[SCM] postgis.net branch website updated. clarity-final-158-g8f9eb96
Thu Oct 16 15:55:53 PDT 2025
the project "postgis.net".
The branch, website has been updated
       via  8f9eb9691253c978c2fe7960737514d0d64ea8c5 (commit)
      from  582c9058567f96623dbbef8eef56342bd22e0f67 (commit)
revisions in full, below.
commit 8f9eb9691253c978c2fe7960737514d0d64ea8c5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Oct 16 15:55:47 2025 -0700
    News entry for 3.5.4
diff --git a/config.toml b/config.toml
index 7c714ac..cb5643c 100644
--- a/config.toml
+++ b/config.toml
@@ -174,8 +174,8 @@ enableRobotsTXT = true
       tag = "3.6.0"
     [params.postgis.releases.35]
       minor = "3.5"
-      dev = "3.5.4dev"
-      tag = "3.5.3"
+      dev = "3.5.5dev"
+      tag = "3.5.4"
     [params.postgis.releases.34]
       minor = "3.4"
       dev = "3.4.5dev"
diff --git a/content/news/2025/10-16_postgis-3.5.4.md b/content/news/2025/10-16_postgis-3.5.4.md
new file mode 100644
index 0000000..efb6285
--- /dev/null
+++ b/content/news/2025/10-16_postgis-3.5.4.md
@@ -0,0 +1,75 @@
+title: PostGIS 3.5.4
+layout: post
+category: news
+tags: [release, 3.5]
+author: Paul Ramsey
+thumbnail:
+date: "2025-10-16"
+The PostGIS Team is pleased to release PostGIS 3.5.4.
+This version requires PostgreSQL 12 - 18beta1, GEOS 3.8 or higher, and Proj 6.1+.
+To take advantage of all features, GEOS 3.12+ is needed.
+SFCGAL 1.4+ is needed to enable postgis_sfcgal support.
+To take advantage of all SFCGAL features, SFCGAL 1.5+ is needed.
+### 3.5.4
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.5.4.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.5.4.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.5.4/NEWS)
+* PDF docs: [en]({{< loc "postgis.release_docs">}}/postgis-3.5.4-en.pdf)
+This release is a bug fix release that includes bug fixes since PostGIS 3.5.3.
+<!--more-->
+### Bug fixes
+- [#5977](https://trac.osgeo.org/postgis/ticket/5977), Fix downgrade protection with standard conforming strings off (Sandro Santilli)
+- [#5951](https://trac.osgeo.org/postgis/ticket/5951), Fix crash in ST_GetFaceEdges with corrupted topology (Sandro Santilli)
+- [#5947](https://trac.osgeo.org/postgis/ticket/5947), [topology] Fix crash in ST_ModEdgeHeal (Sandro Santilli)
+- [#5925](https://trac.osgeo.org/postgis/ticket/5925), [#5946](https://trac.osgeo.org/postgis/ticket/5946), [topology] Have GetFaceContainingPoint survive EMPTY edges (Sandro Santilli)
+- [#5936](https://trac.osgeo.org/postgis/ticket/5936), [topology] Do script-based upgrade in a single transaction (Sandro Santilli)
+- [#5908](https://trac.osgeo.org/postgis/ticket/5908), [topology] Fix crash in GetFaceContainingPoint (Sandro Santilli)
+- [#5907](https://trac.osgeo.org/postgis/ticket/5907), [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)
+- [#5922](https://trac.osgeo.org/postgis/ticket/5922), [topology] Fix crash in TopoGeo_AddLinestring with EMPTY input (Sandro Santilli)
+- [#5921](https://trac.osgeo.org/postgis/ticket/5921), Crash freeing uninitialized pointer (Arsenii Mukhin)
+- [#5912](https://trac.osgeo.org/postgis/ticket/5912), Crash on GML with xlink and no prefix (Paul Ramsey)
+- [#5905](https://trac.osgeo.org/postgis/ticket/5905), Crash on deeply nested geometries (Paul Ramsey)
+- [#5909](https://trac.osgeo.org/postgis/ticket/5909), ST_ValueCount crashes on empty table (Paul Ramsey)
+- [#5917](https://trac.osgeo.org/postgis/ticket/5917), ST_Relate becomes unresponsive (Paul Ramsey)
+- [#5923](https://trac.osgeo.org/postgis/ticket/5923), CG_ExtrudeStraightSkeleton crashes on empty polygon (Loïc Bartoletti)
+- [#5935](https://trac.osgeo.org/postgis/ticket/5935), Require GDAL 2.4 for postgis_raster and switch to GDALGetDataTypeSizeBytes (Laurențiu Nicola)
+- GT-257, fix issue with xsltproc with path has spaces (Laurențiu Nicola)
+- [#5938](https://trac.osgeo.org/postgis/ticket/5938), incorrect parameter order in ST_Relate caching (Paul Ramsey)
+- [#5927](https://trac.osgeo.org/postgis/ticket/5927), ST_IsCollection throwing exception (Paul Ramsey)
+- [#5902](https://trac.osgeo.org/postgis/ticket/5902), ST_PointFromText cannot create geometries with M (Paul Ramsey)
+- [#5943](https://trac.osgeo.org/postgis/ticket/5943), Memory leak in handling GEOS GeometryFactory (Megan Ma)
+- [#5407](https://trac.osgeo.org/postgis/ticket/5407), Use memset in place of bzero (Paul Ramsey)
+- [#5082](https://trac.osgeo.org/postgis/ticket/5082), LRS proportions clamped to [0,1] (Pawel Ostrowski)
+- [#5985](https://trac.osgeo.org/postgis/ticket/5985), Fix configure issue with Debian 12 and 13 (Regina Obe, Sandro Santilli)
+- [#5991](https://trac.osgeo.org/postgis/ticket/5991), CircularString distance error (Paul Ramsey)
+- [#5994](https://trac.osgeo.org/postgis/ticket/5994), Null pointer in ST_AsGeoJsonRow (Alexander Kukushkin)
+- [#5989](https://trac.osgeo.org/postgis/ticket/5989), ST_Distance error on CurvePolygon (Paul Ramsey)
+- [#5962](https://trac.osgeo.org/postgis/ticket/5962), Consistent clipping of MULTI/POINT (Paul Ramsey)
+- [#5754](https://trac.osgeo.org/postgis/ticket/5754), ST_ForcePolygonCCW reverses lines (Paul Ramsey)
+### Upgrading
+After installing the binaries or after running pg_upgrade:
+For PostGIS 3.5, 3.4, 3.3, 3.2, 3.1, 3.0 do below which will upgrade all your postgis extensions.
+```sql
+SELECT postgis_extensions_upgrade();
+If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
+or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 3.5.4 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone=PostGIS+3.5.4
Summary of changes:
 config.toml                              |  4 +-
 content/news/2025/10-16_postgis-3.5.4.md | 75 ++++++++++++++++++++++++++++++++
 2 files changed, 77 insertions(+), 2 deletions(-)
 create mode 100644 content/news/2025/10-16_postgis-3.5.4.md
hooks/post-receive
postgis.net
