[SCM] PostGIS branch stable-3.0 updated. 3.0.11-20-g58ef17e4f
git at osgeo.org
git at osgeo.org
Wed Oct 8 14:21:03 PDT 2025
the project "PostGIS".
The branch, stable-3.0 has been updated
via 58ef17e4fc45651f8b3e92ea9cefc34942f35e71 (commit)
from 98992aa72c3358aff5fc6ee4f30984c8f2a289e4 (commit)
revisions in full, below.
commit 58ef17e4fc45651f8b3e92ea9cefc34942f35e71
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Oct 8 14:17:23 2025 -0700
Avoid possible null pointer dereference. Closes #6000
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index ac2ddac46..eb95ef750 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -261,6 +261,22 @@ lw_dist2d_is_collection(const LWGEOM *g)
+/* Check for overlapping bboxes */
+static int
+lw_dist2d_check_overlap(const LWGEOM *lwg1, const LWGEOM *lwg2)
+ assert(lwg1 && lwg2 && lwg1->bbox && lwg2->bbox);
+ /* Check if the geometries intersect. */
+ if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
+ lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
+ return LW_FALSE;
+ return LW_TRUE;
This is a recursive function delivering every possible combination of subgeometries
@@ -298,6 +314,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
else
g1 = (LWGEOM *)lwg1;
+ if (!g1) continue;
if (lwgeom_is_empty(g1))
continue;
@@ -315,6 +333,8 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
else
g2 = (LWGEOM *)lwg2;
+ if (!g2) continue;
if (lw_dist2d_is_collection(g2))
LWDEBUG(3, "Found collection inside second geometry collection, recursing");
@@ -512,26 +532,6 @@ lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS
return LW_FALSE;
-/* Check for overlapping bboxes */
-int
-lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2)
- LWDEBUG(2, "lw_dist2d_check_overlap is called");
- if (!lwg1->bbox)
- lwgeom_calculate_gbox(lwg1, lwg1->bbox);
- if (!lwg2->bbox)
- lwgeom_calculate_gbox(lwg2, lwg2->bbox);
- /* Check if the geometries intersect. */
- if ((lwg1->bbox->xmax < lwg2->bbox->xmin || lwg1->bbox->xmin > lwg2->bbox->xmax ||
- lwg1->bbox->ymax < lwg2->bbox->ymin || lwg1->bbox->ymin > lwg2->bbox->ymax))
- LWDEBUG(3, "geometries bboxes did not overlap");
- return LW_FALSE;
- LWDEBUG(3, "geometries bboxes overlap");
- return LW_TRUE;
/** Geometries are distributed for the new faster distance-calculations */
int
diff --git a/liblwgeom/measures.h b/liblwgeom/measures.h
index 9cf0fb958..fc3f34bfe 100644
--- a/liblwgeom/measures.h
+++ b/liblwgeom/measures.h
@@ -69,7 +69,6 @@ typedef struct
int lw_dist2d_comp(const LWGEOM *lw1, const LWGEOM *lw2, DISTPTS *dl);
int lw_dist2d_distribute_bruteforce(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
int lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl);
-int lw_dist2d_check_overlap(LWGEOM *lwg1, LWGEOM *lwg2);
int lw_dist2d_distribute_fast(LWGEOM *lwg1, LWGEOM *lwg2, DISTPTS *dl);
Summary of changes:
liblwgeom/measures.c | 40 ++++++++++++++++++++--------------------
liblwgeom/measures.h | 1 -
2 files changed, 20 insertions(+), 21 deletions(-)
hooks/post-receive
