[PostGIS] #5989: ST_Distance error on CurvePolygon
trac at osgeo.org
Tue Oct 7 12:29:31 PDT 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"9979912be010137e0cee0b111e68eec938d516ca/git" 9979912/git]:
{{{#!CommitTicketReference repository="git"
revision="9979912be010137e0cee0b111e68eec938d516ca"
Fix arc/arc distance to handle more cases such as contained,
circular, and other interesting arc/arc alignments that come up rarely
in ordinary GIS data.
Fix compoundcurve distance calculations, in particular the
containment test, which was failing for some cases.
Replaced containment test with a ray casting algorithm
that makes more sense for circularstrings that the
winding order algorithm did.
References #5989
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5989#comment:21>
