[PostGIS] #6017: copytopology creates blank feature_column sometimes
PostGIS trac at osgeo.org
Wed Nov 12 21:44:19 PST 2025
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.5.5
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by robe):
 Just a note that I only tested on windows.  With
 PostgreSQL 18.0 on x86_64-windows, compiled by msvc-19.44.35215, 64-bit
 POSTGIS="3.5.5dev 3.5.4-7-g6e6c2eb22" [EXTENSION] PGSQL="180"
 GEOS="3.14.0-CAPI-1.20.4" PROJ="8.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
 DATABASE_PATH=C:\ming64\projects\proj\rel-
 proj-8.2.1w64/share/proj/proj.db" (compiled against PROJ 8.2.1)
 LIBXML="2.12.5" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6017#comment:1>
