[SCM] PostGIS branch master updated. 3.6.0rc2-140-g60c6bb4fe
git at osgeo.org
git at osgeo.org
Fri Oct 17 10:07:51 PDT 2025
the project "PostGIS".
via 60c6bb4fe2a6a3256ba5daaa6ded1a4c5ebe0e5f (commit)
from 8a5acc9a1b5945db2d50f7126479e74eb2b6eb71 (commit)
revisions in full, below.
commit 60c6bb4fe2a6a3256ba5daaa6ded1a4c5ebe0e5f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 17 10:07:44 2025 -0700
Note the default values for keepcollapsed in ST_MakeValid, closes #6006
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index ed94bb362..d824a504b 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -351,22 +351,35 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
<itemizedlist>
<listitem>
- <para>"linework" is the original algorithm, and builds valid geometries
+ <para>"linework" is the default algorithm, and builds valid geometries
by first extracting all lines, noding that linework together, then building
- a value output from the linework.</para>
+ a value output from the linework. The requirement that no vertices are
+ lost can generate complex collections as outputs.</para>
</listitem>
<listitem>
<para>"structure" is an algorithm that distinguishes between
interior and exterior rings, building new geometry by unioning
- exterior rings, and then differencing all interior rings.</para>
+ exterior rings, and then differencing all interior rings. The results
+ tend to be more intuitive, where collapsed lines are discarded in
+ the output.</para>
</listitem>
</itemizedlist>
<para>The "keepcollapsed" key is only valid for the "structure" algorithm,
- and takes a value of "true" or "false". When set to "false",
- geometry components that collapse to a lower dimensionality,
- for example a one-point linestring would be dropped.
- </para>
+ and takes a value of "true" or "false".</para>
+ <itemizedlist>
+ <listitem>
+ <para>Keep collapsed of "false" is the default, and means that
+ geometry components that collapse to a lower dimensionality,
+ for example a one-point linestring will be dropped.</para>
+ </listitem>
+ <listitem>
+ <para>Keep collapsed of "true" means
+ will be retained.</para>
+ </listitem>
+ </itemizedlist>
<para>Performed by the GEOS module.</para>
Summary of changes:
doc/reference_validation.xml | 27 ++++++++++++++++++++-------
1 file changed, 20 insertions(+), 7 deletions(-)
hooks/post-receive
