[SCM] PostGIS branch master updated. 3.6.0rc2-230-g4507d2c95
git at osgeo.org
git at osgeo.org
Fri Nov 28 00:47:50 PST 2025
the project "PostGIS".
via 4507d2c954d8b7d410004a55fa81b8659b67f053 (commit)
from c7f7524bdd6335fbc5c207c46a6a45992cb60a88 (commit)
revisions in full, below.
commit 4507d2c954d8b7d410004a55fa81b8659b67f053
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Fri Nov 28 07:12:14 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 98.6% (5814 of 5893 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index b9d62334b..68aba062d 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-11-28 03:47+0000\n"
+"PO-Revision-Date: 2025-11-28 08:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/ja/>\n"
@@ -26709,6 +26709,11 @@ msgid ""
"does not affect POINT or POLYGON geometries. By default end caps are square "
"when 'left' or 'right' are specified."
msgstr ""
+"'side=both|left|right' : デフォルトは'both'です。'left'または'right'でジオメ"
+"トリーの片側へのバッファーが行われますが、左右はラインの方向で決まります。こ"
+"れはLINESTRINGジオメトリーにのみ適用可能です。POINTまたはPOLYGONジオメトリに"
+"影響を与えません。'left'または'right'を指定した場合にはデフォルトの終端スタイ"
+"ルは正方形になります。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 7 ++++++-
1 file changed, 6 insertions(+), 1 deletion(-)
hooks/post-receive
