[SCM] PostGIS branch master updated. 3.6.0rc2-83-g389eaee28
Mon Oct 6 12:49:27 PDT 2025
the project "PostGIS".
       via  389eaee2863b5b1d06a33670621f98bf56438680 (commit)
      from  ac17b1d6a6364a81ad7a124b2f9ae257bda51e91 (commit)
revisions in full, below.
commit 389eaee2863b5b1d06a33670621f98bf56438680
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Oct 6 12:49:11 2025 -0700
    Make PostGIS and GEOS consistent in handling clipping at the border of the rectangle (both now clip boundary vertices)
    References #5962
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 16ee36e89..339214f0d 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -1546,8 +1546,9 @@ Datum ST_ClipByBox2d(PG_FUNCTION_ARGS)
 	bbox2 = (GBOX *)PG_GETARG_POINTER(box2d_idx);
 	bbox2->flags = 0;
-	/* if bbox1 is covered by bbox2, return lwgeom1 */
-	if (gbox_contains_2d(bbox2, &bbox1))
+	/* If bbox1 is strictly contained by bbox2, return input geometry */
+	if (bbox2->xmin < bbox1.xmin && bbox2->xmax > bbox1.xmax &&
+	    bbox2->ymin < bbox1.ymin && bbox2->ymax > bbox1.ymax)
 		PG_RETURN_DATUM(PG_GETARG_DATUM(geom_idx));
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 46490a912..4b580b003 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1613,3 +1613,13 @@ CREATE TABLE test5987 (geom geometry(Geometry,4326));
 INSERT INTO test5987 VALUES('LINESTRING(20 20,20.1 20,20.2 19.9)'::geometry);
 SELECT '#5987', ST_AsText(geom), ST_AsText(ST_GeometryN(geom, 1)) FROM test5987;
 DROP TABLE IF EXISTS test5987;
+-- #5962
+SELECT '#5962',
+    ST_AsText(ST_ClipByBox2D(
+        ST_GeomFromText('MULTIPOINT((1 1),(3 4),(5 4))'),
+        ST_MakeEnvelope(0, 0, 5, 5)), 2),
+        ST_GeomFromText('MULTIPOINT((1 1),(6 4),(5 4))'),
+        ST_MakeEnvelope(0, 0, 5, 5 )), 2);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index dd5538e62..0f2bf2f39 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -491,3 +491,4 @@ public|test5829|geom|2|4326|GEOMETRY
 public|test5978|geometry|2|4326|POINT
 public|test5978|shape|2|4326|POINT
 #5987|LINESTRING(20 20,20.1 20,20.2 19.9)|LINESTRING(20 20,20.1 20,20.2 19.9)
+#5962|MULTIPOINT((1 1),(3 4))|POINT(1 1)
Summary of changes:
 postgis/lwgeom_geos.c         |  5 +++--
 regress/core/tickets.sql      | 10 ++++++++++
 regress/core/tickets_expected |  1 +
 3 files changed, 14 insertions(+), 2 deletions(-)
hooks/post-receive
