[SCM] PostGIS branch master updated. 3.6.0rc2-208-gdfc6bdfeb
Tue Nov 18 18:47:55 PST 2025
the project "PostGIS".
       via  dfc6bdfeb851416818eb0079e2fb19dd0a172b12 (commit)
      from  be8edabdb288c89046c5cc97a0817f505c9039f4 (commit)
revisions in full, below.
commit dfc6bdfeb851416818eb0079e2fb19dd0a172b12
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date:   Wed Nov 19 01:46:13 2025 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 97.7% (5763 of 5893 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index e6806a600..e77226c26 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,10 +10,10 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-11-11 04:47+0000\n"
+"PO-Revision-Date: 2025-11-19 02:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -53,6 +53,11 @@ msgid ""
 "You can also use the more cross-platform approach of setting the "
 "corresponding <xref linkend=\"PostGIS_GUC\"/>."
 msgstr ""
+"データベース外ラスターとすべてのラスタードライバーはデフォルトでは無効です。"
+"有効にするには、サーバー側で環境変数 <varname>POSTGIS_GDAL_ENABLED_DRIVERS</v"
+"arname>と<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> "
+"とを設定する必要があります。よりクロスプラットフォームにするなら、"
+"対応する<xref linkend=\"PostGIS_GUC\"/>を設定します。"
 #. Tag: para
 #, no-c-format
@@ -96,6 +101,11 @@ msgid ""
 "<replaceable>CLUSTER</replaceable>/environment</filename> where the "
 "placeholders refer to the PostgreSQL major version and cluster name."
 msgstr ""
+"環境変数はOSによって変化します。UbuntuやDebian上でapt-"
+"postgresqlを介してPostgreSQLをインストールした場合には、<filename>/etc/"
+"postgresql/<replaceable>MAJOR</replaceable>/<replaceable>CLUSTER</replaceable"
+">/environment</filename> (MAJROはメジャーバージョン、CLUSTERはクラスター名が"
+"入ります)を編集する方が良いです。"
 #. Tag: para
 #, no-c-format
@@ -139,6 +149,8 @@ msgid ""
 "If you have compiled and installed the extensions/postgis modules, you can "
 "turn a database into a spatial one using the EXTENSION mechanism."
 msgstr ""
+"extensions/postgisモジュールをコンパイル、インストール済みの場合には、EXTENSI"
+"ON機構を使うことでデータベースを空間データベースに切り替えることができます。"
 #. Tag: para
 #, no-c-format
@@ -294,7 +306,7 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Soft upgrade using extensions"
-msgstr ""
+msgstr "エクステンションを使ったソフトアップグレード"
 #. Tag: para
 #, no-c-format
@@ -303,6 +315,9 @@ msgid ""
 "upgrade using extensions as well. Doing a minor upgrade with extensions is "
 "fairly painless."
 msgstr ""
+"PostGISをエクステンションとして入れている場合には、アップグレードmのエクステ"
+"ンションを使う必要があります。エクステンションでのマイナーアップグレードでは"
+"ほとんど痛みは伴いません。"
 #. Tag: para
 #, no-c-format
@@ -310,6 +325,8 @@ msgid ""
 "Use the <xref linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade "
 "to the latest version you have installed."
 msgstr ""
+"インストール済みのバージョンのうち最新バージョンにアップグレードするには<xref"
+" linkend=\"PostGIS_Extensions_Upgrade\"/> 関数を使います。"
 #. Tag: para
 #, no-c-format
@@ -320,6 +337,11 @@ msgid ""
 "<varname>postgis_raster</varname> objects are folded back into the main "
 "extension."
 msgstr ""
+"PostGIS 2.5をまだ使っているデータベースをアップグレードするときには、 "
+"<command>ALTER EXTENSION</command>を<function>postgis_extensions_upgrade()</f"
+"unction>に先立って使います。 ラスターエクステンションが独立する前の<varname>p"
+"ostgis_raster</varname>オブジェクトを確実に主エクステンションに折り込むように"
+"するためです。"
 #. Tag: para
 #, no-c-format
@@ -392,7 +414,7 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Soft upgrade without extensions"
-msgstr ""
+msgstr "エクステンションを使わないソフトアップグレード"
 #. Tag: para
 #, no-c-format
@@ -658,6 +680,9 @@ msgid ""
 "<code>postgresql.conf</code> or <code>postgresql.auto.conf</code> by using "
 "the <code>ALTER SYSTEM</code> command."
 msgstr ""
+"<code>postgresql.conf</code>または<code>postgresql.auto."
+"conf</code>を触らなくても、 <code>ALTER "
+"SYSTEM</code>コマンドでサーバーレベルのコンフィギュレーションが可能です。"
 #. Tag: para
 #, no-c-format
@@ -705,7 +730,7 @@ msgstr "shared_buffers"
 #. Tag: para
 #, no-c-format
 msgid "Default: ~128MB"
-msgstr ""
+msgstr "デフォルト: ~128MB"
 #. Tag: para
 #, no-c-format
@@ -725,6 +750,10 @@ msgid ""
 "and therefore also bounds how many workers can participate in parallel "
 "queries."
 msgstr ""
+"<link xlink:href=\"https://www.postgresql.org/docs/current/static/runtime-"
+"config-resource.html#GUC-MAX-WORKER-PROCESSES\">max_worker_processes</link>で"
+"有効なバックグラウンドプロセス数の最大値をサーバーに対して制御できます。間接"
+"的にパラレルクエリーに参加するワーカーの上限値も設定できると言えます。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 41 +++++++++++++++++++++++++++++++++++------
 1 file changed, 35 insertions(+), 6 deletions(-)
hooks/post-receive
