[SCM] PostGIS branch master updated. 3.6.0rc2-219-ge137ea4cb
Tue Nov 25 11:34:12 PST 2025
the project "PostGIS".
       via  e137ea4cb571d659520bb25d803d24a51b4d5850 (commit)
      from  6bc133599bd77505649192a48e5986dd85cb5633 (commit)
revisions in full, below.
commit e137ea4cb571d659520bb25d803d24a51b4d5850
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 25 14:33:25 2025 -0500
    Minor doc cleanup
    Add 3.7 to version what's new section
diff --git a/doc/extras_tigergeocoder.xml b/doc/extras_tigergeocoder.xml
index 8ddd36ab8..2889f6286 100644
--- a/doc/extras_tigergeocoder.xml
+++ b/doc/extras_tigergeocoder.xml
@@ -52,7 +52,7 @@ you can upgrade the scripts using the accompanying upgrade_geocoder.bat
          <listitem><para><link xlink:href="http://wiki.openstreetmap.org/wiki/Nominatim">Nominatim</link>
      uses OpenStreetMap gazeteer formatted data.  It requires osm2pgsql for loading the data together with PostgreSQL and PostGIS.  It is packaged as a webservice interface and seems designed to be called as a webservice.
      Just like the TIGER Geocoder, it has both a geocoder and a reverse geocoder component.  From the documentation, it is unclear if it has a pure SQL interface like the TIGER Geocoder, or if a good deal of the logic is implemented in the web interface.</para></listitem>
-         <listitem><para><link xlink:href="http://www.gisgraphy.com/">GIS Graphy</link> also utilizes PostGIS and like Nominatim works with OpenStreetMap (OSM) data.  It comes with a loader to load OSM data and similar to Nominatim is capable of geocoding not just US. Much like Nominatim, it runs as a webservice and relies on Java 1.5, Servlet apps, Solr. GisGraphy is cross-platform and also has a reverse geocoder among some other neat features.</para></listitem>
+         <listitem><para><link xlink:href="https://www.gisgraphy.com/">GIS Graphy</link> can utilize PostGIS and like Nominatim uses OpenStreetMap (OSM) data along with some other sources.  It comes with a loader to load OSM data and similar to Nominatim is capable of geocoding not just US. Much like Nominatim, it runs as a webservice and relies on Java 1.5, Servlet apps, Solr. GisGraphy is cross-platform and also has a reverse geocoder among some other neat features.</para></listitem>
      </itemizedlist>
     <refentry xml:id="Drop_Indexes_Generate_Script">
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index af249573e..502fcb873 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -1937,12 +1937,13 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"<link xlink:href=\"http://www.gisgraphy.com/\">GIS Graphy</link> also "
-"utilizes PostGIS and like Nominatim works with OpenStreetMap (OSM) data. It "
-"comes with a loader to load OSM data and similar to Nominatim is capable of "
-"geocoding not just US. Much like Nominatim, it runs as a webservice and "
-"relies on Java 1.5, Servlet apps, Solr. GisGraphy is cross-platform and also "
-"has a reverse geocoder among some other neat features."
+"<link xlink:href=\"https://www.gisgraphy.com/\">GIS Graphy</link> can "
+"utilize PostGIS and like Nominatim uses OpenStreetMap (OSM) data along with "
+"some other sources. It comes with a loader to load OSM data and similar to "
+"Nominatim is capable of geocoding not just US. Much like Nominatim, it runs "
+"as a webservice and relies on Java 1.5, Servlet apps, Solr. GisGraphy is "
+"cross-platform and also has a reverse geocoder among some other neat "
+"features."
 msgstr ""
 #. Tag: refpurpose
diff --git a/doc/xsl-config.xml b/doc/xsl-config.xml
index c4395a8fa..fe373c755 100644
--- a/doc/xsl-config.xml
+++ b/doc/xsl-config.xml
@@ -21,6 +21,7 @@
         <!-- List of maj/min versions we want to know about -->
         <postgis_versions>
+            <v>3.6</v>
             <v>3.6</v>
             <v>3.5</v>
             <v>3.4</v>
Summary of changes:
 doc/extras_tigergeocoder.xml        |  2 +-
 doc/po/templates/postgis-manual.pot | 13 +++++++------
 doc/xsl-config.xml                  |  1 +
 3 files changed, 9 insertions(+), 7 deletions(-)
hooks/post-receive
