[SCM] PostGIS branch master updated. 3.6.0rc2-69-g34ee8312c
Wed Oct 1 14:44:31 PDT 2025
the project "PostGIS".
       via  34ee8312cdb01171ceb2895d0c4f6124f3e63913 (commit)
       via  fba69e60f1fc636564afe16b6942a84f9c755a22 (commit)
      from  a89de164624f1a9024d7912107cd9e6662f0cadb (commit)
revisions in full, below.
commit 34ee8312cdb01171ceb2895d0c4f6124f3e63913
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 1 14:14:27 2025 -0700
    Ensure calloc called with count as first argument
diff --git a/loader/dbfopen.c b/loader/dbfopen.c
index 5611473f4..fa2df7f9a 100644
--- a/loader/dbfopen.c
+++ b/loader/dbfopen.c
@@ -1975,12 +1975,11 @@ DBFReorderFields( DBFHandle psDBF, int* panMap )
         return FALSE;
     /* a simple malloc() would be enough, but calloc() helps clang static analyzer */
-    panFieldOffsetNew = STATIC_CAST(int *, calloc(sizeof(int), psDBF->nFields));
-    panFieldSizeNew = STATIC_CAST(int *, calloc(sizeof(int),  psDBF->nFields));
-    panFieldDecimalsNew = STATIC_CAST(int *, calloc(sizeof(int), psDBF->nFields));
-    pachFieldTypeNew = STATIC_CAST(char *, calloc(sizeof(char), psDBF->nFields));
-    pszHeaderNew = STATIC_CAST(char*, malloc(sizeof(char) * XBASE_FLDHDR_SZ *
-                                  psDBF->nFields));
+    panFieldOffsetNew = STATIC_CAST(int *, calloc(psDBF->nFields, sizeof(int)));
+    panFieldSizeNew = STATIC_CAST(int *, calloc(psDBF->nFields, sizeof(int)));
+    panFieldDecimalsNew = STATIC_CAST(int *, calloc(psDBF->nFields, sizeof(int)));
+    pachFieldTypeNew = STATIC_CAST(char *, calloc(psDBF->nFields, sizeof(char)));
+    pszHeaderNew = STATIC_CAST(char*, malloc(sizeof(char) * XBASE_FLDHDR_SZ * psDBF->nFields));
     if( panFieldOffsetNew == SHPLIB_NULLPTR || panFieldSizeNew == SHPLIB_NULLPTR ||
         panFieldDecimalsNew == SHPLIB_NULLPTR || pachFieldTypeNew == SHPLIB_NULLPTR ||
diff --git a/loader/shpopen.c b/loader/shpopen.c
index 3fe86874d..903e8a3c2 100644
--- a/loader/shpopen.c
+++ b/loader/shpopen.c
@@ -366,7 +366,7 @@ SHPOpenLL( const char * pszLayer, const char * pszAccess, SAHooks *psHooks )
 /*  Initialize the info structure.                  */
-    psSHP = STATIC_CAST(SHPHandle, calloc(sizeof(SHPInfo),1));
+    psSHP = STATIC_CAST(SHPHandle, calloc(1,sizeof(SHPInfo)));
     if( psSHP == SHPLIB_NULLPTR )
         return SHPLIB_NULLPTR;
@@ -1259,7 +1259,7 @@ SHPCreateObject( int nSHPType, int nShapeId, int nParts,
         psObject->nParts = MAX(1,nParts);
         psObject->panPartStart = STATIC_CAST(int *,
-            calloc(sizeof(int), psObject->nParts));
+            calloc(psObject->nParts, sizeof(int)));
         psObject->panPartType = STATIC_CAST(int *,
             malloc(sizeof(int) * psObject->nParts));
@@ -1288,13 +1288,13 @@ SHPCreateObject( int nSHPType, int nShapeId, int nParts,
         size_t nSize = sizeof(double) * nVertices;
         psObject->padfX = STATIC_CAST(double *, padfX ? malloc(nSize) :
-                                             calloc(sizeof(double),nVertices));
+                                             calloc(nVertices, sizeof(double)));
         psObject->padfY = STATIC_CAST(double *, padfY ? malloc(nSize) :
         psObject->padfZ = STATIC_CAST(double *, padfZ && bHasZ ? malloc(nSize) :
         psObject->padfM = STATIC_CAST(double *, padfM && bHasM ? malloc(nSize) :
         if( padfX != SHPLIB_NULLPTR )
             memcpy(psObject->padfX, padfX, nSize);
         if( padfY != SHPLIB_NULLPTR )
commit fba69e60f1fc636564afe16b6942a84f9c755a22
Date:   Wed Oct 1 14:04:33 2025 -0700
    Compilation failure in CI, uninit variable nsolids
diff --git a/liblwgeom/lwgeom_sfcgal.c b/liblwgeom/lwgeom_sfcgal.c
index 433c01a51..8aaa9445b 100644
--- a/liblwgeom/lwgeom_sfcgal.c
+++ b/liblwgeom/lwgeom_sfcgal.c
@@ -322,7 +322,7 @@ ptarray_to_SFCGAL(const POINTARRAY *pa, int type)
 LWGEOM *
 SFCGAL2LWGEOM(const sfcgal_geometry_t *geom, int force3D, int32_t srid)
-	uint32_t ngeoms, nshells, nsolids;
+	uint32_t ngeoms = 0, nshells = 0, nsolids = 0;
 	uint32_t i, j, k;
 	int want3d;
Summary of changes:
 liblwgeom/lwgeom_sfcgal.c |  2 +-
 loader/dbfopen.c          | 11 +++++------
 loader/shpopen.c          | 12 ++++++------
 3 files changed, 12 insertions(+), 13 deletions(-)
hooks/post-receive
