[SCM] PostGIS branch master updated. 3.6.0rc2-85-g419aa9519
git at osgeo.org
git at osgeo.org
Mon Oct 6 14:37:40 PDT 2025
the project "PostGIS".
via 419aa9519f970de44b1bd1ed770f5932f53c0c36 (commit)
from 489825052c458022fe8fe3b698e7d812461688fc (commit)
revisions in full, below.
commit 419aa9519f970de44b1bd1ed770f5932f53c0c36
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Oct 6 14:37:27 2025 -0700
Fix raycast for linestrings, references #5989
diff --git a/liblwgeom/cunit/cu_measures.c b/liblwgeom/cunit/cu_measures.c
index 58e7cb4ba..c95bf21e1 100644
--- a/liblwgeom/cunit/cu_measures.c
+++ b/liblwgeom/cunit/cu_measures.c
@@ -89,6 +89,14 @@ static void test_mindistance2d_tolerance(void)
double zero_accepted_error = 0.0;
+ * CurvePolygon and Point, #5989
+ DIST2DTEST(
+ "CURVEPOLYGON(COMPOUNDCURVE((129296 142584,94722 100435,91618 97138,57306 60686,26874 28357,13059 34228,14572 65506,14593 65948,14616 66389),CIRCULARSTRING(14616 66389,17955 101124,24417 135415,24655 136418,24895 137421),(24895 137421,25472 139809,19354 141285,0 0,148000 142000,129296 142584)))",
+ "POINT(19925 112376)",
+ 199.655, 0.001);
** Simple case.
diff --git a/liblwgeom/lwalgorithm.c b/liblwgeom/lwalgorithm.c
index a2cb2b037..5cb90a04c 100644
--- a/liblwgeom/lwalgorithm.c
+++ b/liblwgeom/lwalgorithm.c
@@ -107,25 +107,11 @@ lw_pt_in_seg(const POINT2D *P, const POINT2D *A1, const POINT2D *A2)
int
-lw_pt_on_segment(const POINT2D* p1, const POINT2D* p2, const POINT2D* p)
+lw_pt_on_segment(const POINT2D* A1, const POINT2D* A2, const POINT2D* P)
- // Check if the point is within the bounding box of the segment
- if (p->x < FP_MIN(p1->x, p2->x) || p->x > FP_MAX(p1->x, p2->x) ||
- p->y < FP_MIN(p1->y, p2->y) || p->y > FP_MAX(p1->y, p2->y))
- return LW_FALSE;
- // Check for collinearity using the 2D cross-product.
- // (p.y - p1.y) * (p2.x - p1.x) - (p.x - p1.x) * (p2.y - p1.y)
- double cross_product = (p->y - p1->y) * (p2->x - p1->x) - (p->x - p1->x) * (p2->y - p1->y);
- if (fabs(cross_product) < DBL_EPSILON)
- return LW_TRUE; // Point is collinear and within the bounding box
- return LW_TRUE;
+ int side = lw_segment_side(A1, A2, P);
+ if (side != 0) return LW_FALSE;
+ return lw_pt_in_seg(P, A1, A2);
Summary of changes:
liblwgeom/cunit/cu_measures.c | 8 ++++++++
liblwgeom/lwalgorithm.c | 22 ++++------------------
2 files changed, 12 insertions(+), 18 deletions(-)
hooks/post-receive
