[PostGIS] #3651: ST_Orientation crashes the backend
trac at osgeo.org
Wed Oct 8 22:02:23 PDT 2025
Reporter: postgispaul | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: high | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 2.3.x
Resolution: | Keywords: windows
Changes (by robe):
* owner: robe => Loïc Bartoletti
Comment:
Just retested crash.sql using sfcgal 2.2.0 compiled with msys2/mingw64 gcc
13.2 and still crashes.
PostgreSQL 18.0 on x86_64-windows, compiled by msvc-19.44.35215, 64-bit
POSTGIS="3.6.0 3.6.0" [EXTENSION] PGSQL="180" GEOS="3.14.0-CAPI-1.20.4"
SFCGAL="SFCGAL 2.2.0, CGAL 6.0.1, BOOST 1.88.0" PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
DATABASE_PATH=C:\ming64\projects\proj\rel-
proj-8.2.1w64/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
(Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3651#comment:26>
