[PostGIS] #6003: unknown conversion warning in lwgeom under mingw64/msys2 gcc 13.2
trac at osgeo.org
Sat Oct 11 16:05:14 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 3.6.1
Component: postgis | Version: 3.5.x
Resolution: | Keywords: windows
Comment (by robe):
This seems to be a common issue with mingw64.
So other references to the issue in other projects
such as in QT- https://bugreports.qt.io/browse/QTBUG-70030
VHDL compiler and simulator -- https://github.com/nickg/nvc/issues/525
The suggestion is it has to do with msvcrt which is pegged at c89 or some
such thing
and can be worked around by forcing __USE_MINGW_ANSI_STDIO 1.
I haven't given that a try to see if it resolves the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6003#comment:1>
