[SCM] PostGIS branch master updated. 3.6.0rc2-125-g747d7732b
git at osgeo.org
git at osgeo.org
Wed Oct 8 08:51:20 PDT 2025
the project "PostGIS".
via 747d7732b009ee6821501f290a3f729e56a9634d (commit)
from 598acb6241df31b6f77f115b7af796e1226424ab (commit)
revisions in full, below.
commit 747d7732b009ee6821501f290a3f729e56a9634d
Author: Regina Obe <lr at pcorp.us>
Date: Wed Oct 8 11:50:27 2025 -0400
Winnie try to fix path issue in binary regress
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 229a16ed1..5a86e8db9 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -39,10 +39,10 @@ echo PATH AFTER: $PATH
echo WORKSPACE IS $WORKSPACE
#mkdir ${PROJECTS}/postgis/tmp
-export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
-rm -rf ${PGIS_REG_TMPDIR}
-mkdir ${PGIS_REG_TMPDIR}
-export TMPDIR=${PGIS_REG_TMPDIR}
+#export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
+#rm -rf ${PGIS_REG_TMPDIR}
+#mkdir ${PGIS_REG_TMPDIR}
+#export TMPDIR=${PGIS_REG_TMPDIR}
#TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_VER}_${PG_VER}_${GEOS_VERSION}_${PROJ_VER}
@@ -99,7 +99,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
#patch liblwgeom generated make to get rid of dynamic linking
#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-make -j 4
+make -j 2
make install
# don't run tests twice. Only run regular if extension test is not asked for
Summary of changes:
ci/winnie/regress_postgis.sh | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
