[SCM] PostGIS branch master updated. 3.6.0rc2-137-g976adccb9
Wed Oct 15 10:01:14 PDT 2025
the project "PostGIS".
       via  976adccb9b11f9f47da2aafe0e524d3207c08914 (commit)
       via  dba29bac7b4d2a58730953dad939e5dafd28b78b (commit)
      from  c33c1a582e5b468bd54e249b2f54d9ade37bd9e8 (commit)
revisions in full, below.
commit 976adccb9b11f9f47da2aafe0e524d3207c08914
Merge: c33c1a582 dba29bac7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Oct 15 10:01:06 2025 -0700
    Merge branch 'master-5754'
commit dba29bac7b4d2a58730953dad939e5dafd28b78b
Date:   Wed Oct 15 09:14:37 2025 -0700
    ST_ForcePolygonCCW unexpectedly reverses non-polygonal geometries too, references #5754
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 47fb42e02..f0c3dc1b1 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -751,8 +751,9 @@ static void test_lwgeom_force_clockwise(void)
 	/* counterclockwise, must be reversed */
 	geom = lwgeom_from_wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))", LW_PARSER_CHECK_NONE);
-	CU_ASSERT_FALSE(lwgeom_is_clockwise(geom));
+	CU_ASSERT(lwgeom_has_orientation(geom,LW_COUNTERCLOCKWISE));
 	lwgeom_force_clockwise(geom);
+	CU_ASSERT(lwgeom_has_orientation(geom,LW_CLOCKWISE));
 	in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0))";
 	out_ewkt = lwgeom_to_ewkt(geom);
 	if (strcmp(in_ewkt, out_ewkt))
@@ -763,8 +764,9 @@ static void test_lwgeom_force_clockwise(void)
 	/* clockwise, fine as is */
 	geom = lwgeom_from_wkt("POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))", LW_PARSER_CHECK_NONE);
-	CU_ASSERT_TRUE(lwgeom_is_clockwise(geom));
@@ -775,8 +777,8 @@ static void test_lwgeom_force_clockwise(void)
 	/* counterclockwise shell (must be reversed), mixed-wise holes */
 	geom = lwgeom_from_wkt("POLYGON((0 0,10 0,10 10,0 10,0 0),(2 2,2 4,4 2,2 2),(6 2,8 2,8 4,6 2))", LW_PARSER_CHECK_NONE);
 	in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 2,8 4,6 2))";
@@ -785,10 +787,11 @@ static void test_lwgeom_force_clockwise(void)
 	lwfree(out_ewkt);
 	lwgeom_free(geom);
-	/* clockwise shell (fine), mixed-wise holes */
+	/* clockwise shell (fine), mixed-wise holes, so not oriented */
 	geom = lwgeom_from_wkt("POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 4,8 2,6 2))", LW_PARSER_CHECK_NONE);
+	/* fix it and then it is oriented */
@@ -803,10 +806,11 @@ static void test_lwgeom_force_clockwise(void)
 	geom = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
 	geom2 = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
 	lwgeom_force_clockwise(geom2);
 	/** use same check instead of strcmp to account
 	  for difference in endianness **/
-	CU_ASSERT( lwgeom_same(geom, geom2) );
+	CU_ASSERT(lwgeom_same(geom, geom2));
 	lwgeom_free(geom);
 	lwgeom_free(geom2);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 54eb1e7ed..752569540 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1379,10 +1379,12 @@ extern int lwgeom_startpoint(const LWGEOM* lwgeom, POINT4D* pt);
 extern void interpolate_point4d(const POINT4D *A, const POINT4D *B, POINT4D *I, double F);
-* Ensure the outer ring is clockwise oriented and all inner rings
-* are counter-clockwise.
+* Tests that geometry is oriented LW_CLOCKWISE or LW_COUNTERCLOCKWISE.
+* Ensure the outer ring is oriented and all inner rings
+* are anti-oriented. Returns LW_TRUE for oriented or non-orientable (empty
+* or non-polygonal geometry) and LW_FALSE for misoriented.
-extern int lwgeom_is_clockwise(LWGEOM *lwgeom);
+extern int lwgeom_has_orientation(const LWGEOM *lwgeom, int orientation);
@@ -1427,6 +1429,7 @@ extern void lwgeom_grid_in_place(LWGEOM *lwgeom, gridspec *grid);
 extern void lwgeom_reverse_in_place(LWGEOM *lwgeom);
 extern void lwgeom_force_clockwise(LWGEOM *lwgeom);
+extern void lwgeom_force_counterclockwise(LWGEOM *lwgeom);
 extern void lwgeom_longitude_shift(LWGEOM *lwgeom);
 extern int lwgeom_simplify_in_place(LWGEOM *igeom, double dist, int preserve_collapsed);
 extern void lwgeom_affine(LWGEOM *geom, const AFFINE *affine);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 04a3504e2..39baf8032 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -157,6 +157,13 @@
 #define LW_BOUNDARY 0
 #define LW_OUTSIDE -1
+* Constants for orientation checking and forcing
+#define LW_CLOCKWISE 1
+#define LW_NONE 0
+#define LW_COUNTERCLOCKWISE -1
 * Internal prototypes
@@ -361,12 +368,13 @@ LWCOLLECTION *lwcollection_clone_deep(const LWCOLLECTION *lwgeom);
 GBOX *gbox_clone(const GBOX *gbox);
-* Clockwise
+* Orientation (LW_CLOCKWISE and LW_COUNTERCLOCKWISE)
-void lwpoly_force_clockwise(LWPOLY *poly);
-void lwtriangle_force_clockwise(LWTRIANGLE *triangle);
-int lwpoly_is_clockwise(LWPOLY *poly);
-int lwtriangle_is_clockwise(LWTRIANGLE *triangle);
+void lwpoly_force_orientation(LWPOLY *poly, int orientation);
+void lwtriangle_force_orientation(LWTRIANGLE *triangle, int orientation);
+int lwpoly_has_orientation(const LWPOLY *poly, int orientation);
+int lwtriangle_has_orientation(const LWTRIANGLE *triangle, int orientation);
+int ptarray_has_orientation(const POINTARRAY *pa, int orientation);
 int ptarray_isccw(const POINTARRAY *pa);
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 6697186d8..a2d65dc0f 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -33,61 +33,89 @@
 #define out_stack_size 32
-/** Force Right-hand-rule on LWGEOM polygons **/
-void
-lwgeom_force_clockwise(LWGEOM *lwgeom)
-	LWCOLLECTION *coll;
-	uint32_t i;
-	switch (lwgeom->type)
-	case POLYGONTYPE:
-		lwpoly_force_clockwise((LWPOLY *)lwgeom);
-		return;
-	case TRIANGLETYPE:
-		lwtriangle_force_clockwise((LWTRIANGLE *)lwgeom);
-		return;
-		/* Not handle POLYHEDRALSURFACE and TIN
-		   as they are supposed to be well oriented */
-	case MULTIPOLYGONTYPE:
-	case COLLECTIONTYPE:
-		coll = (LWCOLLECTION *)lwgeom;
-		for (i=0; i<coll->ngeoms; i++)
-			lwgeom_force_clockwise(coll->geoms[i]);
-		return;
-/** Check clockwise orientation on LWGEOM polygons **/
-int
-lwgeom_is_clockwise(LWGEOM *lwgeom)
+ * Force an orientation onto geometries made up of rings,
+ * so the rings circle in a particular direction, clockwise
+ * or counter-clockwise. The orientation is one of
+ * LW_CLOCKWISE or LW_COUNTERCLOCKWISE. Non-polygonal
+ * geometries are ignored and returned untouched.
+static void
+lwgeom_force_orientation(LWGEOM *lwgeom, int orientation)
 		case POLYGONTYPE:
-			return lwpoly_is_clockwise((LWPOLY *)lwgeom);
+			lwpoly_force_orientation(lwgeom_as_lwpoly(lwgeom), orientation);
+			return;
 		case TRIANGLETYPE:
-			return lwtriangle_is_clockwise((LWTRIANGLE *)lwgeom);
+			lwtriangle_force_orientation(lwgeom_as_lwtriangle(lwgeom), orientation);
+			return;
+		/* Not handle POLYHEDRALSURFACE and TIN
+		   as they are supposed to be well oriented */
+		case MULTIPOLYGONTYPE:
+		case COLLECTIONTYPE:
+			LWCOLLECTION* coll = lwgeom_as_lwcollection(lwgeom);
+			for (uint32_t i = 0; coll && i < coll->ngeoms; i++)
+				lwgeom_force_orientation(coll->geoms[i], orientation);
+			return;
+void
+lwgeom_force_clockwise(LWGEOM *lwgeom)
+	return lwgeom_force_orientation(lwgeom, LW_CLOCKWISE);
+void
+lwgeom_force_counterclockwise(LWGEOM *lwgeom)
+	return lwgeom_force_orientation(lwgeom, LW_COUNTERCLOCKWISE);
+ * Check clockwise orientation on LWGEOM polygons
+ * returns LW_CLOCKWISE, LW_NONE, LW_COUNTERCLOCKWISE
+ * Non-polygonal geometries return LW_NONE
+ * Geometries must have *all* rings correctly oriented
+ * to return a non-none orientation
+int
+lwgeom_has_orientation(const LWGEOM *lwgeom, int orientation)
+	switch (lwgeom->type)
+		case POLYGONTYPE:
+			return lwpoly_has_orientation(lwgeom_as_lwpoly(lwgeom), orientation);
+		case TRIANGLETYPE:
+			return lwtriangle_has_orientation(lwgeom_as_lwtriangle(lwgeom), orientation);
-			uint32_t i;
-			LWCOLLECTION* coll = (LWCOLLECTION *)lwgeom;
-			for (i=0; i < coll->ngeoms; i++)
-				if (!lwgeom_is_clockwise(coll->geoms[i]))
+				if(!lwgeom_has_orientation(coll->geoms[i], orientation))
 					return LW_FALSE;
 			return LW_TRUE;
 		default:
 			return LW_TRUE;
-		return LW_FALSE;
+	return LW_FALSE;
 LWGEOM *
@@ -1178,7 +1206,7 @@ lwtype_is_collection(uint8_t type)
 	case MULTICURVETYPE:
 	case MULTISURFACETYPE:
 	case POLYHEDRALSURFACETYPE:
-  case TINTYPE:
+	case TINTYPE:
 		return LW_TRUE;
 		break;
diff --git a/liblwgeom/lwpoly.c b/liblwgeom/lwpoly.c
index 145e2cc75..a4949e734 100644
--- a/liblwgeom/lwpoly.c
+++ b/liblwgeom/lwpoly.c
@@ -265,38 +265,37 @@ lwpoly_add_ring(LWPOLY *poly, POINTARRAY *pa)
 void
-lwpoly_force_clockwise(LWPOLY *poly)
+lwpoly_force_orientation(LWPOLY *poly, int orientation)
-	uint32_t i;
+	/* No-op no orientation */
+	if (orientation == LW_NONE) return;
 	/* No-op empties */
-	if ( lwpoly_is_empty(poly) )
-		return;
+	if (lwpoly_is_empty(poly)) return;
 	/* External ring */
-	if ( ptarray_isccw(poly->rings[0]) )
+	if (!ptarray_has_orientation(poly->rings[0], orientation))
 		ptarray_reverse_in_place(poly->rings[0]);
-	/* Internal rings */
-	for (i=1; i<poly->nrings; i++)
-		if ( ! ptarray_isccw(poly->rings[i]) )
+	/* Internal rings must run opposite to external */
+	for (uint32_t i = 1; i < poly->nrings; i++)
+		if (!ptarray_has_orientation(poly->rings[i], -1 * orientation))
 			ptarray_reverse_in_place(poly->rings[i]);
 int
-lwpoly_is_clockwise(LWPOLY *poly)
+lwpoly_has_orientation(const LWPOLY *poly, int orientation)
-	uint32_t i;
 		return LW_TRUE;
+	/* Exterior ring matches orientation? */
+	if(!ptarray_has_orientation(poly->rings[0], orientation))
 		return LW_FALSE;
-	for ( i = 1; i < poly->nrings; i++)
-		if ( !ptarray_isccw(poly->rings[i]) )
+	/* Interior rings are opposite of orientation? */
 			return LW_FALSE;
 	return LW_TRUE;
diff --git a/liblwgeom/lwtriangle.c b/liblwgeom/lwtriangle.c
index adfa9c04f..b37279077 100644
--- a/liblwgeom/lwtriangle.c
+++ b/liblwgeom/lwtriangle.c
@@ -102,17 +102,17 @@ lwtriangle_clone(const LWTRIANGLE *g)
 	return (LWTRIANGLE *)lwline_clone((const LWLINE *)g);
-void
-lwtriangle_force_clockwise(LWTRIANGLE *triangle)
+int
+lwtriangle_has_orientation(const LWTRIANGLE *triangle, int orientation)
-	if ( ptarray_isccw(triangle->points) )
-		ptarray_reverse_in_place(triangle->points);
+	return ptarray_has_orientation(triangle->points, orientation);
-int
-lwtriangle_is_clockwise(LWTRIANGLE *triangle)
+void
+lwtriangle_force_orientation(LWTRIANGLE *triangle, int orientation)
-	return !ptarray_isccw(triangle->points);
+	if (!lwtriangle_has_orientation(triangle, orientation))
+		ptarray_reverse_in_place(triangle->points);
 void
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 4bf5816e9..cce30d5b2 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1171,12 +1171,17 @@ ptarray_signed_area(const POINTARRAY *pa)
 int
-ptarray_isccw(const POINTARRAY *pa)
+ptarray_has_orientation(const POINTARRAY *pa, int orientation)
-	double area = 0;
-	area = ptarray_signed_area(pa);
-	if ( area > 0 ) return LW_FALSE;
-	else return LW_TRUE;
+	if (ptarray_signed_area(pa) > 0)
+		return orientation == LW_CLOCKWISE;
+	else
+		return orientation == LW_COUNTERCLOCKWISE;
+int ptarray_isccw(const POINTARRAY *pa)
+	return ptarray_has_orientation(pa, LW_COUNTERCLOCKWISE);
 POINTARRAY*
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index abcc222c6..13e31cf01 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -869,21 +869,12 @@ PG_FUNCTION_INFO_V1(ST_IsPolygonCW);
 Datum ST_IsPolygonCW(PG_FUNCTION_ARGS)
 	GSERIALIZED* geom;
-	LWGEOM* input;
-	bool is_clockwise;
 	if (PG_ARGISNULL(0))
 		PG_RETURN_NULL();
 	geom = PG_GETARG_GSERIALIZED_P(0);
-	input = lwgeom_from_gserialized(geom);
-	is_clockwise = lwgeom_is_clockwise(input);
-	lwgeom_free(input);
-	PG_FREE_IF_COPY(geom, 0);
-	PG_RETURN_BOOL(is_clockwise);
+	PG_RETURN_BOOL(lwgeom_has_orientation(lwgeom_from_gserialized(geom), LW_CLOCKWISE));
@@ -896,19 +887,12 @@ PG_FUNCTION_INFO_V1(ST_IsPolygonCCW);
 Datum ST_IsPolygonCCW(PG_FUNCTION_ARGS)
 	GSERIALIZED* geom;
-	LWGEOM* input;
-	bool is_ccw;
 		PG_RETURN_NULL();
-	geom = PG_GETARG_GSERIALIZED_P_COPY(0);
-	lwgeom_reverse_in_place(input);
-	is_ccw = lwgeom_is_clockwise(input);
-	PG_RETURN_BOOL(is_ccw);
+	geom = PG_GETARG_GSERIALIZED_P(0);
+	PG_RETURN_BOOL(lwgeom_has_orientation(lwgeom_from_gserialized(geom), LW_COUNTERCLOCKWISE));
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 06ea00934..b3e1179b3 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -1934,6 +1934,31 @@ Datum LWGEOM_force_clockwise_poly(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(outgeom);
+ * Force polygon exterior rings to circle counter-clockwise,
+ * and interior rings to circle clockwise.
+PG_FUNCTION_INFO_V1(ST_ForcePolygonCCW);
+Datum ST_ForcePolygonCCW(PG_FUNCTION_ARGS)
+	GSERIALIZED *ingeom, *outgeom;
+	LWGEOM *lwgeom;
+	POSTGIS_DEBUG(2, "ST_ForcePolygonCCW called");
+	ingeom = PG_GETARG_GSERIALIZED_P_COPY(0);
+	lwgeom = lwgeom_from_gserialized(ingeom);
+	lwgeom_force_counterclockwise(lwgeom);
+	outgeom = geometry_serialize(lwgeom);
+	lwgeom_free(lwgeom);
+	PG_FREE_IF_COPY(ingeom, 0);
+	PG_RETURN_POINTER(outgeom);
 /** Test deserialize/serialize operations */
 PG_FUNCTION_INFO_V1(LWGEOM_noop);
 Datum LWGEOM_noop(PG_FUNCTION_ARGS)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 03a7fdde8..f508024c5 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1592,10 +1592,11 @@ CREATE OR REPLACE FUNCTION ST_ForcePolygonCW(geometry)
 	_COST_LOW;
 -- Availability: 2.4.0
+-- Changed: 3.7.0 - C implementation
 CREATE OR REPLACE FUNCTION ST_ForcePolygonCCW(geometry)
 	RETURNS geometry
-	AS $$ SELECT @extschema at .ST_Reverse(@extschema at .ST_ForcePolygonCW($1)) $$
-	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
+	AS 'MODULE_PATHNAME', 'ST_ForcePolygonCCW'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
 -- Availability: 1.2.2
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 4b580b003..cffa4fbf8 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1623,3 +1623,9 @@ SELECT '#5962',
     ST_AsText(ST_ClipByBox2D(
         ST_GeomFromText('MULTIPOINT((1 1),(6 4),(5 4))'),
         ST_MakeEnvelope(0, 0, 5, 5 )), 2);
+SELECT '#5754' AS Ticket,
+    ST_AsText(ST_ForcePolygonCCW('LINESTRING(0 0, 1 1, 2 0, 3 1, 4 0)'::geometry), 1) AS LsCcw,
+    ST_AsText(ST_ForcePolygonCW('LINESTRING(0 0, 1 1, 2 0, 3 1, 4 0)'::geometry), 1) AS LsCw,
+	ST_AsText(ST_ForcePolygonCCW('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))'::geometry), 1) AS PlyCcw1,
+	ST_AsText(ST_ForcePolygonCCW('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(1 1, 2 1, 2 2, 1 2, 1 1))'::geometry), 1)  AS PlyCcw2
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 0f2bf2f39..98d74a836 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -492,3 +492,4 @@ public|test5978|geometry|2|4326|POINT
 public|test5978|shape|2|4326|POINT
 #5987|LINESTRING(20 20,20.1 20,20.2 19.9)|LINESTRING(20 20,20.1 20,20.2 19.9)
 #5962|MULTIPOINT((1 1),(3 4))|POINT(1 1)
+#5754|LINESTRING(0 0,1 1,2 0,3 1,4 0)|LINESTRING(0 0,1 1,2 0,3 1,4 0)|POLYGON((0 0,1 0,1 1,0 1,0 0))|POLYGON((0 0,10 0,10 10,0 10,0 0),(1 1,1 2,2 2,2 1,1 1))
Summary of changes:
 liblwgeom/cunit/cu_gserialized1.c   | 16 ++++---
 liblwgeom/liblwgeom.h.in            |  9 ++--
 liblwgeom/liblwgeom_internal.h      | 18 +++++---
 liblwgeom/lwgeom.c                  | 86 ++++++++++++++++++++++++-------------
 liblwgeom/lwpoly.c                  | 31 +++++++------
 liblwgeom/lwtriangle.c              | 14 +++---
 liblwgeom/ptarray.c                 | 15 ++++---
 postgis/lwgeom_functions_analytic.c | 24 ++---------
 postgis/lwgeom_functions_basic.c    | 25 +++++++++++
 postgis/postgis.sql.in              |  5 ++-
 regress/core/tickets.sql            |  6 +++
 regress/core/tickets_expected       |  1 +
 12 files changed, 157 insertions(+), 93 deletions(-)
hooks/post-receive
