[PostGIS] #6017: copytopology creates blank feature_column sometimes
trac at osgeo.org
Wed Nov 12 22:27:17 PST 2025
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.5
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by strk):
That's actually expected, as CopyTopology does NOT copy the layer data, so
what you are left with is so-called "DETACHED" layers, as reported by
TopologySummary:
=# select topologysummary(name) from topology where name =
'upgrade_test_copy';
topologysummary
Topology upgrade_test_copy (id 3, SRID 0, precision 0)+
2 nodes, 1 edges, 0 faces, 1 topogeoms in 1 layers +
Layer 1, type Lineal (2), 1 topogeoms +
Deploy: NONE (detached) +
(1 row)
Since there's no "deploy" target for those layers (that are known to exist
as the relation table data IS copied and refers to them) the code write
arbitrary information in the "schema_name", "table_name" and
"feature_column" of the newly created layer record; and when I implemented
that I evidently went with the topology schema as the detached/phantom
layer's "schema_name", the literal "LAYER#" as the "table_name" and a
plain NULL as the "feature_column". And one of these values (I guess the
NULL) is what TopologySummary recognizes as a signe of a "DETACHED" layer.
I hope this is clear and see #1195 for a past discussion about this
situation and proposals for improving them.
But given the above, this ticket should probably be closed as invalid
(expected). Just make sure it's "always" and not "sometimes' that this
happen, maybe ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6017#comment:2>
