[SCM] PostGIS branch master updated. 3.6.0rc2-120-g56c2cc850
git at osgeo.org
git at osgeo.org
Tue Oct 7 12:33:14 PDT 2025
the project "PostGIS".
via 56c2cc85083f125e9d5f623b9de1b20370d558ef (commit)
from c0bc117e91fd015468fd37975c42f382070b52f4 (commit)
revisions in full, below.
commit 56c2cc85083f125e9d5f623b9de1b20370d558ef
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Oct 7 12:33:07 2025 -0700
Clarify single sided buffering a little. From Peter Nguyen
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 8144058a4..80c16af3f 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -85,8 +85,8 @@ providing a list of blank-separated key=value pairs as follows:
<para>'mitre_limit=#.#' : mitre ratio limit (only affects mitered join style). 'miter_limit' is accepted as a synonym for 'mitre_limit'.</para>
</listitem>
<listitem>
-<para>'side=both|left|right' : 'left' or 'right' performs a single-sided buffer on the geometry, with the buffered side relative to the direction of the line.
-This is only applicable to LINESTRING geometry and does not affect POINT or POLYGON geometries. By default end caps are square.</para>
+<para>'side=both|left|right' : defaults to 'both'. 'left' or 'right' performs a single-sided buffer on the geometry, with the buffered side relative to the direction of the line.
+This is only applicable to LINESTRING geometry and does not affect POINT or POLYGON geometries. By default end caps are square when 'left' or 'right' are specified.</para>
</listitem>
</itemizedlist>
</para>
Summary of changes:
doc/reference_processing.xml | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
