[SCM] PostGIS branch master updated. 3.6.0rc2-201-g567f201c7
git at osgeo.org
git at osgeo.org
Thu Nov 13 08:27:34 PST 2025
the project "PostGIS".
via 567f201c77c22a97ab28530c33de764bdb0bfa43 (commit)
from 6044af623ede9e6ba856793a0b0394842e60e99e (commit)
revisions in full, below.
commit 567f201c77c22a97ab28530c33de764bdb0bfa43
Author: Regina Obe <lr at pcorp.us>
Date: Thu Nov 13 11:27:27 2025 -0500
Update pot template
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index c8d019da2..af249573e 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2025-08-21 03:28+0000\n"
+"POT-Creation-Date: 2025-11-13 16:23+0000\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -39,11 +39,11 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
-"by default. In order to re-enable these, you need to set the following "
-"environment variables <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
+"Out-of-db rasters and all raster drivers are disabled by default. In order "
+"to re-enable these, you need to set the following environment variables "
+"<varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in the server environment. "
-"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
+"You can also use the more cross-platform approach of setting the "
"corresponding <xref linkend=\"PostGIS_GUC\"/>."
msgstr ""
@@ -81,9 +81,9 @@ msgstr ""
msgid ""
"Setting environment variables varies depending on OS. For PostgreSQL "
"installed on Ubuntu or Debian via apt-postgresql, the preferred way is to "
-"edit <filename>/etc/postgresql/<replaceable>10</replaceable>/"
-"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
-"version of PostgreSQL and main refers to the cluster."
+"edit <filename>/etc/postgresql/<replaceable>MAJOR</replaceable>/"
+"<replaceable>CLUSTER</replaceable>/environment</filename> where the "
+"placeholders refer to the PostgreSQL major version and cluster name."
msgstr ""
#. Tag: para
@@ -117,9 +117,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"If you are using PostgreSQL 9.1+ and have compiled and installed the "
-"extensions/postgis modules, you can turn a database into a spatial one using "
-"the EXTENSION mechanism."
+"If you have compiled and installed the extensions/postgis modules, you can "
+"turn a database into a spatial one using the EXTENSION mechanism."
msgstr ""
#. Tag: para
@@ -239,28 +238,32 @@ msgstr ""
#. Tag: title
#, no-c-format
-msgid "Soft Upgrade 9.1+ using extensions"
+msgid "Soft upgrade using extensions"
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"If you originally installed PostGIS with extensions, then you need to "
-"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
+"upgrade using extensions as well. Doing a minor upgrade with extensions is "
"fairly painless."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"If you are running PostGIS 3 or above, then you should use the <xref "
-"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
-"version you have installed."
+"Use the <xref linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade "
+"to the latest version you have installed."
msgstr ""
#. Tag: para
#, no-c-format
-msgid "If you are running PostGIS 2.5 or lower, then do the following:"
+msgid ""
+"If you are upgrading a database that still runs PostGIS 2.5, issue an "
+"<command>ALTER EXTENSION</command> followed by "
+"<function>postgis_extensions_upgrade()</function> to make sure the legacy "
+"<varname>postgis_raster</varname> objects are folded back into the main "
+"extension."
msgstr ""
#. Tag: para
@@ -317,68 +320,16 @@ msgstr ""
#. Tag: title
#, no-c-format
-msgid "Soft Upgrade Pre 9.1+ or without extensions"
+msgid "Soft upgrade without extensions"
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This section applies only to those who installed PostGIS not using "
-"extensions. If you have extensions and try to upgrade with this approach "
-"you'll get messages like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
-"prior to r7409, you cannot use this procedure but would rather need to do a "
-"<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After compiling and installing (make install) you should find a set of "
-"<filename>*_upgrade.sql</filename> files in the installation folders. You "
-"can list them all with:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
-"filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The same procedure applies to raster, topology and sfcgal extensions, with "
-"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
-"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
-"filename> respectively. If you need them:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "You are advised to switch to an extension based install by running"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
-"upgrading your version you are using a version too early for a soft upgrade "
-"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
-"about the need to run this kind of upgrade using a \"procs need upgrade\" "
-"message."
+"Extensions have been the supported installation method for many releases. If "
+"you still rely on an unpackaged installation, perform a <link "
+"linkend=\"hard_upgrade\">HARD UPGRADE</link> into a database created with "
+"extensions and migrate your data there."
msgstr ""
#. Tag: title
@@ -563,9 +514,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"For PostgreSQL 9.4+ configuration can be set at the server level without "
-"touching <code>postgresql.conf</code> or <code>postgresql.auto.conf</code> "
-"by using the <code>ALTER SYSTEM</code> command."
+"PostgreSQL configuration can be set at the server level without touching "
+"<code>postgresql.conf</code> or <code>postgresql.auto.conf</code> by using "
+"the <code>ALTER SYSTEM</code> command."
msgstr ""
#. Tag: para
@@ -598,10 +549,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This is generally used for table partitioning. The default for this is set "
-"to \"partition\" which is ideal for PostgreSQL 8.4 and above since it will "
-"force the planner to only analyze tables for constraint consideration if "
-"they are in an inherited hierarchy and not pay the planner penalty otherwise."
+"This is generally used for table partitioning. The default of \"partition\" "
+"forces the planner to only analyze tables for constraint consideration if "
+"they are in an inherited hierarchy and avoids paying the planner penalty "
+"otherwise."
msgstr ""
#. Tag: link
@@ -611,7 +562,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Default: ~128MB in PostgreSQL 9.6"
+msgid "Default: ~128MB"
msgstr ""
#. Tag: para
@@ -626,9 +577,9 @@ msgstr ""
msgid ""
"<link xlink:href=\"https://www.postgresql.org/docs/current/static/runtime-"
"config-resource.html#GUC-MAX-WORKER-PROCESSES\">max_worker_processes</link> "
-"This setting is only available for PostgreSQL 9.4+. For PostgreSQL 9.6+ this "
-"setting has additional importance in that it controls the max number of "
-"processes you can have for parallel queries."
+"controls the maximum number of background processes available to the server "
+"and therefore also bounds how many workers can participate in parallel "
+"queries."
msgstr ""
#. Tag: para
@@ -709,14 +660,14 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This setting is only available for PostgreSQL 9.6+ and will only affect "
-"PostGIS 2.3+, since only PostGIS 2.3+ supports parallel queries. If set to "
-"higher than 0, then some queries such as those involving relation functions "
-"like <code>ST_Intersects</code> can use multiple processes and can run more "
-"than twice as fast when doing so. If you have a lot of processors to spare, "
-"you should change the value of this to as many processors as you have. Also "
-"make sure to bump up <code>max_worker_processes</code> to at least as high "
-"as this number."
+"Parallel query support in modern PostgreSQL and PostGIS uses this setting to "
+"decide how many workers a plan may request. If set to higher than 0, then "
+"some queries such as those involving relation functions like "
+"<code>ST_Intersects</code> can use multiple processes and can run more than "
+"twice as fast when doing so. If you have a lot of processors to spare, you "
+"should change the value of this to as many processors as you have. Also make "
+"sure to bump up <code>max_worker_processes</code> to at least as high as "
+"this number."
msgstr ""
#. Tag: para
@@ -1228,7 +1179,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "(28). A 5 digit number. Identifies a Zip Code"
+msgid "(28). A 5 digit number. Identifies a ZIP code"
msgstr ""
#. Tag: para
@@ -1334,7 +1285,7 @@ msgstr ""
#, no-c-format
msgid ""
"(token number \"13\"). (SADS elements \"ZIP CODE\" , \"PLUS 4\" ). This "
-"attribute is used for both the US Zip and the Canadian Postal Codes."
+"attribute is used for both the US ZIP and the Canadian postal codes."
msgstr ""
#. Tag: para
@@ -1721,10 +1672,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The <varname>history_table</varname> was also packaged in PostGIS 1.5, but "
-"added to the documentation in PostGIS 2.0. This package is written in "
-"plpgsql and located in the <varname>extras/history_table</varname> of "
-"PostGIS source tar balls and source repository."
+"The <varname>history_table</varname> extension is written in plpgsql and "
+"located in the <varname>extras/history_table</varname> directory of the "
+"PostGIS source tree."
msgstr ""
#. Tag: para
@@ -1849,22 +1799,22 @@ msgstr ""
#, no-c-format
msgid ""
"The script builds a schema called <varname>tiger</varname> to house all the "
-"tiger related functions, reusable lookup data such as road type prefixes, "
+"TIGER-related functions, reusable lookup data such as road type prefixes, "
"suffixes, states, various control tables for managing data load, and "
-"skeleton base tables from which all the tiger loaded tables inherit from."
+"skeleton base tables from which all the TIGER-loaded tables inherit."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Another schema called <varname>tiger_data</varname> is also created which "
-"houses all the census data for each state that the loader downloads from "
+"houses all the census data for each state that the loader downloads from the "
"Census site and loads into the database. In the current model, each set of "
"state tables is prefixed with the state code e.g <varname>ma_addr</varname>, "
"<varname>ma_edges</varname> etc with constraints to enforce only that state "
"data. Each of these tables inherits from the tables <varname>addr</varname>, "
"<varname>faces</varname>, <varname>edges</varname>, etc located in the "
-"<varname>tiger schema</varname>."
+"<varname>tiger</varname> schema."
msgstr ""
#. Tag: para
@@ -1872,9 +1822,9 @@ msgstr ""
msgid ""
"All the geocode functions only reference the base tables, so there is no "
"requirement that the data schema be called <varname>tiger_data</varname> or "
-"that data can't be further partitioned into other schemas -- e.g a different "
-"schema for each state, as long as all the tables inherit from the tables in "
-"the <varname>tiger</varname> schema."
+"that data can't be further partitioned into other schemas -- e.g. a "
+"different schema for each state, as long as all the tables inherit from the "
+"tables in the <varname>tiger</varname> schema."
msgstr ""
#. Tag: para
@@ -1888,9 +1838,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"If you are using tiger geocoder (tiger_2010), you can upgrade the scripts "
-"using the accompanying upgrade_geocoder.bat / .sh scripts in extras/tiger. "
-"One major change between <varname>tiger_2010</varname> and "
+"If you are using the TIGER Geocoder (tiger_2010), you can upgrade the "
+"scripts using the accompanying upgrade_geocoder.bat / .sh scripts in extras/"
+"tiger. One major change between <varname>tiger_2010</varname> and "
"<varname>tiger_2011+</varname> is that the <varname>county</varname> and "
"<varname>state</varname> tables are no longer broken out by state. If you "
"have data from tiger_2010 and want to replace with tiger_2015, refer to "
@@ -1900,16 +1850,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"New in PostGIS 2.2.0 release is support for Tiger 2015 data and inclusion of "
-"Address Standardizer as part of PostGIS."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"New in PostGIS 2.1.0 release is ability to install tiger geocoder with "
-"PostgreSQL extension model if you are running PostgreSQL 9.1+. Refer to "
-"<xref linkend=\"install_tiger_geocoder_extension\"/> for details."
+"You can install the TIGER Geocoder with the PostgreSQL extension model. "
+"Refer to <xref linkend=\"install_tiger_geocoder_extension\"/> for details."
msgstr ""
#. Tag: para
@@ -1939,9 +1881,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The <varname>reverse_geocode</varname> function, introduced in PostGIS 2.0.0 "
-"is useful for deriving the street address and cross streets of a GPS "
-"location."
+"The <varname>reverse_geocode</varname> function is useful for deriving the "
+"street address and cross streets of a GPS location."
msgstr ""
#. Tag: para
@@ -1976,8 +1917,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"There are a couple other open source geocoders for PostGIS, that unlike "
-"tiger geocoder have the advantage of multi-country geocoding support"
+"There are a couple other open source geocoders for PostGIS, that unlike the "
+"TIGER Geocoder have the advantage of multi-country geocoding support"
msgstr ""
#. Tag: para
@@ -1985,12 +1926,12 @@ msgstr ""
msgid ""
"<link xlink:href=\"http://wiki.openstreetmap.org/wiki/Nominatim\">Nominatim</"
"link> uses OpenStreetMap gazeteer formatted data. It requires osm2pgsql for "
-"loading the data, PostgreSQL 8.4+ and PostGIS 1.5+ to function. It is "
-"packaged as a webservice interface and seems designed to be called as a "
-"webservice. Just like the tiger geocoder, it has both a geocoder and a "
-"reverse geocoder component. From the documentation, it is unclear if it has "
-"a pure SQL interface like the tiger geocoder, or if a good deal of the logic "
-"is implemented in the web interface."
+"loading the data together with PostgreSQL and PostGIS. It is packaged as a "
+"webservice interface and seems designed to be called as a webservice. Just "
+"like the TIGER Geocoder, it has both a geocoder and a reverse geocoder "
+"component. From the documentation, it is unclear if it has a pure SQL "
+"interface like the TIGER Geocoder, or if a good deal of the logic is "
+"implemented in the web interface."
msgstr ""
#. Tag: para
@@ -2121,14 +2062,6 @@ msgstr ""
msgid "Examples: Basic"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The below examples timings are on a 3.0 GHZ single processor Windows 7 "
-"machine with 2GB ram running PostgreSQL 9.1rc1/PostGIS 2.0 loaded with all "
-"of MA,MN,CA, RI state Tiger data loaded."
-msgstr ""
#. Tag: para
#, no-c-format
msgid "Exact matches are faster to compute (61ms)"
@@ -2196,21 +2129,6 @@ msgid ""
"PostgreSQL fuzzy string matching (soundex,levenshtein)"
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"machine with 2GB ram running PostgreSQL 9.0/PostGIS 1.5 loaded with all of "
-"MA state Tiger data loaded. Currently a bit slow (3000 ms)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Testing on Windows 2003 64-bit 8GB on PostGIS 2.0 PostgreSQL 64-bit Tiger "
-"2011 data loaded -- (41ms)"
-msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -2376,9 +2294,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"includes this logic, but if you installed tiger geocoder prior to PostGIS "
-"2.0.0 alpha5, you'll need to run this on the states you have already done to "
-"get these additional tables."
+"includes this logic, but if you installed the TIGER Geocoder with older "
+"scripts, rerun it on the states you have already processed to get these "
+"additional tables."
msgstr ""
#. Tag: para
@@ -2502,7 +2420,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Enhanced: 2.4.1 zip code 5 tabulation area (zcta5) load step was fixed and "
+"Enhanced: 2.4.1 ZIP Code 5 tabulation area (zcta5) load step was fixed and "
"when enabled, zcta5 data is loaded as a single table called zcta5_all as "
"part of the nation script load."
msgstr ""
@@ -2510,7 +2428,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"If you want zip code 5 tabulation area (zcta5) to be included in your nation "
+"If you want ZIP Code 5 tabulation area (zcta5) to be included in your nation "
"script load, do the following:"
msgstr ""
@@ -2695,7 +2613,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"<varname>zip4</varname> last 4 digits of a 9 digit zip code. Availability: "
+"<varname>zip4</varname> last 4 digits of a 9 digit ZIP Code. Availability: "
"PostGIS 2.4.0."
msgstr ""
@@ -3112,11 +3030,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The PostGIS topology module has existed in prior versions of PostGIS but was "
-"never part of the Official PostGIS documentation. In PostGIS 2.0.0 major "
-"cleanup is going on to remove use of all deprecated functions in it, fix "
-"known usability issues, better document the features and functions, add new "
-"functions, and enhance to closer conform to SQL-MM standards."
+"The PostGIS topology module has existed for a long time but was not always "
+"part of the official documentation. Extensive cleanup removed deprecated "
+"functions, fixed known usability issues, documented the features and "
+"functions, added new functionality, and improved SQL-MM compliance."
msgstr ""
#. Tag: para
@@ -3143,9 +3060,89 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Topology support is build by default starting with PostGIS 2.0, and can be "
-"disabled specifying --without-topology configure option at build time as "
-"described in <xref linkend=\"postgis_installation\"/>"
+"Topology support is built by default and can be disabled by specifying the --"
+"without-topology configure option at build time as described in <xref "
+"linkend=\"postgis_installation\"/>"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Topology Primitive Tables"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The core primitives of any topology are stored in the <varname>edge_data</"
+"varname>, <varname>node</varname>, and <varname>face</varname> tables that "
+"live in the schema created by <xref linkend=\"CreateTopology\"/>. Each row "
+"of <varname>edge_data</varname> represents an oriented edge: it records a "
+"directed curve from <varname>start_node</varname> to <varname>end_node</"
+"varname> together with the identifier of the face encountered on the left of "
+"that direction (<varname>left_face</varname>) and the face encountered on "
+"the right (<varname>right_face</varname>). The same geometric segment may "
+"therefore appear twice—once for each orientation—when it belongs to two "
+"faces."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>next_left_edge</varname> and <varname>next_right_edge</varname> "
+"columns complete this orientation information by encoding how to keep "
+"walking around a face. They store signed integers whose absolute value is "
+"the identifier of the next oriented edge and whose sign determines whether "
+"the stored orientation has to be followed as-is or reversed when traversing. "
+"Formally, the following rules hold for every edge <varname>e</varname>:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>abs(next_left_edge)</varname> is the identifier of the edge reached "
+"by continuing around the face that lies to the left of <varname>e</varname>. "
+"If the value is positive the walk continues from the end node of <varname>e</"
+"varname> along the stored orientation of the referenced edge; if it is "
+"negative the referenced edge must be followed backwards so that the shared "
+"face remains on the walker’s left."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>abs(next_right_edge)</varname> analogously follows the boundary of "
+"the face located on the right of <varname>e</varname>. A positive value "
+"means that the next edge is taken with its recorded orientation starting "
+"from the end node of <varname>e</varname>, whereas a negative value "
+"instructs to traverse the referenced edge in reverse, starting from its end "
+"node, so that the right-hand face is preserved."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A zero value indicates that the edge is dangling on the corresponding side "
+"(for example an isolated edge whose incident face is the universal face "
+"<varname>0</varname>). The <varname>abs_next_left_edge</varname> and "
+"<varname>abs_next_right_edge</varname> columns exposed by the <varname>edge</"
+"varname> view are convenience projections of these absolute values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This representation is a variant of a doubly connected edge list and is "
+"exploited by many topology routines. Functions such as <xref "
+"linkend=\"GetRingEdges\"/> and <xref linkend=\"ValidateTopology\"/> rely on "
+"it to reconstruct face boundaries and to diagnose inconsistencies—hence the "
+"“invalid next_left_edge” and “invalid next_right_edge” diagnostics reported "
+"during validation. Constructors like <xref linkend=\"AddEdge\"/> initialise "
+"the <varname>next_*</varname> attributes with trivial self references, while "
+"editing routines including <xref linkend=\"ST_AddEdgeModFace\"/> and <xref "
+"linkend=\"ST_RemEdgeModFace\"/> update the links as edges are inserted or "
+"removed. Other bulk operations (for example <xref "
+"linkend=\"TopologyPolygonize\"/>) may intentionally leave the fields unset, "
+"which is why the documentation flags their behaviour explicitly."
msgstr ""
#. Tag: title
@@ -3533,6 +3530,32 @@ msgid ""
"integrity checks."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Fixes topogeometry corruption caused by upgrade to postgis_topology 3.6.0 "
+"and higher"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When upgrading from PostGIS topology <3.6.0 to version >3.6.0+, the "
+"topogeometry column definition was changed. This caused corruption in "
+"topogeometries created before the upgrade. This function fixes this "
+"corruption in affected tables."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.1"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Fix all topology columns"
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
@@ -4191,7 +4214,14 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Enhanced: 2.0 added the signature accepting hasZ"
+msgid "Enhanced: 2.0 added support for <varname>hasZ</varname>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Enhanced: 3.6.0 added <varname>topoid</varname> and <varname>usesLargeIDs</"
+"varname> parameters."
msgstr ""
#. Tag: para
@@ -4337,9 +4367,30 @@ msgstr ""
msgid ""
"Adds a linestring to an existing topology and returns a set of signed edge "
"identifiers forming it up (negative identifies mean the edge goes in the "
-"opposite direction of the input linestring). The given line will snap to "
-"existing nodes or edges within given tolerance. Existing edges and faces may "
-"be split by the line. New nodes and faces may be added."
+"opposite direction of the input linestring)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The given line will snap to existing nodes or edges within given tolerance. "
+"Existing edges and faces may be split by the line. New nodes and faces may "
+"be added, in addition to new edges."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The returned edge identifiers may be either existing edges or newly created "
+"edges as needed to fully represent the input line as closely as possible."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The number of newly created edges (either covering space previously "
+"uncovered or resulting from split of existing edges) may be limited by the "
+"<varname>max_edges</varname> parameter."
msgstr ""
#. Tag: para
@@ -4354,6 +4405,13 @@ msgstr ""
msgid "Enhanced: 3.2.0 added support for returning signed identifier."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Enhanced: 3.7.0 added support for limiting the number of new edges created "
+"in the topology."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -5604,7 +5662,8 @@ msgstr ""
#, no-c-format
msgid ""
"When <varname>tolerance</varname> is given it will be used to snap the input "
-"geometry to existing primitives."
+"geometry to existing primitives. The special value -1 (default) means use "
+"the topology precision as tolerance."
msgstr ""
#. Tag: para
@@ -5629,6 +5688,13 @@ msgstr ""
msgid "Enhanced: 2.1.0 adds the version taking an existing TopoGeometry."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Changed: 3.7.0 changes meaning of tolerance 0 to really mean 0 and -1 (new "
+"default) to request using the topology precision."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "This is a full self-contained workflow"
@@ -6767,22 +6833,22 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"As of PostGIS v1.4.0, all the functions have comments generated from the "
-"documentation. If you wish to install these comments into your spatial "
-"databases later, run the command which requires docbook. The "
-"postgis_comments.sql and other package comments files raster_comments.sql, "
-"topology_comments.sql are also packaged in the tar.gz distribution in the "
-"doc folder so no need to make comments if installing from the tar ball. "
-"Comments are also included as part of the CREATE EXTENSION install."
+"All the functions have comments generated from the documentation. If you "
+"wish to install these comments into your spatial databases later, run the "
+"command which requires docbook. The postgis_comments.sql and other package "
+"comment files are also packaged in the tar.gz distribution in the doc folder "
+"so no need to make comments if installing from the tar ball. Comments are "
+"also included as part of the CREATE EXTENSION install."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Introduced in PostGIS 2.0. This generates html cheat sheets suitable for "
-"quick reference or for student handouts. This requires xsltproc to build and "
-"will generate 4 files in doc folder <filename>topology_cheatsheet.html</"
-"filename>, <filename>tiger_geocoder_cheatsheet.html</filename>, "
+"The <command>make cheatsheets</command> target generates html cheat sheets "
+"suitable for quick reference or for student handouts. This requires xsltproc "
+"to build and will generate 4 files in doc folder "
+"<filename>topology_cheatsheet.html</filename>, "
+"<filename>tiger_geocoder_cheatsheet.html</filename>, "
"<filename>raster_cheatsheet.html</filename>, <filename>postgis_cheatsheet."
"html</filename>"
msgstr ""
@@ -6803,8 +6869,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The PostGIS extensions are built and installed automatically if you are "
-"using PostgreSQL 9.1+."
+"The PostGIS extensions are built and installed automatically when PostgreSQL "
+"extension support is available."
msgstr ""
#. Tag: para
@@ -6923,15 +6989,14 @@ msgid ""
"Extension tables <varname>spatial_ref_sys</varname>, <varname>layer</"
"varname>, <varname>topology</varname> can not be explicitly backed up. They "
"can only be backed up when the respective <varname>postgis</varname> or "
-"<varname>postgis_topology</varname> extension is backed up, which only seems "
-"to happen when you backup the whole database. As of PostGIS 2.0.1, only srid "
-"records not packaged with PostGIS are backed up when the database is backed "
-"up so don't go around changing srids we package and expect your changes to "
-"be there. Put in a ticket if you find an issue. The structures of extension "
-"tables are never backed up since they are created with <code>CREATE "
-"EXTENSION</code> and assumed to be the same for a given version of an "
-"extension. These behaviors are built into the current PostgreSQL extension "
-"model, so nothing we can do about it."
+"<varname>postgis_topology</varname> extension is backed up, which only "
+"happens when you back up the whole database. Only srid records not packaged "
+"with PostGIS are captured in backups, so don't change the entries we ship "
+"and expect the modifications to persist. Put in a ticket if you find an "
+"issue. The structures of extension tables are never backed up since they are "
+"created with <code>CREATE EXTENSION</code> and assumed to be the same for a "
+"given version of an extension. These behaviors are built into the current "
+"PostgreSQL extension model."
msgstr ""
#. Tag: para
@@ -6981,6 +7046,27 @@ msgid ""
"headaches."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Sandboxed build accounts that are not PostgreSQL superusers can delegate "
+"database ownership during the regression cycle by exporting "
+"<varname>POSTGIS_REGRESS_DB_OWNER</varname>. The harness will create the "
+"temporary regression database owned by the nominated role while continuing "
+"to connect using the less privileged account. Combine this with "
+"<varname>POSTGIS_REGRESS_ROLE_EXT_CREATOR</varname> when the extension "
+"creation role must differ from the database owner."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These variables allow automated environments to exercise the full upgrade "
+"and extension install paths without promoting the calling account to "
+"superuser, provided the target PostgreSQL instance permits extension "
+"installation by those delegate roles."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -7085,11 +7171,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The <code>address_standardizer</code> extension used to be a separate "
-"package that required separate download. From PostGIS 2.2 on, it is now "
-"bundled in. For more information about the address_standardize, what it "
-"does, and how to configure it for your needs, refer to <xref "
-"linkend=\"Address_Standardizer\"/>."
+"The <code>address_standardizer</code> extension is bundled with PostGIS. For "
+"more information about the address_standardizer, what it does, and how to "
+"configure it for your needs, refer to <xref linkend=\"Address_Standardizer\"/"
msgstr ""
#. Tag: para
@@ -7119,9 +7204,8 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"For Windows users, the PostGIS 2.1+ bundle is packaged with the "
-"address_standardizer already so no need to compile and can move straight to "
-"<code>CREATE EXTENSION</code> step."
+"Windows installation packages include the address_standardizer so you can "
+"move straight to the <code>CREATE EXTENSION</code> step."
msgstr ""
#. Tag: para
@@ -7238,11 +7322,11 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"As of PostGIS 2.4.1 the Zip code-5 digit tabulation area <varname>zcta5</"
-"varname> load step was revised to load current zcta5 data and is part of the "
-"<xref linkend=\"Loader_Generate_Nation_Script\"/> when enabled. It is turned "
-"off by default because it takes quite a bit of time to load (20 to 60 "
-"minutes), takes up quite a bit of disk space, and is not used that often."
+"The Zip code-5 digit tabulation area <varname>zcta5</varname> load step uses "
+"current ZCTA data and is part of the <xref "
+"linkend=\"Loader_Generate_Nation_Script\"/> when enabled. It is turned off "
+"by default because it takes quite a bit of time to load (20 to 60 minutes), "
+"takes up quite a bit of disk space, and is not used that often."
msgstr ""
#. Tag: para
@@ -7781,6 +7865,16 @@ msgstr ""
msgid "Geometry Processing, PostgreSQL gist, general bug fixing"
msgstr ""
+#. Tag: term
+#, no-c-format
+msgid "<term>Laurențiu Nicola</term>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Bug fixes, maintenance, stability, and performance"
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Core Contributors Past"
@@ -8294,7 +8388,7 @@ msgstr ""
#. Tag: member
#, no-c-format
-msgid "Laurențiu Nicola"
+msgid "<member>Laurențiu Nicola</member>"
msgstr ""
#. Tag: member
@@ -8841,9 +8935,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"PostGIS 2.0.0 was the first release we tried this strategy. We used <link "
-"xlink:href=\"http://www.pledgebank.com\">PledgeBank</link> and we got two "
-"successful campaigns out of it."
+"PostGIS has experimented with community fundraising for features in the "
+"past. We used <link xlink:href=\"http://www.pledgebank.com\">PledgeBank</"
+"link> and we got two successful campaigns out of it."
msgstr ""
#. Tag: para
@@ -8920,13 +9014,13 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Current PostgreSQL versions (including 9.6) suffer from a query optimizer "
-"weakness regarding TOAST tables. TOAST tables are a kind of \"extension "
-"room\" used to store large (in the sense of data size) values that do not "
-"fit into normal data pages (like long texts, images or complex geometries "
-"with lots of vertices), see <link xlink:href=\"http://www.postgresql.org/"
-"docs/current/static/storage-toast.html\">the PostgreSQL Documentation for "
-"TOAST</link> for more information)."
+"Current PostgreSQL versions suffer from a query optimizer weakness regarding "
+"TOAST tables. TOAST tables are a kind of \"extension room\" used to store "
+"large (in the sense of data size) values that do not fit into normal data "
+"pages (like long texts, images or complex geometries with lots of vertices), "
+"see <link xlink:href=\"http://www.postgresql.org/docs/current/static/storage-"
+"toast.html\">the PostgreSQL Documentation for TOAST</link> for more "
+"information)."
msgstr ""
#. Tag: para
@@ -9508,6 +9602,15 @@ msgstr ""
msgid "Geometry Accessors"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These functions expose structural information about an existing geometry "
+"without changing it. They provide access to metadata such as geometry type, "
+"dimensionality, or coordinate components so that spatial expressions can "
+"interrogate complex objects in a controlled way."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Returns the type of a geometry as text."
@@ -9944,7 +10047,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"This only works for POLYGON geometries. It does not work for MULTIPOLYGONS"
+"This only works for POLYGON geometries, not MULTIPOLYGONs. Use <xref "
+"linkend=\"ST_Dump\"/> to extract polygon elements from polygonal geometries: "
+"<code>ST_DumpRings( (ST_Dump(geom)).geom )</code>"
msgstr ""
#. Tag: para
@@ -9954,12 +10059,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "General form of query."
+msgid "Extracting all rings as polygons."
msgstr ""
#. Tag: para
#, no-c-format
-msgid "A polygon with a single hole."
+msgid "Extracting shell and holes from a polygon."
msgstr ""
#. Tag: para
@@ -11455,8 +11560,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-", <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref "
-"linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
+", <xref linkend=\"ST_YMin\"/>, <xref linkend=\"ST_YMax\"/>, <xref "
+"linkend=\"ST_ZMin\"/>, <xref linkend=\"ST_ZMax\"/>, <xref "
+"linkend=\"ST_MMin\"/>, <xref linkend=\"ST_MMax\"/>"
msgstr ""
#. Tag: refpurpose
@@ -11497,7 +11603,8 @@ msgstr ""
#, no-c-format
msgid ""
", <xref linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref "
msgstr ""
#. Tag: refpurpose
@@ -11517,8 +11624,9 @@ msgstr ""
#, no-c-format
msgid ""
", <xref linkend=\"ST_XMin\"/>, <xref linkend=\"ST_XMax\"/>, <xref "
-"linkend=\"ST_YMax\"/>, <xref linkend=\"ST_ZMax\"/>, <xref "
-"linkend=\"ST_ZMin\"/>"
+"linkend=\"ST_YMax\"/>, <xref linkend=\"ST_ZMin\"/>, <xref "
+"linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_MMin\"/>, <xref "
+"linkend=\"ST_MMax\"/>"
msgstr ""
#. Tag: refpurpose
@@ -11538,8 +11646,9 @@ msgstr ""
#, no-c-format
msgid ""
-"linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref "
-"linkend=\"ST_ZMax\"/>"
+"linkend=\"ST_YMin\"/>, <xref linkend=\"ST_YMax\"/>, <xref "
+"linkend=\"ST_ZMin\"/>, <xref linkend=\"ST_MMin\"/>, <xref "
msgstr ""
#. Tag: refpurpose
@@ -11559,8 +11668,36 @@ msgstr ""
#, no-c-format
msgid ""
", <xref linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_XMin\"/>, <xref "
-"linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMax\"/>, <xref "
-"linkend=\"ST_YMin\"/>, <xref linkend=\"ST_ZMax\"/>"
+"linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref "
+"linkend=\"ST_YMax\"/>, <xref linkend=\"ST_ZMax\"/>, <xref "
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Returns the M minima of a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns the M minima of a geometry, or null of the geometry lacks M values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref "
+"linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_MMax\"/>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_MMin\"/>"
msgstr ""
#. Tag: title
@@ -11849,6 +11986,14 @@ msgstr ""
msgid "Geometry Constructors"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These functions instantiate new geometry or geography values. They assemble "
+"primitives, coordinate sequences, or existing geometries into well-formed "
+"spatial objects that can participate in subsequent analysis."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
@@ -12052,8 +12197,16 @@ msgstr ""
msgid ""
"Repeated nodes at the beginning of input LineStrings are collapsed to a "
"single point. Repeated points in Point and MultiPoint inputs are not "
-"collapsed. <xref linkend=\"ST_RemoveRepeatedPoints\"/> can be used to "
-"collapse repeated points from the output LineString."
+"collapsed. Components of MultiLineString are handled in the order they "
+"appear in the collection. <xref linkend=\"ST_RemoveRepeatedPoints\"/> can be "
+"used to collapse repeated points from the output LineString."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Availability: 3.7.0 - Support for MultiLineString input elements was "
+"introduced"
msgstr ""
#. Tag: para
@@ -12133,8 +12286,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Prior to PostgreSQL 9, ordering in a subquery can be used. However, "
-"sometimes the query plan may not respect the order of the subquery."
+"When ordering within the aggregate is not possible, ordering in a subquery "
+"can be used. However, sometimes the query plan may not respect the order of "
+"the subquery."
msgstr ""
#. Tag: para
@@ -12956,6 +13110,132 @@ msgid ""
">, <xref linkend=\"ST_CoverageSimplify\"/>"
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal "
+"coverage, given a non-clean input."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A window function which adjusts the edges of a set of valid polygonal "
+"geometries to produce a clean coverage. Cleaning involves:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"snapping vertices and edges to remove small discrepancies and ensure common "
+"edges are identically noded"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "merging overlaps into a parent polygon"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "merging narrow gaps into adjacent polygons"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<parameter>gapMaximumWidth</parameter> controls which gaps between polygons "
+"are merged. Gaps with width <= this distance are merged into an adjacent "
+"polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<parameter>snappingDistance</parameter> controls snapping of vertices and "
+"edges. The default (-1) automatically determines a snapping distance based "
+"on the input extent. Set to 0.0 to turn off snapping."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<parameter>overlapMergeStrategy</parameter> specifies how overlaps are "
+"merged into a parent polygon:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>MERGE_LONGEST_BORDER</code> - merges into polygon with longest common "
+"border"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<code>MERGE_MAX_AREA</code> - merges into polygon with maximum area"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<code>MERGE_MIN_AREA</code> - merges into polygon with minimum area"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>MERGE_MIN_INDEX</code> - merges into polygon with smallest input index "
+"(defined by order of input polygons)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The result is a clean polygonal coverage that will pass validation by <xref "
+"linkend=\"ST_CoverageInvalidEdges\"/> and can be input to coverage "
+"processing functions."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"To aid in determining a maximum gap width, gaps can be computed by cleaning "
+"with <code>gapMaximumWidth => 0</code> and using <xref "
+"linkend=\"ST_CoverageUnion\"/> to union the result coverage. Holes in the "
+"union correspond to gaps in the original dataset. Gap widths can be measured "
+"by extracting the holes as polygons and running <xref "
+"linkend=\"ST_MaximumInscribedCircle\"/> on them; the gap width is twice the "
+"computed radius."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0 - requires GEOS >= 3.14.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Polygons with overlaps and gaps"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Invalid coverage edges"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Clean polygonal coverage, with overlaps and narrow gaps removed"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
+"linkend=\"ST_CoverageSimplify\"/>, <xref "
+"linkend=\"ST_MaximumInscribedCircle\"/>"
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Window function that simplifies the edges of a polygonal coverage."
@@ -13055,77 +13335,6 @@ msgid ""
"linkend=\"ST_CoverageClean\"/>, <xref linkend=\"ST_Union\"/>"
msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal "
-"coverage, given a non-clean input."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A window function which alters the edges of a polygonal coverage to ensure "
-"that none of the polygons overlap, that small gaps are snapped away, and "
-"that all shared edges are exactly identical. The result is a clean coverage "
-"that will pass validation tests like <xref "
-"linkend=\"ST_CoverageInvalidEdges\"/>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <parameter>gapMaximumWidth</parameter> controls the cleaning of gaps "
-"between polygons. Gaps smaller than this tolerance will be closed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <parameter>snappingDistance</parameter> controls the node snapping step, "
-"when nearby vertices are snapped together. The default setting (-1) applies "
-"an automatic snapping distance based on an analysis of the input. Set to 0.0 "
-"to turn off all snapping."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <parameter>overlapMergeStrategy</parameter> controls the algorithm used "
-"to determine which neighboring polygons to merge overlapping areas into."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "<code>MERGE_MAX_AREA</code> chooses polygon with maximum area"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "<code>MERGE_MIN_AREA</code> chooses polygon with minimum area"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "<code>MERGE_MIN_INDEX</code> chooses polygon with smallest input index"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.6.0 - requires GEOS >= 3.14.0"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_Union\"/> <xref linkend=\"ST_CoverageSimplify\"/>"
-msgstr ""
#. Tag: title
#, no-c-format
msgid "Geometry Editors"
@@ -14587,9 +14796,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"These functions are rarely used functions that should only be used if your "
-"data is corrupted in someway. They are used for troubleshooting corruption "
-"and also fixing things that should under normal circumstances, never happen."
+"These routines are reserved for diagnosing and repairing data corruption. "
+"They provide last-resort maintenance operations that are not required during "
+"normal spatial workflows."
msgstr ""
#. Tag: refpurpose
@@ -15528,11 +15737,11 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"In PostgreSQL 9.1+ - standard_conforming_strings is set to on by default, "
-"where as in past versions it was set to off. You can change defaults as "
-"needed for a single query or at the database or server level. Below is how "
-"you would do it with standard_conforming_strings = on. In this case we "
-"escape the ' with standard ansi ', but slashes are not escaped"
+"In PostgreSQL, standard_conforming_strings is set to on by default. You can "
+"change the default as needed for a single query or at the database or server "
+"level. Below is how you would do it with standard_conforming_strings = on. "
+"In this case we escape the ' with standard ANSI ', but slashes are not "
+"escaped"
msgstr ""
#. Tag: para
@@ -16111,6 +16320,15 @@ msgstr ""
msgid "Linear Referencing"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These functions measure and locate events along linear features. They "
+"support the classic linear referencing workflow of expressing positions as "
+"fractions or measures along routes and of projecting those measures back "
+"into spatial coordinates."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Returns a point interpolated along a line at a fractional location."
@@ -17503,10 +17721,10 @@ msgstr ""
#, no-c-format
msgid ""
"For geography types: computation is performed using the inverse geodesic "
-"calculation. Units of length are in meters. If PostGIS is compiled with PROJ "
-"version 4.8.0 or later, the spheroid is specified by the SRID, otherwise it "
-"is exclusive to WGS84. If <varname>use_spheroid = false</varname>, then the "
-"calculation is based on a sphere instead of a spheroid."
+"calculation. Units of length are in meters. The spheroid is specified by the "
+"SRID; when no SRID is provided, WGS84 is used. If <varname>use_spheroid = "
+"false</varname>, then the calculation is based on a sphere instead of a "
+"spheroid."
msgstr ""
#. Tag: para
@@ -17910,10 +18128,10 @@ msgstr ""
#, no-c-format
msgid ""
"For geography types, the calculations are performed using the inverse "
-"geodesic problem, where perimeter units are in meters. If PostGIS is "
-"compiled with PROJ version 4.8.0 or later, the spheroid is specified by the "
-"SRID, otherwise it is exclusive to WGS84. If <varname>use_spheroid = false</"
-"varname>, then calculations will approximate a sphere instead of a spheroid."
+"geodesic problem, where perimeter units are in meters. The spheroid is "
+"specified by the SRID; when no SRID is provided, WGS84 is used. If "
+"<varname>use_spheroid = false</varname>, then calculations will approximate "
+"a sphere instead of a spheroid."
msgstr ""
#. Tag: para
@@ -18091,6 +18309,16 @@ msgstr ""
msgid "Operators"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These entries document the spatial operators defined by PostGIS. Operators "
+"complement the function catalogue by supplying concise symbolic predicates "
+"for bounding-box interactions and spatial relationships. Their semantics "
+"follow the same geometric rules as the corresponding functions but are "
+"optimised for use in SQL expressions and index-supported filtering."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Bounding Box Operators"
@@ -18160,8 +18388,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Availability: 2.3.0 support for Block Range INdexes (BRIN) was introduced. "
-"Requires PostgreSQL 9.5+."
+"Availability: 2.3.0 support for Block Range INdexes (BRIN) was introduced."
msgstr ""
#. Tag: para
@@ -18785,10 +19012,8 @@ msgstr ""
msgid ""
"The <varname><-></varname> operator returns the 2D distance between "
"two geometries. Used in the \"ORDER BY\" clause provides index-assisted "
-"nearest-neighbor result sets. For PostgreSQL below 9.5 only gives centroid "
-"distance of bounding boxes and for PostgreSQL 9.5+, does true KNN distance "
-"search giving true distance between geometries, and distance sphere for "
-"geographies."
+"nearest-neighbor result sets with true KNN distance search for geometries, "
+"and distance on the sphere for geographies."
msgstr ""
#. Tag: para
@@ -18820,17 +19045,15 @@ msgstr ""
#, no-c-format
msgid ""
"Enhanced: 2.2.0 -- True KNN (\"K nearest neighbor\") behavior for geometry "
-"and geography for PostgreSQL 9.5+. Note for geography KNN is based on sphere "
-"rather than spheroid. For PostgreSQL 9.4 and below, geography support is new "
-"but only supports centroid box."
+"and geography. Note for geography KNN is based on sphere rather than "
+"spheroid."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Changed: 2.2.0 -- For PostgreSQL 9.5 users, old Hybrid syntax may be slower, "
-"so you'll want to get rid of that hack if you are running your code only on "
-"PostGIS 2.2+ 9.5+. See examples below."
+"Changed: 2.2.0 -- Old hybrid-syntax workarounds may be slower once true KNN "
+"is available. See examples below."
msgstr ""
#. Tag: para
@@ -18838,7 +19061,7 @@ msgstr ""
msgid ""
"Availability: 2.0.0 -- Weak KNN provides nearest neighbors based on geometry "
"centroid distances instead of true distances. Exact results for points, "
-"inexact for all other types. Available for PostgreSQL 9.1+"
+"inexact for all other types."
msgstr ""
#. Tag: para
@@ -18856,9 +19079,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"For users running with PostgreSQL < 9.5, use a hybrid query to find the "
-"true nearest neighbors. First a CTE query using the index-assisted KNN, then "
-"an exact query to get correct ordering:"
+"When a plan cannot produce exact distances directly, use a hybrid query to "
+"find the true nearest neighbors. First a CTE query using the index-assisted "
+"KNN, then an exact query to get correct ordering:"
msgstr ""
#. Tag: para
@@ -18880,8 +19103,7 @@ msgid ""
"The <varname>|=|</varname> operator returns the 3D distance between two "
"trajectories (See <xref linkend=\"ST_IsValidTrajectory\"/>). This is the "
"same as <xref linkend=\"ST_DistanceCPA\"/> but as an operator it can be used "
-"for doing nearest neighbor searches using an N-dimensional index (requires "
-"PostgreSQL 9.5.0 or higher)."
+"for doing nearest neighbor searches using an N-dimensional index."
msgstr ""
#. Tag: para
@@ -18903,7 +19125,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Availability: 2.2.0. Index-supported only available for PostgreSQL 9.5+"
+msgid "Availability: 2.2.0."
msgstr ""
#. Tag: para
@@ -18922,9 +19144,9 @@ msgstr ""
#, no-c-format
msgid ""
"The <varname><#></varname> operator returns distance between two "
-"floating point bounding boxes, possibly reading them from a spatial index "
-"(PostgreSQL 9.1+ required). Useful for doing nearest neighbor <emphasis "
-"role=\"strong\">approximate</emphasis> distance ordering."
+"floating point bounding boxes, possibly reading them from a spatial index. "
+"Useful for doing nearest neighbor <emphasis role=\"strong\">approximate</"
+"emphasis> distance ordering."
msgstr ""
#. Tag: para
@@ -18945,7 +19167,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid "Availability: 2.0.0 -- KNN only available for PostgreSQL 9.1+"
+msgid "Availability: 2.0.0."
msgstr ""
#. Tag: para
@@ -18978,11 +19200,6 @@ msgid ""
"clause."
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 2.2.0 -- KNN only available for PostgreSQL 9.1+"
-msgstr ""
#. Tag: title
#, no-c-format
msgid "Geometry Output"
@@ -19179,9 +19396,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The default behavior in PostgreSQL 9.0 has been changed to output bytea in "
-"hex encoding. If your GUI tools require the old behavior, then SET "
-"bytea_output='escape' in your database."
+"PostgreSQL outputs <varname>bytea</varname> values in hex encoding by "
+"default. If your GUI tools require the old behavior, then SET "
+"<code>bytea_output='escape'</code> in your database."
msgstr ""
#. Tag: para
@@ -19447,6 +19664,15 @@ msgid ""
"end up inside the feature’s \"properties\" member."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When the input record includes duplicate column names, the resulting "
+"\"properties\" object will contain repeated keys. <function>ST_AsGeoJSON</"
+"function> raises a warning in that case because PostgreSQL <type>jsonb</"
+"type> keeps only the last value for duplicate keys."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -19506,6 +19732,11 @@ msgstr ""
msgid "Changed: 3.5.0 allow specifying the column containing the feature id"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Changed: 3.7.0 added warning about duplicate keys"
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Generate a FeatureCollection:"
@@ -20244,11 +20475,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"The 'options' argument is a bitfield. For PostGIS 2.2+, this is used to "
-"denote whether to represent coordinates with X3D GeoCoordinates Geospatial "
-"node and also whether to flip the x/y axis. By default, <code>ST_AsX3D</"
-"code> outputs in database form (long,lat or X,Y), but X3D default of lat/"
-"lon, y/x may be preferred."
+"The 'options' argument is a bitfield that denotes whether to represent "
+"coordinates with the X3D GeoCoordinates geospatial node and whether to flip "
+"the x/y axis. By default, <code>ST_AsX3D</code> outputs in database form "
+"(long,lat or X,Y), but the X3D default of lat/lon, y/x may be preferred."
msgstr ""
#. Tag: para
@@ -20943,6 +21173,18 @@ msgid ""
"operations executed by the index recheck process fewer points."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When casting a subdivided geometry to geography, the resulting geography may "
+"differ from the original. Subdivision adds vertices in planar (geometry) "
+"space. If vertices are inserted along the boundary, they will alter the "
+"geographical representation, where edges are interpreted as geodesic "
+"segments. To minimize distortion, first densify the geography using <xref "
+"linkend=\"ST_Segmentize\"/> to add geodesic vertices, then cast to geometry "
+"before subdivision."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -20977,7 +21219,9 @@ msgstr ""
msgid ""
"<emphasis role=\"bold\">Example:</emphasis> Densify a long geography line "
"using ST_Segmentize(geography, distance), and use ST_Subdivide to split the "
-"resulting line into sublines of 8 vertices."
+"resulting line into sublines of 8 vertices. Densification minimizes the "
+"impact of changes to the geography representation of a geometry when "
+"subdividing."
msgstr ""
#. Tag: para
@@ -21293,10 +21537,11 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"'side=both|left|right' : 'left' or 'right' performs a single-sided buffer on "
-"the geometry, with the buffered side relative to the direction of the line. "
-"This is only applicable to LINESTRING geometry and does not affect POINT or "
-"POLYGON geometries. By default end caps are square."
+"'side=both|left|right' : defaults to 'both'. 'left' or 'right' performs a "
+"single-sided buffer on the geometry, with the buffered side relative to the "
+"direction of the line. This is only applicable to LINESTRING geometry and "
+"does not affect POINT or POLYGON geometries. By default end caps are square "
+"when 'left' or 'right' are specified."
msgstr ""
#. Tag: para
@@ -22073,9 +22318,19 @@ msgstr ""
msgid "This function strips the M dimension."
msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Cardinality 2"
+msgstr ""
#. Tag: para
#, no-c-format
-msgid "Merging lines with different orientation."
+msgid "Nodes with cardinality 2 are merged away."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Cardinality 3 or More"
msgstr ""
#. Tag: para
@@ -22083,6 +22338,11 @@ msgstr ""
msgid "Lines are not merged across intersections with degree > 2."
msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Non-Touching Lines"
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -22090,14 +22350,19 @@ msgid ""
"MultiLineString is returned."
msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Directed Parameter"
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Lines with opposite directions are not merged if directed = TRUE."
msgstr ""
-#. Tag: para
+#. Tag: title
#, no-c-format
-msgid "Example showing Z-dimension handling."
+msgid "Z-dimension Handling"
msgstr ""
#. Tag: para
@@ -24718,9 +24983,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
-"From PostGIS 2.0+ the srid of a non-georeferenced raster/geometry is 0 "
-"instead of the prior -1."
+msgid "Non-georeferenced rasters and geometries use SRID 0."
msgstr ""
#. Tag: refpurpose
@@ -26214,12 +26477,12 @@ msgstr ""
#, no-c-format
msgid ""
"If you find your transformation support is not working right, you may need "
-"to set the environment variable PROJSO to the .so or .dll projection library "
-"your PostGIS is using. This just needs to have the name of the file. So for "
+"to set the environment variable PROJSO to the projection library your "
+"PostGIS build is using. This just needs to have the name of the file. So for "
"example on windows, you would in Control Panel -> System -> "
"Environment Variables add a system variable called <varname>PROJSO</varname> "
-"and set it to <varname>libproj.dll</varname> (if you are using proj 4.6.1). "
-"You'll have to restart your PostgreSQL service/daemon after this change."
+"and set it to <varname>libproj.dll</varname>. You'll have to restart your "
+"PostgreSQL service/daemon after this change."
msgstr ""
#. Tag: para
@@ -27734,16 +27997,14 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
-"Complete example of tiles of a coverage with neighborhood. This query only "
-"works with PostgreSQL 9.1 or higher."
+msgid "Complete example of tiles of a coverage with neighborhood."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"Example like the prior one for tiles of a coverage with neighborhood but "
-"works with PostgreSQL 9.0."
+"using only basic SQL features."
msgstr ""
#. Tag: title
@@ -28999,9 +29260,7 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
-"Complete example of tiles of a coverage. This query only works with "
-"PostgreSQL 9.1 or higher."
+msgid "Complete example of tiles of a coverage."
msgstr ""
#. Tag: para
@@ -29449,6 +29708,13 @@ msgid ""
"result invalid geometries."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Changed 3.7.0, the polygonization honours PostgreSQL interrupts so "
+"cancellations and statement timeouts halt processing promptly."
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Availability: Requires GDAL 1.7 or higher."
@@ -34745,9 +35011,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"\"linework\" is the original algorithm, and builds valid geometries by first "
+"\"linework\" is the default algorithm, and builds valid geometries by first "
"extracting all lines, noding that linework together, then building a value "
-"output from the linework."
+"output from the linework. The requirement that no vertices are lost can "
+"generate complex collections as outputs."
msgstr ""
#. Tag: para
@@ -34755,16 +35022,30 @@ msgstr ""
msgid ""
"\"structure\" is an algorithm that distinguishes between interior and "
"exterior rings, building new geometry by unioning exterior rings, and then "
-"differencing all interior rings."
+"differencing all interior rings. The results tend to be more intuitive, "
+"where collapsed lines are discarded in the output."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
"The \"keepcollapsed\" key is only valid for the \"structure\" algorithm, and "
-"takes a value of \"true\" or \"false\". When set to \"false\", geometry "
+"takes a value of \"true\" or \"false\"."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Keep collapsed of \"false\" is the default, and means that geometry "
"components that collapse to a lower dimensionality, for example a one-point "
-"linestring would be dropped."
+"linestring will be dropped."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Keep collapsed of \"true\" means geometry components that collapse to a "
+"lower dimensionality will be retained."
msgstr ""
#. Tag: para
@@ -36391,9 +36672,8 @@ msgid ""
"Like the geometry data type, geography data is associated with a spatial "
"reference system via a spatial reference system identifier (SRID). Any "
"geodetic (long/lat based) spatial reference system defined in the "
-"<varname>spatial_ref_sys</varname> table can be used. (Prior to PostGIS 2.2, "
-"the geography type supported only WGS 84 geodetic (SRID:4326)). You can add "
-"your own custom geodetic spatial reference system as described in <xref "
+"<varname>spatial_ref_sys</varname> table can be used. You can add your own "
+"custom geodetic spatial reference system as described in <xref "
"linkend=\"user-spatial-ref-sys\"/>."
msgstr ""
@@ -38091,9 +38371,9 @@ msgstr ""
#, no-c-format
msgid ""
"BRIN stands for \"Block Range Index\". It is a general-purpose index method "
-"introduced in PostgreSQL 9.5. BRIN is a <emphasis>lossy</emphasis> index "
-"method, meaning that a secondary check is required to confirm that a record "
-"matches a given search condition (which is the case for all provided spatial "
+"provided by PostgreSQL. BRIN is a <emphasis>lossy</emphasis> index method, "
+"meaning that a secondary check is required to confirm that a record matches "
+"a given search condition (which is the case for all provided spatial "
"indexes). It provides much faster index creation and much smaller index "
"size, with reasonable read performance. Its primary purpose is to support "
"indexing very large tables on columns which have a correlation with their "
Summary of changes:
doc/po/templates/postgis-manual.pot | 1034 ++++++++++++++++++++++-------------
1 file changed, 657 insertions(+), 377 deletions(-)
hooks/post-receive
