[SCM] PostGIS branch master updated. 3.6.0rc2-238-gef19e8fb4
Sun Nov 30 12:07:02 PST 2025
the project "PostGIS".
       via  ef19e8fb446e05d42f54adc59d51ebdf2e88c5e0 (commit)
      from  eebec8c1cdf57805289c85ce9e155d386a860256 (commit)
revisions in full, below.
commit ef19e8fb446e05d42f54adc59d51ebdf2e88c5e0
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Dec 1 00:06:43 2025 +0400
    [raster] Support GDT_Float16 pixel type
    Closes #5941
diff --git a/NEWS b/NEWS
index 3401fe5f0..3d974e88c 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ xxxx/xx/xx
           (Sandro Santilli)
  - #6001, support MultiLineString in ST_MakeLine (Paul Ramsey)
  - #2858, ST_MMin and ST_MMax (Paul Ramsey)
+ - #5941, [raster] Support GDT_Float16 pixel type (Darafei Praliaskouski)
  - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
  - #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
  - #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
diff --git a/raster/doc/RFC1-SerializedFormat b/raster/doc/RFC1-SerializedFormat
index 8b143b5eb..519d2ac9b 100644
--- a/raster/doc/RFC1-SerializedFormat
+++ b/raster/doc/RFC1-SerializedFormat
@@ -114,7 +114,7 @@ will be of 7 bytes.
  as part of the datum or is to be found on the server's
  filesystem.
- There are currently 11 supported pixel value types, so 4
+ There are currently 12 supported pixel value types, so 4
  bits are enough to account for all. We'll reserve
  the upper 4 bits for generic flags and define upmost as
  storage flag:
@@ -135,7 +135,7 @@ will be of 7 bytes.
     - PT_1BB, PT_2BUI, PT_4BUI, PT_8BSI, PT_8BUI:
       No alignment required, each value is 1 byte.
-    - PT_16BSI, PT_16BUI:
+    - PT_16BSI, PT_16BUI, PT_16BF:
       Data must be aligned to 2-bytes boundary.
     - PT_32BSI, PT_32BUI, PT_32BF:
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index ded95f1c9..6847319cf 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -184,19 +184,21 @@ typedef enum {
 } rt_errorstate;
 /* Pixel types */
-typedef enum {
-    PT_1BB=0,     /* 1-bit boolean            */
-    PT_2BUI=1,    /* 2-bit unsigned integer   */
-    PT_4BUI=2,    /* 4-bit unsigned integer   */
-    PT_8BSI=3,    /* 8-bit signed integer     */
-    PT_8BUI=4,    /* 8-bit unsigned integer   */
-    PT_16BSI=5,   /* 16-bit signed integer    */
-    PT_16BUI=6,   /* 16-bit unsigned integer  */
-    PT_32BSI=7,   /* 32-bit signed integer    */
-    PT_32BUI=8,   /* 32-bit unsigned integer  */
-    PT_32BF=10,   /* 32-bit float             */
-    PT_64BF=11,   /* 64-bit float             */
-    PT_END=13
+typedef enum
+	PT_1BB = 0,   /* 1-bit boolean            */
+	PT_2BUI = 1,  /* 2-bit unsigned integer   */
+	PT_4BUI = 2,  /* 4-bit unsigned integer   */
+	PT_8BSI = 3,  /* 8-bit signed integer     */
+	PT_8BUI = 4,  /* 8-bit unsigned integer   */
+	PT_16BSI = 5, /* 16-bit signed integer    */
+	PT_16BUI = 6, /* 16-bit unsigned integer  */
+	PT_32BSI = 7, /* 32-bit signed integer    */
+	PT_32BUI = 8, /* 32-bit unsigned integer  */
+	PT_16BF = 9,  /* 16-bit float             */
+	PT_32BF = 10, /* 32-bit float             */
+	PT_64BF = 11, /* 64-bit float             */
+	PT_END = 13
 } rt_pixtype;
 typedef enum {
@@ -2249,6 +2251,7 @@ extern void rtdealloc(void *mem);
 #define POSTGIS_RT_1BBMAX 1
 #define POSTGIS_RT_2BUIMAX 3
 #define POSTGIS_RT_4BUIMAX 15
+#define POSTGIS_RT_16F_MAX 65504.0F
 uint8_t
 rt_util_clamp_to_1BB(double value);
@@ -2280,6 +2283,12 @@ rt_util_clamp_to_32BUI(double value);
 float
 rt_util_clamp_to_32F(double value);
+float rt_util_clamp_to_16F(double value);
+uint16_t rt_util_float_to_float16(float value);
+float rt_util_float16_to_float(uint16_t value);
 int
 rt_util_dbl_trunc_warning(
 	double initialvalue,
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index 4578609a2..2cbe92ead 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -11,6 +11,7 @@
  * Copyright (C) 2009-2011 Pierre Racine <pierre.racine at sbf.ulaval.ca>
  * Copyright (C) 2009-2011 Mateusz Loskot <mateusz at loskot.net>
  * Copyright (C) 2008-2009 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2025 Darafei Praliaskouski <me at komzpa.net>
  * This program is free software; you can redistribute it and/or
  * modify it under the terms of the GNU General Public License
@@ -189,8 +190,7 @@ rt_band_init_value(
 			checkvalint = ptr[0];
 			break;
-		case PT_16BUI:
+		case PT_16BUI: {
 			uint16_t *ptr = mem;
 			uint16_t clamped_initval = rt_util_clamp_to_16BUI(initval);
 			for (uint32_t i = 0; i < numval; i++)
@@ -198,8 +198,16 @@ rt_band_init_value(
 			break;
-		case PT_32BSI:
+		case PT_16BF: {
+			uint16_t *ptr = mem;
+			float clamped_initval = rt_util_clamp_to_16F(initval);
+			uint16_t packed = rt_util_float_to_float16(clamped_initval);
+			for (uint32_t i = 0; i < numval; i++)
+				ptr[i] = packed;
+			checkvalfloat = rt_util_float16_to_float(ptr[0]);
+			break;
+		case PT_32BSI: {
 			int32_t *ptr = mem;
 			int32_t clamped_initval = rt_util_clamp_to_32BSI(initval);
@@ -944,6 +952,13 @@ rt_band_set_nodata(rt_band band, double val, int *converted) {
 			checkvaluint = band->nodataval;
 			break;
+		case PT_16BF: {
+			float half = rt_util_clamp_to_16F(val);
+			/* Persist the exact half-float encoding so nodata comparisons stay bitwise-stable. */
+			band->nodataval = rt_util_float16_to_float(rt_util_float_to_float16(half));
+			checkvalfloat = (float)band->nodataval;
+			break;
 		case PT_32BF: {
 			band->nodataval = rt_util_clamp_to_32F(val);
 			checkvalfloat = band->nodataval;
@@ -1178,12 +1193,13 @@ rt_band_set_pixel(
 	data = rt_band_get_data(band);
 	offset = x + (y * band->width);
-	switch (pixtype) {
-		case PT_1BB: {
-			data[offset] = rt_util_clamp_to_1BB(val);
-			checkvalint = data[offset];
-			break;
+	switch (pixtype)
+	case PT_1BB: {
+		data[offset] = rt_util_clamp_to_1BB(val);
+		checkvalint = data[offset];
+		break;
 		case PT_2BUI: {
 			data[offset] = rt_util_clamp_to_2BUI(val);
@@ -1223,13 +1239,21 @@ rt_band_set_pixel(
 			break;
 		case PT_32BUI: {
-			uint32_t *ptr = (uint32_t*) data; /* we assume correct alignment */
+			uint32_t *ptr = (uint32_t *)data; /* we assume correct alignment */
 			ptr[offset] = rt_util_clamp_to_32BUI(val);
 			checkvaluint = ptr[offset];
 			break;
+		case PT_16BF: {
+			uint16_t *ptr = (uint16_t *)data; /* we assume correct alignment */
+			float clamped = rt_util_clamp_to_16F(val);
+			/* Pack via explicit converter to mirror GDAL's Float16 representation. */
+			ptr[offset] = rt_util_float_to_float16(clamped);
+			checkvalfloat = rt_util_float16_to_float(ptr[offset]);
+			break;
 		case PT_32BF: {
-			float *ptr = (float*) data; /* we assume correct alignment */
+			float *ptr = (float *)data; /* we assume correct alignment */
 			ptr[offset] = rt_util_clamp_to_32F(val);
 			checkvalfloat = ptr[offset];
 			break;
@@ -1244,7 +1268,7 @@ rt_band_set_pixel(
 			rterror("rt_band_set_pixel: Unknown pixeltype %d", pixtype);
 			return ES_ERROR;
 	/* If the stored value is not NODATA, reset the isnodata flag */
 	if (!rt_band_clamped_value_is_nodata(band, val)) {
@@ -1631,12 +1655,17 @@ rt_band_get_pixel(
 			break;
 		case PT_32BUI: {
 			*value = ptr[offset];
 			break;
+		case PT_16BF: {
+			*value = rt_util_float16_to_float(ptr[offset]);
+			break;
 		case PT_32BF: {
 			break;
@@ -2213,6 +2242,12 @@ rt_band_corrected_clamped_value(
 			else
 				(*newval)--;
 			break;
+		case PT_16BF:
+			if (FLT_EQ(rt_util_clamp_to_16F(val), rt_util_clamp_to_16F(minval)))
+				*newval += FLT_EPSILON;
+			else
+				*newval -= FLT_EPSILON;
+			break;
 		case PT_32BF:
 			if (FLT_EQ(rt_util_clamp_to_32F(val), rt_util_clamp_to_32F(minval)))
diff --git a/raster/rt_core/rt_pixel.c b/raster/rt_core/rt_pixel.c
index d35298fea..15793e82e 100644
--- a/raster/rt_core/rt_pixel.c
+++ b/raster/rt_core/rt_pixel.c
@@ -11,6 +11,7 @@
  * Copyright (C) 2013  Nathaniel Hunter Clay <clay.nathaniel at gmail.com>
@@ -49,6 +50,7 @@ rt_pixtype_size(rt_pixtype pixtype) {
 			break;
 		case PT_16BSI:
 		case PT_16BUI:
+		case PT_16BF:
 			pixbytes = 2;
 			break;
 		case PT_32BSI:
@@ -94,6 +96,8 @@ rt_pixtype_index_from_name(const char* pixname) {
 		return PT_16BSI;
 	else if (strcmp(pixname, "16BUI") == 0)
 		return PT_16BUI;
+	else if (strcmp(pixname, "16BF") == 0)
+		return PT_16BF;
 	else if (strcmp(pixname, "32BSI") == 0)
 		return PT_32BSI;
 	else if (strcmp(pixname, "32BUI") == 0)
@@ -125,6 +129,8 @@ rt_pixtype_name(rt_pixtype pixtype) {
 			return "16BSI";
 		case PT_16BUI:
 			return "16BUI";
+		case PT_16BF:
+			return "16BF";
 		case PT_32BSI:
 			return "32BSI";
 		case PT_32BUI:
@@ -170,8 +176,11 @@ rt_pixtype_get_min_value(rt_pixtype pixtype) {
 		case PT_16BUI: {
 			return 0;
+		case PT_16BF: {
+			return (double)-POSTGIS_RT_16F_MAX;
 		case PT_32BSI: {
-			return (double) rt_util_clamp_to_32BSI((double) INT_MIN);
+			return (double)rt_util_clamp_to_32BSI((double)INT_MIN);
 		case PT_32BUI: {
 			return 0;
@@ -236,6 +245,10 @@ rt_errorstate rt_pixtype_compare_clamped_values(
 			if (rt_util_clamp_to_16BUI(val) == rt_util_clamp_to_16BUI(refval))
 				*isequal = 1;
 			break;
+		case PT_16BF:
+			if (FLT_EQ(rt_util_clamp_to_16F(val), rt_util_clamp_to_16F(refval)))
+				*isequal = 1;
+			break;
 		case PT_32BSI:
 			if (rt_util_clamp_to_32BSI(val) == rt_util_clamp_to_32BSI(refval))
 				*isequal = 1;
diff --git a/raster/rt_core/rt_serialize.c b/raster/rt_core/rt_serialize.c
index 4673b3e0c..dbb7cd527 100644
--- a/raster/rt_core/rt_serialize.c
+++ b/raster/rt_core/rt_serialize.c
@@ -10,6 +10,7 @@
@@ -653,6 +654,12 @@ rt_raster_serialize(rt_raster raster) {
 				ptr += 4;
 				break;
+			case PT_16BF: {
+				uint16_t v = rt_util_float_to_float16((float)band->nodataval);
+				memcpy(ptr, &v, 2);
+				ptr += 2;
+				break;
 			case PT_32BF: {
 				float v = band->nodataval;
 				memcpy(ptr, &v, 4);
@@ -849,6 +856,10 @@ rt_raster_deserialize(void* serialized, int header_only) {
 				band->nodataval = read_uint32(&ptr, littleEndian);
 				break;
+			case PT_16BF: {
+				band->nodataval = rt_util_float16_to_float(read_uint16(&ptr, littleEndian));
+				break;
 			case PT_32BF: {
 				band->nodataval = read_float32(&ptr, littleEndian);
 				break;
diff --git a/raster/rt_core/rt_statistics.c b/raster/rt_core/rt_statistics.c
index b5a6c7025..8be627161 100644
--- a/raster/rt_core/rt_statistics.c
+++ b/raster/rt_core/rt_statistics.c
@@ -10,6 +10,7 @@
@@ -1683,11 +1684,14 @@ rt_band_get_value_count(
 				roundto = 0;
 				break;
 			/* floating points, check the rounding */
+			case PT_16BF:
 			case PT_32BF:
 			case PT_64BF:
-				for (scale = 0; scale <= 20; scale++) {
+				for (scale = 0; scale <= 20; scale++)
 					tmpd = roundto * pow(10, scale);
-					if (FLT_EQ((tmpd - ((int) tmpd)), 0.0)) break;
+					if (FLT_EQ((tmpd - ((int)tmpd)), 0.0))
+						break;
 				break;
 			case PT_END:
diff --git a/raster/rt_core/rt_util.c b/raster/rt_core/rt_util.c
index e3e1f5415..95f4eb8f3 100644
--- a/raster/rt_core/rt_util.c
+++ b/raster/rt_core/rt_util.c
@@ -10,6 +10,7 @@
@@ -83,6 +84,94 @@ rt_util_clamp_to_32F(double value) {
 	return (float)fmin(fmax((value), -FLT_MAX), FLT_MAX);
+float
+rt_util_clamp_to_16F(double value)
+	 * GDAL exposes Float16 samples as raw 16-bit words, so we clamp to the
+	 * representable range before packing them manually rather than
+	 * depending on a runtime helper.
+	if (isnan(value))
+		return (float)value;
+	return (float)fmin(fmax((value), -POSTGIS_RT_16F_MAX), POSTGIS_RT_16F_MAX);
+uint16_t
+rt_util_float_to_float16(float value)
+	 * Manual half-float conversion keeps raster I/O independent of GDAL's
+	 * optional Float16 helpers while preserving IEEE semantics.
+	union {
+		float f;
+		uint32_t u;
+	} v;
+	v.f = value;
+	uint32_t sign = (v.u >> 16) & 0x8000U;
+	uint32_t mantissa = v.u & 0x7fffffU;
+	int32_t exponent = ((int32_t)((v.u >> 23) & 0xffU)) - 127 + 15;
+	if (exponent <= 0)
+		if (exponent < -10)
+			return (uint16_t)sign;
+		mantissa = (mantissa | 0x800000U) >> (uint32_t)(1 - exponent);
+		return (uint16_t)(sign | ((mantissa + 0x1000U) >> 13));
+	if (exponent >= 31)
+		return (uint16_t)(sign | 0x7c00U | (mantissa ? 0x200U : 0));
+	return (uint16_t)(sign | ((uint32_t)exponent << 10) | ((mantissa + 0x1000U) >> 13));
+float
+rt_util_float16_to_float(uint16_t value)
+	union {
+		uint32_t u;
+		float f;
+	} v;
+	uint32_t sign = (uint32_t)(value & 0x8000U) << 16;
+	uint32_t exponent = (value >> 10) & 0x1fU;
+	uint32_t mantissa = value & 0x3ffU;
+	if (exponent == 0)
+		if (mantissa == 0)
+			v.u = sign;
+		else
+			exponent = 1;
+			while ((mantissa & 0x400U) == 0)
+				mantissa <<= 1;
+				exponent--;
+			mantissa &= 0x3ffU;
+			v.u = sign | ((exponent + 127 - 15) << 23) | (mantissa << 13);
+	else if (exponent == 31)
+		v.u = sign | 0x7f800000U | (mantissa << 13);
+	else
+	return v.f;
  * Convert cstring name to GDAL Resample Algorithm
@@ -140,6 +229,10 @@ rt_util_pixtype_to_gdal_datatype(rt_pixtype pt) {
 			return GDT_Int32;
 		case PT_32BUI:
 			return GDT_UInt32;
+#if POSTGIS_GDAL_VERSION >= 31100 && defined(GDT_Float16)
+		case PT_16BF:
+			return GDT_Float16;
+#endif
 		case PT_32BF:
 			return GDT_Float32;
 		case PT_64BF:
@@ -179,11 +272,15 @@ rt_util_gdal_datatype_to_pixtype(GDALDataType gdt) {
 			return PT_32BF;
 		case GDT_Float64:
 			return PT_64BF;
+		case GDT_Float16:
+			return PT_16BF;
+#endif
 		default:
 			return PT_END;
-	return PT_END;
+		return PT_END;
@@ -717,12 +814,13 @@ rt_util_dbl_trunc_warning(
 			break;
 		case PT_32BUI: {
-			if (fabs(checkvaluint - initialvalue) >= 1) {
+			if (fabs(checkvaluint - initialvalue) >= 1)
 #if POSTGIS_RASTER_WARN_ON_TRUNCATION > 0
 				rtwarn("Value set for %s band got clamped from %f to %u",
-					rt_pixtype_name(pixtype),
-					initialvalue, checkvaluint
+				       rt_pixtype_name(pixtype),
+				       initialvalue,
+				       checkvaluint);
 #endif
 				result = 1;
@@ -738,6 +836,7 @@ rt_util_dbl_trunc_warning(
 			break;
+		case PT_16BF:
 		case PT_32BF: {
 				For float, because the initial value is a double,
diff --git a/raster/rt_core/rt_wkb.c b/raster/rt_core/rt_wkb.c
index 88daa9665..86efe1e74 100644
--- a/raster/rt_core/rt_wkb.c
+++ b/raster/rt_core/rt_wkb.c
@@ -10,6 +10,7 @@
@@ -129,6 +130,10 @@ rt_band_from_wkb(
 			band->nodataval = read_uint32(ptr, littleEndian);
 			break;
+		case PT_16BF: {
+			band->nodataval = rt_util_float16_to_float(read_uint16(ptr, littleEndian));
+			break;
 		case PT_32BF: {
 			band->nodataval = read_float32(ptr, littleEndian);
 			break;
@@ -619,6 +624,12 @@ rt_raster_to_wkb(rt_raster raster, int outasin, uint32_t *wkbsize) {
 				ptr += 4;
 				break;
+			case PT_16BF: {
+				ptr += 2;
+				break;
 			case PT_32BF: {
 				memcpy(ptr, &v, 4);
diff --git a/raster/scripts/python/pixval.py b/raster/scripts/python/pixval.py
index 644e1aec6..44c953cd0 100755
--- a/raster/scripts/python/pixval.py
+++ b/raster/scripts/python/pixval.py
@@ -39,6 +39,8 @@ def pt2fmt(pt):
         gdalc.GDT_Float32: 'f',
         gdalc.GDT_Float64: 'f'
+    if hasattr(gdalc, 'GDT_Float16'):
+        fmttypes[gdalc.GDT_Float16] = 'e'
     return fmttypes.get(pt, 'x')
 if len(sys.argv) < 5 or len(sys.argv) > 6:
diff --git a/raster/scripts/python/raster2pgsql.py b/raster/scripts/python/raster2pgsql.py
index c6401f925..7d227b413 100755
--- a/raster/scripts/python/raster2pgsql.py
+++ b/raster/scripts/python/raster2pgsql.py
@@ -222,6 +222,9 @@ def gdt2pt(gdt):
         gdalc.GDT_Float32 : { 'name': 'PT_32BF',  'id': 10 },
         gdalc.GDT_Float64 : { 'name': 'PT_64BF',  'id': 11 }
+        pixtypes[gdalc.GDT_Float16] = { 'name': 'PT_16BF', 'id': 9 }
     # XXX: Uncomment these logs to debug types translation
     #logit('MSG: Input GDAL pixel type: %s (%d)\n' % (gdal.GetDataTypeName(gdt), gdt))
@@ -240,6 +243,8 @@ def pt2numpy(pt):
         gdalc.GDT_Float32: numpy.float32,
         gdalc.GDT_Float64: numpy.float64
+        ptnumpy[gdalc.GDT_Float16] = numpy.float16
     return ptnumpy.get(pt, numpy.uint8)
 def pt2fmt(pt):
@@ -250,6 +255,7 @@ def pt2fmt(pt):
         6: 'H', # PT_16BUI
         7: 'i', # PT_32BSI
         8: 'I', # PT_32BUI
+        9: 'e', # PT_16BF
         10: 'f', # PT_32BF
         11: 'd'  # PT_64BF
@@ -264,6 +270,7 @@ def fmt2printfmt(fmt):
         'H': '%d', # PT_16BUI
         'i': '%d', # PT_32BSI
         'I': '%d', # PT_32BUI
+        'e': '%.8f', # PT_16BF
         'f': '%.15f', # PT_32BF
         'd': '%.15f', # PT_64BF
         's': '%s'
diff --git a/raster/scripts/python/rtrowdump.py b/raster/scripts/python/rtrowdump.py
index 8712db00d..d7a239182 100755
--- a/raster/scripts/python/rtrowdump.py
+++ b/raster/scripts/python/rtrowdump.py
@@ -47,6 +47,8 @@ def pt2gdt(pt):
         '32BF' : osgeo.gdalconst.GDT_Float32,
         '64BF' : osgeo.gdalconst.GDT_Float64
+    if hasattr(osgeo.gdalconst, 'GDT_Float16'):
+        pixtypes['16BF'] = osgeo.gdalconst.GDT_Float16
     return pixtypes.get(pt, 'UNKNOWN')
 def pt2numpy(pt):
@@ -60,6 +62,8 @@ def pt2numpy(pt):
         '32BF' : numpy.float32,
         '64BF' : numpy.float64
+    if hasattr(numpy, 'float16'):
+        numpytypes['16BF'] = numpy.float16
     return numpytypes.get(pt, numpy.uint8)
diff --git a/raster/test/cunit/cu_pixtype.c b/raster/test/cunit/cu_pixtype.c
index 45333a35e..b69db7b37 100644
--- a/raster/test/cunit/cu_pixtype.c
+++ b/raster/test/cunit/cu_pixtype.c
@@ -4,6 +4,7 @@
  * Copyright (C) 2012 Regents of the University of California
  *   <bkpark at ucdavis.edu>
@@ -32,6 +33,7 @@ static void test_pixtype_size() {
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_8BSI), 1);
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_16BUI), 2);
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_16BSI), 2);
+	CU_ASSERT_EQUAL(rt_pixtype_size(PT_16BF), 2);
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_32BUI), 4);
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_32BSI), 4);
 	CU_ASSERT_EQUAL(rt_pixtype_size(PT_32BF), 4);
@@ -52,6 +54,7 @@ static void test_pixtype_name() {
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_8BSI), "8BSI");
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_16BUI), "16BUI");
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_16BSI), "16BSI");
+	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_16BF), "16BF");
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_32BUI), "32BUI");
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_32BSI), "32BSI");
 	CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_32BF), "32BF");
@@ -68,6 +71,7 @@ static void test_pixtype_index_from_name() {
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("8BSI"), PT_8BSI);
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("16BUI"), PT_16BUI);
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("16BSI"), PT_16BSI);
+	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("16BF"), PT_16BF);
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("32BUI"), PT_32BUI);
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("32BSI"), PT_32BSI);
 	CU_ASSERT_EQUAL(rt_pixtype_index_from_name("32BF"), PT_32BF);
@@ -84,11 +88,17 @@ static void test_pixtype_get_min_value() {
 	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_2BUI), rt_util_clamp_to_2BUI((double) CHAR_MIN), DBL_EPSILON);
 	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_4BUI), rt_util_clamp_to_4BUI((double) CHAR_MIN), DBL_EPSILON);
 	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_8BUI), rt_util_clamp_to_8BUI((double) CHAR_MIN), DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_8BSI), rt_util_clamp_to_8BSI((double) SCHAR_MIN), DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_16BUI), rt_util_clamp_to_16BUI((double) SHRT_MIN), DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_16BSI), rt_util_clamp_to_16BSI((double) SHRT_MIN), DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_32BUI), rt_util_clamp_to_32BUI((double) INT_MIN), DBL_EPSILON);
-	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_32BSI), rt_util_clamp_to_32BSI((double) INT_MIN), DBL_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(
+	    rt_pixtype_get_min_value(PT_8BSI), rt_util_clamp_to_8BSI((double)SCHAR_MIN), DBL_EPSILON);
+	    rt_pixtype_get_min_value(PT_16BUI), rt_util_clamp_to_16BUI((double)SHRT_MIN), DBL_EPSILON);
+	    rt_pixtype_get_min_value(PT_16BSI), rt_util_clamp_to_16BSI((double)SHRT_MIN), DBL_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_16BF), -POSTGIS_RT_16F_MAX, DBL_EPSILON);
+	    rt_pixtype_get_min_value(PT_32BUI), rt_util_clamp_to_32BUI((double)INT_MIN), DBL_EPSILON);
+	    rt_pixtype_get_min_value(PT_32BSI), rt_util_clamp_to_32BSI((double)INT_MIN), DBL_EPSILON);
 	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_32BF), -FLT_MAX, DBL_EPSILON);
 	CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_64BF), -DBL_MAX, DBL_EPSILON);
@@ -200,6 +210,14 @@ static void test_pixtype_compare_clamped_values() {
 	CU_ASSERT_EQUAL(rt_pixtype_compare_clamped_values(PT_16BSI, 32767, -32767, &isequal), ES_NONE);
 	CU_ASSERT(!isequal);
+	/* 16BF */
+	CU_ASSERT_EQUAL(rt_pixtype_compare_clamped_values(PT_16BF, 1.5, 1.5, &isequal), ES_NONE);
+	CU_ASSERT(isequal);
+	CU_ASSERT_EQUAL(rt_pixtype_compare_clamped_values(PT_16BF, 70000.0, 65504.0, &isequal), ES_NONE);
+	CU_ASSERT_EQUAL(rt_pixtype_compare_clamped_values(PT_16BF, -70000.0, 0.0, &isequal), ES_NONE);
+	CU_ASSERT(!isequal);
 	/* 32BUI */
 	CU_ASSERT_EQUAL(rt_pixtype_compare_clamped_values(PT_32BUI, 4294967295UL, 4294967295UL, &isequal), ES_NONE);
 	CU_ASSERT(isequal);
Summary of changes:
 NEWS                                  |   1 +
 raster/doc/RFC1-SerializedFormat      |   4 +-
 raster/rt_core/librtcore.h            |  35 +++++++----
 raster/rt_core/rt_band.c              |  65 +++++++++++++++-----
 raster/rt_core/rt_pixel.c             |  15 ++++-
 raster/rt_core/rt_serialize.c         |  11 ++++
 raster/rt_core/rt_statistics.c        |   8 ++-
 raster/rt_core/rt_util.c              | 111 ++++++++++++++++++++++++++++++++--
 raster/rt_core/rt_wkb.c               |  11 ++++
 raster/scripts/python/pixval.py       |   2 +
 raster/scripts/python/raster2pgsql.py |   7 +++
 raster/scripts/python/rtrowdump.py    |   4 ++
 raster/test/cunit/cu_pixtype.c        |  28 +++++++--
 13 files changed, 258 insertions(+), 44 deletions(-)
hooks/post-receive
