[SCM] PostGIS branch master updated. 3.6.0rc2-139-g8a5acc9a1
Fri Oct 17 09:57:22 PDT 2025
the project "PostGIS".
       via  8a5acc9a1b5945db2d50f7126479e74eb2b6eb71 (commit)
      from  74d24bc78383f8e021cd6300b5aec1d7278b5487 (commit)
revisions in full, below.
commit 8a5acc9a1b5945db2d50f7126479e74eb2b6eb71
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Oct 17 09:57:10 2025 -0700
    Break up examples in ST_LineMerge, closes #5842
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 80c16af3f..8f5fd34b9 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1468,6 +1468,8 @@ FROM test;
 		<refsection>
 			<title>Examples</title>
+      <refsect1>
+        <title>Cardinality 2</title>
       <para>
           <informalfigure>
               <mediaobject>
@@ -1476,7 +1478,7 @@ FROM test;
                     </imageobject>
                     <caption>
-                        <para>Merging lines with different orientation.
+                        <para>Nodes with cardinality 2 are merged away.
                         </para>
                     </caption>
               </mediaobject>
@@ -1488,7 +1490,9 @@ FROM test;
  LINESTRING(10 160,60 120,120 140,180 120)
 </programlisting>
+</refsect1>
+<refsect1>
+<title>Cardinality 3 or More</title>
       <para>
           <informalfigure>
               <mediaobject>
@@ -1509,7 +1513,10 @@ FROM test;
  MULTILINESTRING((10 160,60 120,120 140),(100 180,120 140),(120 140,180 120))
 </programlisting>
+</refsect1>
+<refsect1>
+  <title>Non-Touching Lines</title>
 <para>If merging is not possible due to non-touching lines,
 the original MultiLineString is returned.</para>
 <programlisting>
@@ -1519,7 +1526,10 @@ SELECT ST_AsText(ST_LineMerge(
 MULTILINESTRING((-45.2 -33.2,-46 -32),(-29 -27,-30 -29.7,-36 -31,-45 -33))
 </programlisting>
+</refsect1>
+<refsect1>
+  <title>Directed Parameter</title>
 <para>
 	<informalfigure>
 		<mediaobject>
@@ -1539,15 +1549,18 @@ TRUE));
  MULTILINESTRING((120 50,60 30,10 70),(120 50,180 30))
 </programlisting>
+</refsect1>
-<para>Example showing Z-dimension handling.</para>
+<refsect1>
+<title>Z-dimension Handling</title>
 <programlisting>
       'MULTILINESTRING((-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 6), (-29 -27 12,-30 -29.7 5), (-45 -33 1,-46 -32 11))'
 LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11)
 </programlisting>
+</refsect1>
 		</refsection>
 		<refsection>
 			<title>See Also</title>
Summary of changes:
 doc/reference_processing.xml | 21 +++++++++++++++++----
 1 file changed, 17 insertions(+), 4 deletions(-)
hooks/post-receive
