[PostGIS] #5983: Data corruption in topology.topoelement and topology.topogeometry after upgrade to 3.6.0
PostGIS trac at osgeo.org
Wed Oct 15 06:58:43 PDT 2025
upgrade to 3.6.0
  Reporter:  packi     |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.6.1
 Component:  topology  |    Version:  3.6.x
Resolution:            |   Keywords:
Comment (by strk):
 I believe this is another effect of the same bug:
 strk=# select geometrytype(tg) from public.com01012025_wgs84 limit 2;
  geometrytype
  UNEXPECTED
  UNEXPECTED
 (2 rows)
 Those TopoGeometry objects have feature_type=3 but I'm afraid the int64
 change made PostgreSQL read past the bounds of the actual data, as I
 anticipated in
 https://gitea.osgeo.org/postgis/postgis/pulls/242#issuecomment-13471
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:11>
