[PostGIS] #5995: Add pg_upgrade testing in CI
trac at osgeo.org
Wed Oct 1 00:43:36 PDT 2025
Reporter: strk | Owner: robe
Type: task | Status: new
Priority: medium | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Keywords: pg_upgrade |
At the moment we have no CI agent testing pg_upgrade.
The OCI image used for Woodie testing already contains different
PostgreSQL versions so would be usable for such test.
Ideally we'd have a script to do the testing, so developers can also
easily run the script locally, like utils/check_all_upgrades.sh (and
possibly adding the new support in that same script)
Known bug whose fix could be secured in this way: #5899
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5995>
