[SCM] PostGIS branch stable-3.6 updated. 3.6.1-5-g4a9da4fca
git at osgeo.org
git at osgeo.org
Wed Nov 19 08:39:20 PST 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
via 4a9da4fcaa9de8e7dc87b6a3be7569cdc2e17e95 (commit)
from c615e151d0f02f6f0d469255188d35cf09fb4689 (commit)
revisions in full, below.
commit 4a9da4fcaa9de8e7dc87b6a3be7569cdc2e17e95
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 19 08:39:11 2025 -0800
schema qualify call in ST_MPointFromText, references #6020
diff --git a/NEWS b/NEWS
index 9ec818ffe..d1c1e0708 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,7 @@
PostGIS 3.6.2
2025/xx/xx
This version requires PostgreSQL 12-18, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.14+ is needed.
To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
@@ -14,6 +16,8 @@ SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_co
- #6019, make clean does not remove cunit generated files
(Bas Couwenberg)
+- #6020, schema qualify call in ST_MPointFromText (Paul Ramsey)
PostGIS 3.6.1
2025/11/13
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c4177edb9..398031528 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5716,7 +5716,7 @@ CREATE OR REPLACE FUNCTION ST_MPointFromText(text, integer)
RETURNS geometry
AS '
SELECT CASE WHEN @extschema at .ST_GeometryType(@extschema at .ST_GeomFromText($1, $2)) = ''ST_MultiPoint''
- THEN ST_GeomFromText($1, $2)
+ THEN @extschema at .ST_GeomFromText($1, $2)
ELSE NULL END
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
Summary of changes:
NEWS | 4 ++++
postgis/postgis.sql.in | 2 +-
2 files changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
