[SCM] PostGIS branch stable-3.2 updated. 3.2.7-56-g6e2102f01
git at osgeo.org
git at osgeo.org
Wed Oct 8 14:20:46 PDT 2025
the project "PostGIS".
The branch, stable-3.2 has been updated
via 6e2102f01c0f9019c53ba5ca7a975834805326e5 (commit)
from dd98c6f88026cf6f2504bfc2afb88bbd02b530fd (commit)
revisions in full, below.
commit 6e2102f01c0f9019c53ba5ca7a975834805326e5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Oct 8 14:17:23 2025 -0700
Avoid possible null pointer dereference. Closes #6000
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 192aa3c69..2fd00f944 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -273,6 +273,22 @@ lw_dist2d_is_collection(const LWGEOM *g)
+/* Check for overlapping bboxes */
+static int
+lw_dist2d_check_overlap(const LWGEOM *lwg1, const LWGEOM *lwg2)
+ assert(lwg1 && lwg2 && lwg1->bbox && lwg2->bbox);
+ /* Check if the geometries intersect. */
+ if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
+ lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
+ return LW_FALSE;
+ return LW_TRUE;
This is a recursive function delivering every possible combination of subgeometries
@@ -310,6 +326,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
else
g1 = (LWGEOM *)lwg1;
+ if (!g1) continue;
if (lwgeom_is_empty(g1))
continue;
@@ -327,6 +345,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
else
g2 = (LWGEOM *)lwg2;
+ if (!g2) continue;
if (lw_dist2d_is_collection(g2))
LWDEBUG(3, "Found collection inside second geometry collection, recursing");
@@ -524,26 +544,6 @@ lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS
return LW_FALSE;
-/* Check for overlapping bboxes */
-int
-lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2)
- LWDEBUG(2, "lw_dist2d_check_overlap is called");
- if (!lwg1->bbox)
- lwgeom_calculate_gbox(lwg1, lwg1->bbox);
- if (!lwg2->bbox)
- lwgeom_calculate_gbox(lwg2, lwg2->bbox);
- /* Check if the geometries intersect. */
- if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
- lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
- LWDEBUG(3, "geometries bboxes did not overlap");
- return LW_FALSE;
- LWDEBUG(3, "geometries bboxes overlap");
- return LW_TRUE;
/** Geometries are distributed for the new faster distance-calculations */
int
diff --git a/liblwgeom/measures.h b/liblwgeom/measures.h
index 9cf0fb958..fc3f34bfe 100644
--- a/liblwgeom/measures.h
+++ b/liblwgeom/measures.h
@@ -69,7 +69,6 @@ typedef struct
int lw_dist2d_comp(const LWGEOM *lw1, const LWGEOM *lw2, DISTPTS *dl);
int lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
int lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
-int lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2);
int lw_dist2d_distribute_fast(LWGEOM *lwg1, LWGEOM *lwg2, DISTPTS *dl);
Summary of changes:
liblwgeom/measures.c | 40 ++++++++++++++++++++--------------------
liblwgeom/measures.h | 1 -
2 files changed, 20 insertions(+), 21 deletions(-)
hooks/post-receive
