[SCM] PostGIS branch master updated. 3.6.0rc2-229-gc7f7524bd
Thu Nov 27 23:02:53 PST 2025
the project "PostGIS".
       via  c7f7524bdd6335fbc5c207c46a6a45992cb60a88 (commit)
      from  eb73a244e131c0e362e2b4b3f8257c9ce4da3057 (commit)
revisions in full, below.
commit c7f7524bdd6335fbc5c207c46a6a45992cb60a88
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Nov 28 08:01:54 2025 +0100
    Add --disable-spellcheck-tests configure switch
    For those who have a broken codespell
    References #6021
diff --git a/GNUmakefile.in b/GNUmakefile.in
index c1d58738f..1e0c2fb92 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -309,5 +309,5 @@ check-spell:
 ifneq (@CODESPELL@,)
 	cd $(top_srcdir) && @CODESPELL@
 else
-	@echo "SKIP: codespell not installed, cannot check spell"
+	@echo "SKIP: spell checking disabled"
 endif
diff --git a/configure.ac b/configure.ac
index efd360053..29f66a38c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -186,9 +186,16 @@ case $host_os in
 esac
 AC_SUBST([MINGWBUILD])
-AC_PATH_PROG([CODESPELL], [codespell], [])
-if test "x$CODESPELL" = "x"; then
-	AC_MSG_WARN([codespell is not installed so spelling cannot be checked])
+AC_ARG_ENABLE([spellcheck-tests],
+    [AS_HELP_STRING([--disable-spellcheck-tests],
+                    [Disable spell checking tests])])
+if test "x$enable_spellcheck_tests" = "xno"; then
+  AC_MSG_NOTICE([NOTE: spell checking tests disabled])
+else
+  AC_PATH_PROG([CODESPELL], [codespell], [])
+  if test "x$CODESPELL" = "x"; then
+    AC_MSG_WARN([codespell is not installed so spelling cannot be checked])
+  fi
 fi
 AC_PATH_PROG([PERL], [perl], [])
Summary of changes:
 GNUmakefile.in |  2 +-
 configure.ac   | 13 ++++++++++---
 2 files changed, 11 insertions(+), 4 deletions(-)
hooks/post-receive
