[PostGIS] #5989: ST_Distance error on CurvePolygon
PostGIS trac at osgeo.org
Thu Oct 2 14:10:43 PDT 2025
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.5.4
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"ae2d86d16b3ebf9f69baf1429fe4be6ab1bcf1cf/git" ae2d86d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ae2d86d16b3ebf9f69baf1429fe4be6ab1bcf1cf"
 Fix arc/arc distance to handle more cases such as contained,
 circular, and other interesting arc/arc alignments that come up rarely
 in ordinary GIS data.
 Fix compoundcurve distance calculations, in particular the
 containment test, which was failing for some cases.
 Replaced containment test with a ray casting algorithm
 that makes more sense for circularstrings that the
 winding order algorithm did.
 References #5989
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5989#comment:11>
