[SCM] PostGIS branch master updated. 3.6.0rc2-135-gc33c1a582
Tue Oct 14 21:45:56 PDT 2025
the project "PostGIS".
       via  c33c1a582e5b468bd54e249b2f54d9ade37bd9e8 (commit)
      from  5dc95f1bc3047b048128616d4543b603b8bbdca7 (commit)
revisions in full, below.
commit c33c1a582e5b468bd54e249b2f54d9ade37bd9e8
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Oct 14 19:57:46 2025 -0700
    Improve doc for ST_CoverageClean
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index a98c58427..5906b40a4 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -116,6 +116,95 @@ SELECT true = ALL (
   </refentry>
+  <refentry xml:id="ST_CoverageClean">
+    <refnamediv>
+      <refname>ST_CoverageClean</refname>
+      <refpurpose>Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal coverage, given a non-clean input.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+      <funcsynopsis>
+        <funcprototype>
+          <funcdef>geometry <function>ST_CoverageClean</function></funcdef>
+          <paramdef><type>geometry winset</type>
+            <parameter>geom</parameter></paramdef>
+          <paramdef choice="opt"><type>float8 </type>
+            <parameter>gapMaximumWidth = 0</parameter></paramdef>
+            <parameter>snappingDistance = -1</parameter></paramdef>
+          <paramdef choice="opt"><type>text </type>
+            <parameter>overlapMergeStrategy = 'MERGE_LONGEST_BORDER'</parameter></paramdef>
+        </funcprototype>
+      </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <title>Description</title>
+      <para>A window function which adjusts the edges of a polygonal dataset to ensure that none of the polygons overlap, narrow gaps are removed, and shared edges are identically noded.
+      The result is a clean coverage that will pass validation by <xref linkend="ST_CoverageInvalidEdges"/>
+      and can be input to coverage processing functions.
+      </para>
+      <para><parameter>gapMaximumWidth</parameter> controls the cleaning of gaps between polygons. Gaps with width less than this distance are merged into an adjacent polygon.</para>
+      <para><parameter>snappingDistance</parameter> controls snapping of close vertices and edges. The default setting (-1) use an automatic snapping distance based on the input. Set to 0.0 to turn off snapping.</para>
+      <para><parameter>overlapMergeStrategy</parameter> specifies how overlapping areas are merged into an adjacent polygon:</para>
+      <itemizedlist>
+        <listitem><para>
+            <code>MERGE_LONGEST_BORDER</code> - merges into polygon with longest common border
+            </para></listitem>
+        <listitem><para>
+            <code>MERGE_MAX_AREA</code> - merges into polygon with maximum area
+        <listitem><para>
+            <code>MERGE_MIN_AREA</code> - merges into polygon with minimum area
+        <listitem><para>
+            <code>MERGE_MIN_INDEX</code> - merges into polygon with smallest input index (defined by order of input polygons)
+      </itemizedlist>
+      <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires GEOS >= 3.14.0</para>
+    </refsection>
+    <refsection>
+      <title>Examples</title>
+      <programlisting>-- Populate demo table
+CREATE TABLE example AS SELECT * FROM (VALUES
+  (1, 'POLYGON ((10 190, 30 160, 40 110, 100 70, 120 10, 10 10, 10 190))'::geometry),
+  (2, 'POLYGON ((100 190, 10 190, 30 160, 40 110, 50 80, 74 110.5, 100 130, 140 120, 140 160, 100 190))'::geometry),
+  (3, 'POLYGON ((140 190, 190 190, 190 80, 140 80, 140 190))'::geometry),
+  (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::geometry)
+) AS v(id, geom);
+-- Prove it is a dirty coverage
+SELECT ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())
+  FROM example;
+-- Clean the coverage
+CREATE TABLE example_clean AS
+  SELECT id, ST_CoverageClean(geom) OVER () AS GEOM
+  FROM example;
+-- Prove it is a clean coverage
+  FROM example_clean;
+      </programlisting>
+    </refsection>
+    <refsection>
+      <title>See Also</title>
+      <para>
+        <xref linkend="ST_CoverageInvalidEdges"/>,
+        <xref linkend="ST_CoverageUnion"/>,
+        <xref linkend="ST_CoverageSimplify"/>,
+        <xref linkend="ST_MaximumInscribedCircle"/>
+      </para>
+    </refsection>
+  </refentry>
   <refentry xml:id="ST_CoverageSimplify">
     <refnamediv>
@@ -312,82 +401,4 @@ MULTIPOLYGON (((10 150, 80 190, 110 150, 140 80, 120 10, 10 10, 10 150), (50 60,
   </refentry>
-  <refentry xml:id="ST_CoverageClean">
-    <refnamediv>
-      <refname>ST_CoverageClean</refname>
-      <refpurpose>Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal coverage, given a non-clean input.</refpurpose>
-    </refnamediv>
-    <refsynopsisdiv>
-      <funcsynopsis>
-        <funcprototype>
-          <funcdef>geometry <function>ST_CoverageClean</function></funcdef>
-          <paramdef><type>geometry winset</type>
-            <parameter>geom</parameter></paramdef>
-          <paramdef choice="opt"><type>float8 </type>
-            <parameter>gapMaximumWidth = 0</parameter></paramdef>
-            <parameter>snappingDistance = -1</parameter></paramdef>
-          <paramdef choice="opt"><type>text </type>
-            <parameter>overlapMergeStrategy = 'MERGE_LONGEST_BORDER'</parameter></paramdef>
-        </funcprototype>
-      </funcsynopsis>
-    </refsynopsisdiv>
-    <refsection>
-      <title>Description</title>
-      <para>A window function which alters the edges of a polygonal coverage to ensure that none of the polygons overlap, that small gaps are snapped away, and that all shared edges are exactly identical. The result is a clean coverage that will pass validation tests like <xref linkend="ST_CoverageInvalidEdges"/></para>
-      <para>The <parameter>gapMaximumWidth</parameter> controls the cleaning of gaps between polygons. Gaps smaller than this tolerance will be closed.</para>
-      <para>The <parameter>snappingDistance</parameter> controls the node snapping step, when nearby vertices are snapped together. The default setting (-1) applies an automatic snapping distance based on an analysis of the input. Set to 0.0 to turn off all snapping.</para>
-      <para>The <parameter>overlapMergeStrategy</parameter> controls the algorithm used to determine which neighboring polygons to merge overlapping areas into.</para>
-      <para><code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border</para>
-      <para><code>MERGE_MAX_AREA</code> chooses polygon with maximum area</para>
-      <para><code>MERGE_MIN_AREA</code> chooses polygon with minimum area</para>
-      <para><code>MERGE_MIN_INDEX</code> chooses polygon with smallest input index</para>
-      <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires GEOS >= 3.14.0</para>
-    </refsection>
-    <refsection>
-      <title>Examples</title>
-      <programlisting>-- Populate demo table
-CREATE TABLE example AS SELECT * FROM (VALUES
-  (1, 'POLYGON ((10 190, 30 160, 40 110, 100 70, 120 10, 10 10, 10 190))'::geometry),
-  (2, 'POLYGON ((100 190, 10 190, 30 160, 40 110, 50 80, 74 110.5, 100 130, 140 120, 140 160, 100 190))'::geometry),
-  (3, 'POLYGON ((140 190, 190 190, 190 80, 140 80, 140 190))'::geometry),
-  (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::geometry)
-) AS v(id, geom);
--- Prove it is a dirty coverage
-SELECT ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())
-  FROM example;
--- Clean the coverage
-CREATE TABLE example_clean AS
-  SELECT id, ST_CoverageClean(geom) OVER () AS GEOM
-  FROM example;
--- Prove it is a clean coverage
-  FROM example_clean;
-      </programlisting>
-    </refsection>
-    <refsection>
-      <title>See Also</title>
-      <para>
-        <xref linkend="ST_CoverageInvalidEdges"/>,
-        <xref linkend="ST_Union"/>
-        <xref linkend="ST_CoverageSimplify"/>
-      </para>
-    </refsection>
-  </refentry>
 </section>
Summary of changes:
 doc/reference_coverage.xml | 167 ++++++++++++++++++++++++---------------------
 1 file changed, 89 insertions(+), 78 deletions(-)
hooks/post-receive
