 row)
>      t      | t
>  8589934593 | 0
> (1 row)
>    t
>  {1,2}
> (1 row)
>                                                  version
> (1 row)
>             postgis_version
>  3.6 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> (1 row)
> postgres=#
> Our automated reproduction case where we can reproduce the constraint
> error every time involves upgrading from PG 16 to 17 but this should also
> illustrate the problem.
New description:
 This ticket now just addresses topology.topogeometry though it started as
 issue discussing topoelement corruption which is related.
 topoelement issue is now on #6016
 or, worse, silently "corrupting" the data when accessing single members of
 the `topoelement`. It still returns the right values when accessing the
 whole element.
 element, but access to single members yields it returning a negative value
 Steps to reproduce:
 2. Execute:
 SELECT version();
 SELECT version();
 Output:
 CREATE EXTENSION
 CREATE EXTENSION
                                                  version
 (1 row)
             postgis_version
 (1 row)
 CREATE TABLE
 INSERT 0 1
  t | t
  1 | 2
 (1 row)
 ALTER EXTENSION
 for details
 (1 row)
      t      | t
  8589934593 | 0
 (1 row)
    t
  {1,2}
 (1 row)
                                                  version
 (1 row)
             postgis_version
 (1 row)
 postgres=#
Comment:
 The patch I put in place only addresses the topogeometry corruption and is
 more of a workaround that requires the user to run:
 SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name,
 feature_column)
     FROM topology.layer;
 The topoelement part is continued on #6016 - topology.topoelement.
 I think it's rare that people store topoelements in tables, so less of an
 issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:33>
