[PostGIS] #5754: ST_ForcePolygonCCW unexpectedly modifies line geometries
trac at osgeo.org
Tue Oct 14 18:58:56 PDT 2025
Reporter: nti | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.5
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
> Unfortunately it seems there's no way to fix this without changing the
SQL definition for ST_ForcePolygonCCW which makes a patch-level fix a "no
go", so this will have to be for the 3.7 milestone.
As long as the SQL definition doesn't change the front facing API to user.
I think it's fine to change it in a patch-level.
We do sql changes to functions all the time in patch releases at the very
least in the name of security.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5754#comment:4>
