[PostGIS] #6006: ST_MakeValid documentation does not state default value for keepcollapsed param
trac at osgeo.org
Wed Oct 15 17:32:49 PDT 2025
param
Reporter: atlight | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: documentation | Version: 3.5.x
Keywords: |
https://postgis.net/docs/ST_MakeValid.html
> The "keepcollapsed" key is only valid for the "structure" algorithm, and
takes a value of "true" or "false". When set to "false", geometry
components that collapse to a lower dimensionality, for example a one-
point linestring would be dropped.
Is "true" or "false" the default value if the parameter is not specified?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6006>
