[PostGIS] #6017: copytopology creates blank feature_column sometimes
PostGIS trac at osgeo.org
Wed Nov 12 21:42:29 PST 2025
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.5.5
Component:  topology  |    Version:  3.5.x
 Keywords:            |
 While testing the topogeometry corruption and putting in hooks
 before/after.
 I noticed that the copytopology test is failing, but hooks don't tell me
 that.
 Anyway I also confirmed this issue has nothing to do with the support for
 bigint as the same issue exists in 3.5.5dev.  I haven't confirmed older
 versions.
 To replicate run the hook tests we have without upgrading.
 I'll add the test to 3.7 after I've figured out what's up with woodie.
 CREATE EXTENSION postgis VERSION "3.5.5dev";
 CREATE EXTENSION postgis_topology VERSION "3.5.5dev";
 SELECT topology.createTopology('upgrade_test');
 -- Create some TopoGeometry data
 CREATE TABLE upgrade_test.feature(id serial primary key);
 SELECT topology.AddTopoGeometryColumn('upgrade_test', 'upgrade_test',
 'feature', 'tg', 'linear');
 INSERT INTO upgrade_test.feature(tg) SELECT
 topology.toTopoGeom('LINESTRING(0 0, 10 0)', 'upgrade_test', 1);
 CREATE INDEX ON upgrade_test.feature ( id(tg) );
 CREATE TABLE upgrade_test.domain_test(a topology.topoelement, b
 topology.topoelementarray);
 INSERT INTO upgrade_test.domain_test values (
   '{1,2}'::topology.topoelement,
   '{{2,3}}'::topology.topoelementarray
 SELECT * FROM topology.layer;
 SELECT topology.CopyTopology('upgrade_test', 'upgrade_test_copy');
 output is:
 createtopology
               1
 (1 row)
  addtopogeometrycolumn
                      1
 (1 row)
 INSERT 0 1
 CREATE INDEX
  topology_id | layer_id | schema_name  | table_name | feature_column |
 feature_type | level | child_id
            1 |        1 | upgrade_test | feature    | tg             |
 2 |     0 |
 (1 row)
  copytopology
             2
 (1 row)
 |            2 |     0 |
            2 |        1 | upgrade_test_copy | LAYER1     |
 |            2 |     0 |
 (2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6017>
