[PostGIS] #5996: ST_FilterHolesByArea
trac at osgeo.org
Wed Oct 15 11:07:08 PDT 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.0
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by pramsey):
"Remove small holes" is not the same as "remove all holes", which is the
use case that drove me to the idea of filtering holes also rather than
just having a single-minded `ST_NoHoles` function. That use case seems
like a bad fit for `ST_RemoveSmallParts`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5996#comment:6>
