[SCM] PostGIS branch stable-3.6 updated. 3.6.0-23-gaca123684
Thu Oct 9 08:52:37 PDT 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  aca123684d92189659756a00d93a97398447f229 (commit)
       via  abd2fda84e22c81d8279b6e25dabd8e3f76db32e (commit)
       via  ad0444b02c4ca00a388d1be03305571b71c5563e (commit)
      from  e5cc9ae7a1806acc8d18b0ee4f4ee7d4b9e29c7c (commit)
revisions in full, below.
commit aca123684d92189659756a00d93a97398447f229
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Oct 9 11:52:29 2025 -0400
    Add credits. References #5998 for PostGIS 3.6.1
diff --git a/NEWS b/NEWS
index f60416789..476d10cfe 100644
--- a/NEWS
+++ b/NEWS
@@ -5,11 +5,14 @@ PostGIS 3.6.1
 * Fixes *
   - #5978, geometry_columns needs to still parse table constraints (Paul Ramsey)
-  - #5987, ST_GeometryN fails for non-collections (Paul Ramsey)
+  - #5987, ST_GeometryN fails for non-collections (Paul Ramsey)
   - #5991, CircularString distance error (Paul Ramsey)
   - #5994, Null pointer in ST_AsGeoJsonRow (Alexander Kukushkin)
   - #5998, ST_Distance error on CurvePolygon (Paul Ramsey)
   - #5962, Consistent clipping of MULTI/POINT (Paul Ramsey)
+  - #5998, [tiger_geocoder] [security] CVE-2022-2625, make sure tables requires
+              by extension are owned by extension
+              authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)
 PostGIS 3.6.0
commit abd2fda84e22c81d8279b6e25dabd8e3f76db32e
Date:   Tue Oct 7 18:27:17 2025 -0400
    TIGER EXTENSION SECURITY fix
     - Ensure tables are created by tiger extension and bale if not.
       Patch provided by Andrey Borodin (Yandex)
     - Don't create tiger_data as that gets created on first load of data
       and shouldn't be part of the extension
diff --git a/extras/tiger_geocoder/geocode_settings.sql b/extras/tiger_geocoder/geocode_settings.sql
index e126f825b..e5c09b8c2 100644
--- a/extras/tiger_geocoder/geocode_settings.sql
+++ b/extras/tiger_geocoder/geocode_settings.sql
@@ -22,10 +22,16 @@ BEGIN
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'geocode_settings')  THEN
 		CREATE TABLE geocode_settings(name text primary key, setting text, unit text, category text, short_desc text);
 		GRANT SELECT ON geocode_settings TO public;
+	ELSE
+		-- Insist on invoking Postgres logic of owning table by extension. This prevent attacks like CVE-2022-2625.
+		CREATE TABLE IF NOT EXISTS geocode_settings(name text primary key, setting text, unit text, category text, short_desc text);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'geocode_settings_default')  THEN
 		CREATE TABLE geocode_settings_default(name text primary key, setting text, unit text, category text, short_desc text);
 		GRANT SELECT ON geocode_settings_default TO public;
+	ELSE
+		-- Same as above.
+		CREATE TABLE IF NOT EXISTS geocode_settings_default(name text primary key, setting text, unit text, category text, short_desc text);
 	END IF;
 	--recreate defaults
 	TRUNCATE TABLE geocode_settings_default;
diff --git a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
index ff78fc8f8..da6fc91a9 100644
--- a/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
+++ b/extras/tiger_geocoder/pagc_normalize/pagc_tables.sql
@@ -11,14 +11,23 @@ BEGIN
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz')  THEN
 		CREATE TABLE pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
 		GRANT SELECT ON pagc_gaz TO public;
+	ELSE
+		CREATE TABLE IF NOT EXISTS pagc_gaz (id serial NOT NULL primary key ,seq integer ,word text, stdword text, token integer,is_custom boolean NOT NULL default true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_lex')  THEN
 		CREATE TABLE pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
 		GRANT SELECT ON pagc_lex TO public;
+	ELSE
+		-- Same as above.
+		CREATE TABLE IF NOT EXISTS pagc_lex (id serial NOT NULL primary key,seq integer,word text,stdword text,token integer,is_custom boolean NOT NULL default true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_rules')  THEN
 		CREATE TABLE pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
 		GRANT SELECT ON pagc_rules TO public;
+	ELSE
+		-- Same as above.
+		CREATE TABLE IF NOT EXISTS pagc_rules (id serial NOT NULL primary key,rule text, is_custom boolean DEFAULT true);
 	END IF;
 	IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND table_name = 'pagc_gaz' AND data_type='text')  THEN
 	-- its probably old table structure change type of lex and gaz columns
diff --git a/extras/tiger_geocoder/tiger_loader_2012.sql b/extras/tiger_geocoder/tiger_loader_2012.sql
index c4d6da1b7..00593ecf5 100644
--- a/extras/tiger_geocoder/tiger_loader_2012.sql
+++ b/extras/tiger_geocoder/tiger_loader_2012.sql
@@ -57,18 +57,14 @@ $$
 DO
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_platform' AND table_schema = 'tiger') THEN
-      CREATE TABLE loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
-  END IF;
+   CREATE TABLE IF NOT EXISTS loader_platform(os varchar(50) PRIMARY KEY, declare_sect text, pgbin text, wget text, unzip_command text, psql text, path_sep text, loader text, environ_set_command text, county_process_command text);
 END
 $$ LANGUAGE 'plpgsql';
 DO
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE schema_name = 'tiger_data') THEN
-       CREATE SCHEMA tiger_data;
-  END IF;
+    CREATE SCHEMA IF NOT EXISTS tiger_data;
 END
@@ -125,9 +121,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_variables' AND table_schema = 'tiger') THEN
-      CREATE TABLE loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
-  END IF;
+    CREATE TABLE IF NOT EXISTS loader_variables(tiger_year varchar(4) PRIMARY KEY, website_root text, staging_fold text, data_schema text, staging_schema text);
 END
@@ -138,8 +132,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
-  IF NOT EXISTS (SELECT * FROM information_schema.tables WHERE table_name = 'loader_lookuptables' AND table_schema = 'tiger') THEN
-   CREATE TABLE loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
+   CREATE TABLE IF NOT EXISTS loader_lookuptables(process_order integer NOT NULL DEFAULT 1000,
 		lookup_name text primary key,
 		table_name text, single_mode boolean NOT NULL DEFAULT true,
 		load boolean NOT NULL DEFAULT true,
@@ -149,7 +142,6 @@ BEGIN
 		post_load_process text, single_geom_mode boolean DEFAULT false,
 		insert_mode char(1) NOT NULL DEFAULT 'c',
 		pre_load_process text,columns_exclude text[], website_root_override text);
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2013.sql b/extras/tiger_geocoder/tiger_loader_2013.sql
index d42f60ea2..8b6e0d166 100644
--- a/extras/tiger_geocoder/tiger_loader_2013.sql
+++ b/extras/tiger_geocoder/tiger_loader_2013.sql
@@ -56,18 +56,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -124,9 +120,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -137,8 +131,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -148,7 +141,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2014.sql b/extras/tiger_geocoder/tiger_loader_2014.sql
index bedb84051..8726e5afe 100644
--- a/extras/tiger_geocoder/tiger_loader_2014.sql
+++ b/extras/tiger_geocoder/tiger_loader_2014.sql
@@ -89,6 +89,72 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
 	  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
 	COMMENT ON TABLE tiger.bg IS 'block groups';
+ELSE
+	CREATE TABLE IF NOT EXISTS tract
+	  gid serial NOT NULL,
+	  statefp varchar(2),
+	  countyfp varchar(3),
+	  tractce varchar(6),
+	  tract_id varchar(11) PRIMARY KEY,
+	  name varchar(7),
+	  namelsad varchar(20),
+	  mtfcc varchar(5),
+	  funcstat varchar(1),
+	  aland double precision,
+	  awater double precision,
+	  intptlat varchar(11),
+	  intptlon varchar(12),
+	  the_geom geometry,
+	  CONSTRAINT enforce_dims_geom CHECK (st_ndims(the_geom) = 2),
+	  CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
+	  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
+	CREATE TABLE IF NOT EXISTS tabblock
+	  blockce varchar(4),
+	  tabblock_id varchar(16) PRIMARY KEY,
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	CREATE TABLE IF NOT EXISTS bg
+	  blkgrpce varchar(1),
+	  bg_id varchar(12) PRIMARY KEY,
+	  namelsad varchar(13),
+	  mtfcc varchar(5),
 END IF;
 IF EXISTS(SELECT * FROM information_schema.columns WHERE table_schema = 'tiger' AND column_name = 'tabblock_id' AND table_name = 'tabblock' AND character_maximum_length < 16)  THEN -- size of name and tabblock_id fields need to be increased
@@ -144,18 +210,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -212,9 +274,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -225,8 +285,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -236,7 +295,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2015.sql b/extras/tiger_geocoder/tiger_loader_2015.sql
index fe0bdf62f..3311be2e7 100644
--- a/extras/tiger_geocoder/tiger_loader_2015.sql
+++ b/extras/tiger_geocoder/tiger_loader_2015.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2016.sql b/extras/tiger_geocoder/tiger_loader_2016.sql
index 0cb93e442..39dd37f0a 100644
--- a/extras/tiger_geocoder/tiger_loader_2016.sql
+++ b/extras/tiger_geocoder/tiger_loader_2016.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -211,9 +273,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -224,8 +284,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -235,7 +294,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2017.sql b/extras/tiger_geocoder/tiger_loader_2017.sql
index 9a7c6a726..5644a4d53 100644
--- a/extras/tiger_geocoder/tiger_loader_2017.sql
+++ b/extras/tiger_geocoder/tiger_loader_2017.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2018.sql b/extras/tiger_geocoder/tiger_loader_2018.sql
index 61e68797a..33697e785 100644
--- a/extras/tiger_geocoder/tiger_loader_2018.sql
+++ b/extras/tiger_geocoder/tiger_loader_2018.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2019.sql b/extras/tiger_geocoder/tiger_loader_2019.sql
index 12a395b60..9485011cf 100644
--- a/extras/tiger_geocoder/tiger_loader_2019.sql
+++ b/extras/tiger_geocoder/tiger_loader_2019.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2020.sql b/extras/tiger_geocoder/tiger_loader_2020.sql
index 6afce151a..01c81f26a 100644
--- a/extras/tiger_geocoder/tiger_loader_2020.sql
+++ b/extras/tiger_geocoder/tiger_loader_2020.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
@@ -165,18 +231,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -232,9 +294,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -245,8 +305,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -256,7 +315,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2021.sql b/extras/tiger_geocoder/tiger_loader_2021.sql
index 0cdd7ee5a..675bff9cd 100644
--- a/extras/tiger_geocoder/tiger_loader_2021.sql
+++ b/extras/tiger_geocoder/tiger_loader_2021.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
@@ -172,18 +238,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -239,9 +301,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -252,8 +312,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -263,7 +322,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2022.sql b/extras/tiger_geocoder/tiger_loader_2022.sql
index af4b9ee25..991ce2255 100644
--- a/extras/tiger_geocoder/tiger_loader_2022.sql
+++ b/extras/tiger_geocoder/tiger_loader_2022.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
@@ -175,18 +241,14 @@ $$
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
@@ -242,9 +304,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -255,8 +315,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -266,7 +325,6 @@ BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2023.sql b/extras/tiger_geocoder/tiger_loader_2023.sql
index 691176236..65c497ce2 100644
--- a/extras/tiger_geocoder/tiger_loader_2023.sql
+++ b/extras/tiger_geocoder/tiger_loader_2023.sql
+ELSE
+	  name varchar(7),
+	  mtfcc varchar(5),
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	  mtfcc varchar(5),
 END IF;
 DO
 BEGIN
-  END IF;
 END
 DO
 BEGIN
-  END IF;
 END
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
 DO $$
 BEGIN
-  END IF;
 END
diff --git a/extras/tiger_geocoder/tiger_loader_2024.sql b/extras/tiger_geocoder/tiger_loader_2024.sql
index f6d7f0b85..75db83e0f 100644
--- a/extras/tiger_geocoder/tiger_loader_2024.sql
+++ b/extras/tiger_geocoder/tiger_loader_2024.sql
+ELSE
+	CREATE TABLE IF NOT EXISTS tiger.tract
+	  name varchar(7),
+	  mtfcc varchar(5),
+	CREATE TABLE IF NOT EXISTS tiger.tabblock
+	  name varchar(20),
+	  mtfcc varchar(5),
+	  ur varchar(1),
+	  uace varchar(5),
+	CREATE TABLE IF NOT EXISTS tiger.bg
+	  mtfcc varchar(5),
 END IF;
@@ -175,18 +241,7 @@ $$
 DO
 BEGIN
-  END IF;
-END
-$$ LANGUAGE 'plpgsql';
-DO
-BEGIN
-  END IF;
 END
@@ -242,9 +297,7 @@ done');
 -- variables table
 DO $$
 BEGIN
-  END IF;
 END
@@ -255,8 +308,7 @@ GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
 BEGIN
@@ -266,7 +318,6 @@ BEGIN
-  END IF;
 END
commit ad0444b02c4ca00a388d1be03305571b71c5563e
Date:   Thu Oct 9 11:39:48 2025 -0400
    Cleanup winnie ci building
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index bb4f1fc4c..bcaa2435e 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -12,7 +12,7 @@ DWN=${WEB}/download
 #export PG_VER=9.2beta2
 if [ -n "$SOURCE_FOLDER" ]; then
-  export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
+  	export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
 	cd $POSTGIS_SRC
 fi
@@ -55,7 +55,7 @@ cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libstdc++-6.dll $outdir/bi
 cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libgcc*.dll $outdir/bin
 # don't package postgisgui if we don't have gtk2
-if [ -n "${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}" ]; then
+if [ -d "${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}" ]; then
 	mkdir $outdir/bin/postgisgui
 	mkdir $outdir/bin/postgisgui/share
 	mkdir $outdir/bin/postgisgui/lib
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 10aa48c0e..5a86e8db9 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -39,10 +39,10 @@ echo PATH AFTER: $PATH
 echo WORKSPACE IS $WORKSPACE
 #mkdir ${PROJECTS}/postgis/tmp
-export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
-rm -rf ${PGIS_REG_TMPDIR}
-mkdir ${PGIS_REG_TMPDIR}
-export TMPDIR=${PGIS_REG_TMPDIR}
+#export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
+#rm -rf ${PGIS_REG_TMPDIR}
+#mkdir ${PGIS_REG_TMPDIR}
+#export TMPDIR=${PGIS_REG_TMPDIR}
 #TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_VER}_${PG_VER}_${GEOS_VERSION}_${PROJ_VER}
@@ -68,11 +68,11 @@ if [ $INCLUDE_MINOR_LIB == "1" ]; then
   EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --with-library-minor-version"
 fi
-if [ $REGRESS_WITHOUT_TOPOLOGY == "1" ]; then
+if [ $REGRESS_WITHOUT_TOPOLOGY == "1" ]; then
    EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
 fi
-if [ $REGRESS_WITHOUT_RASTER == "1" ]; then
+if [ $REGRESS_WITHOUT_RASTER == "1" ]; then
    EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-raster"
 fi
@@ -99,13 +99,13 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
 #patch liblwgeom generated make to get rid of dynamic linking
 #sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-make -j 4
+make -j 2
 make install
 # don't run tests twice. Only run regular if extension test is not asked for
-if [ "$MAKE_EXTENSION" == "" ]; then
+if [ "$MAKE_EXTENSION" == "0" ]; then
   make check RUNTESTFLAGS=-v
-fi
+fi
 if [ "$MAKE_EXTENSION" == "1" ]; then
@@ -117,13 +117,13 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
  #strip raster/rt_pg/postgis_raster-*.dll
  #strip sfcgal/*.dll
- if [ $REGRESS_WITHOUT_TOPOLOGY == "" ]; then
+ if [ $REGRESS_WITHOUT_TOPOLOGY == "0" ]; then
     cp -r topology/*.dll ${PGPATHEDB}/lib
  fi
  cp postgis/postgis*.dll ${PGPATHEDB}/lib
  cp sfcgal/*.dll ${PGPATHEDB}/lib
- if [ $REGRESS_WITHOUT_RASTER == "" ]; then
+ if [ $REGRESS_WITHOUT_RASTER == "0" ]; then
     cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
  fi
@@ -141,18 +141,18 @@ export UPGRADEABLE_VERSIONS=$value
 export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
 export extensions_to_install="postgis postgis_sfcgal postgis_tiger_geocoder address_standardizer"
-if [ $REGRESS_WITHOUT_TOPOLOGY == "" ]; then
+if [ $REGRESS_WITHOUT_TOPOLOGY == "0" ]; then
   extensions_to_install="${extensions_to_install} postgis_topology"
 fi
-if [ $REGRESS_WITHOUT_RASTER == "" ]; then
+if [ $REGRESS_WITHOUT_RASTER == "0" ]; then
   extensions_to_install="${extensions_to_install} postgis_raster"
 fi
 #echo "Versions are:  $UPGRADEABLE_VERSIONS"
 for EXTNAME in $extensions_to_install; do
 	cp extensions/$EXTNAME/sql/*  ${PGPATHEDB}/share/extension
 	cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index e81b946f0..d375cbec6 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -65,6 +65,18 @@ fi;
 echo "LZ4_VER ${LZ4_VER}"
+if  [[ "${REGRESS_WITHOUT_TOPOLOGY}" == '' ]] ; then
+  export REGRESS_WITHOUT_TOPOLOGY=0
+fi;
+if  [[ "${REGRESS_WITHOUT_RASTER}" == '' ]] ; then
+  export REGRESS_WITHOUT_RASTER=0
+fi;
+if  [[ "${MAKE_EXTENSION}" == '' ]] ; then
+  export MAKE_EXTENSION=0
+fi;
 #set to something even if override is on but not set
 if  [[ "${ZLIB_VER}" == '' ]] ; then
Summary of changes:
 NEWS                                               |  5 +-
 ci/winnie/package_postgis.sh                       |  4 +-
 ci/winnie/regress_postgis.sh                       | 28 +++----
 ci/winnie/winnie_common.sh                         | 12 +++
 extras/tiger_geocoder/geocode_settings.sql         |  6 ++
 .../tiger_geocoder/pagc_normalize/pagc_tables.sql  |  9 +++
 extras/tiger_geocoder/tiger_loader_2012.sql        | 16 +---
 extras/tiger_geocoder/tiger_loader_2013.sql        | 16 +---
 extras/tiger_geocoder/tiger_loader_2014.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2015.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2016.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2017.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2018.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2019.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2020.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2021.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2022.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2023.sql        | 82 +++++++++++++++++---
 extras/tiger_geocoder/tiger_loader_2024.sql        | 87 +++++++++++++++++-----
 19 files changed, 824 insertions(+), 179 deletions(-)
hooks/post-receive
