[SCM] PostGIS branch stable-3.5 updated. 3.5.3-59-ge612c0ad8
Thu Oct 2 09:46:28 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  e612c0ad859742b6bf0bd8af0567a577419adbfa (commit)
      from  fad381ea7594ac2162ee82e6bcb58dd82e1cf6d0 (commit)
revisions in full, below.
commit e612c0ad859742b6bf0bd8af0567a577419adbfa
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Oct 2 09:46:21 2025 -0700
    Remove Cirrus-CI as constant source of CI failure due to Cirrus resource limits
diff --git a/.cirrus.yml b/.cirrus.yml
deleted file mode 100644
index c2490f510..000000000
--- a/.cirrus.yml
+++ /dev/null
@@ -1,95 +0,0 @@
-task:
-  only_if: $CIRRUS_BRANCH =~ 'pull/.*'
-  name: FreeBSD
-  alias: test-freebsd
-  #env:
-    #MAKE_FLAGS: -j 8
-  install_script:
-    - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
-    - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
-    - pkg install -y
-        autoconf
-        automake
-        bison
-        cunit
-        docbook
-        gdal
-        geos
-        gmake
-        iconv
-        json-c
-        libtool
-        libxml2
-        libxslt
-        pcre
-        pkgconf
-        postgresql13-contrib
-        postgresql13-server
-        proj
-        protobuf-c
-        sfcgal
-    - projsync --system-directory --source-id us_noaa
-    - projsync --system-directory --source-id ch_swisstopo
-  patch_script:
-    # will be removed
-    - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
-  build_script:
-    - ./autogen.sh
-    - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster  --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
-    - service postgresql oneinitdb
-    - service postgresql onestart
-    - su postgres -c "createuser -s `whoami`"
-    - gmake || { service postgresql onestop; exit 1;}
-    - gmake check RUNTESTFLAGS="-v" || { service postgresql onestop; exit 1;}
-    - gmake install || { service postgresql onestop; exit 1;}
-    - gmake check RUNTESTFLAGS="-v --extension" || { service postgresql onestop; exit 1;}
-    - gmake check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1;}
-    - service postgresql onestop
-  freebsd_instance:
-    cpu: 8
-    memory: 24g
-  matrix:
-    # - name: 14-CURRENT
-    #   freebsd_instance:
-    #     image_family: freebsd-14-0-snap
-    - name: 13.2-RELEASE
-      freebsd_instance:
-        image_family: freebsd-13-2
-task:
-  name: macOS
-  alias: test-macos
-  test_script:
-    - brew update
-    - brew install
-        autoconf
-        automake
-        cunit
-        docbook
-        docbook-xsl
-        gdal
-        geos
-        gpp
-        json-c
-        libtool
-        pcre2
-        pkg-config
-        postgresql at 14
-        proj
-        sfcgal
-    - ./autogen.sh
-    - ./configure --without-gui --without-interrupt-tests --without-topology --without-raster  --with-sfcgal --with-address-standardizer --without-protobuf --with-pgconfig=/opt/homebrew/opt/postgresql at 14/bin/pg_config
-    - brew services start postgresql at 14
-    - postgres -V
-    - make -j8 || { brew services stop postgresql at 14; exit 1;}
-    - make -j8 check || { brew services stop postgresql at 14; exit 1;}
-    - brew services stop postgresql at 14
-  matrix:
-    macos_instance:
-      image: ghcr.io/cirruslabs/macos-ventura-base:latest
-  #  macos_instance:
-  #    image: ghcr.io/cirruslabs/macos-monterey-base:latest
Summary of changes:
 .cirrus.yml | 95 -------------------------------------------------------------
 1 file changed, 95 deletions(-)
 delete mode 100644 .cirrus.yml
hooks/post-receive
