[SCM] PostGIS branch master updated. 3.6.0rc2-142-gd7c5ead4d
Fri Oct 17 13:16:56 PDT 2025
the project "PostGIS".
       via  d7c5ead4d9998d34b6a7753bf757981ffdefb326 (commit)
      from  5cd33ae8d1a9dc8f878ac7792d03566667d1cffc (commit)
revisions in full, below.
commit d7c5ead4d9998d34b6a7753bf757981ffdefb326
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Oct 18 00:15:20 2025 +0400
    Add development environment setup notes
    Compatible with Codex
    References #5638
diff --git a/AGENTS.md b/AGENTS.md
new file mode 100644
index 000000000..683dd6a0b
--- /dev/null
+++ b/AGENTS.md
@@ -0,0 +1,245 @@
+# PostGIS development environment
+This document aims to get your development environment up as fast as possible so
+you can jump ahead into improving the PostGIS codebase.
+It assumes Ubuntu 24.04 as it is current on Codex space as the time of writing.
+This repository does not ship ready-to-run binaries. Contributors are expected to
+build PostGIS and its extensions locally and to run the regression suites before
+submitting patches. The notes below summarise what the CI images
+(https://github.com/postgis/postgis-build-env) provide and adapt them to a plain
+Ubuntu host where Docker is unavailable.
+## 1. Base system preparation
+* Work as a user that is allowed to run `sudo`.
+* Keep the system lean: always prefer `apt-get` with `--no-install-recommends`.
+* Make sure the packaged PostgreSQL client binaries precede any other build you
+  may already have in `PATH` (see Section 2).
+```bash
+sudo apt-get update
+sudo apt-get install -y --no-install-recommends \
+  autoconf automake autotools-dev \
+  bison flex \
+  build-essential clang clang-tools clang-format llvm \
+  ca-certificates curl wget gnupg \
+  ccache cmake ninja-build pkg-config \
+  cppcheck \
+  gdb valgrind lcov \
+  git gettext \
+  libcunit1 libcunit1-dev \
+  libexpat1-dev libfreexl-dev \
+  libgdal-dev gdal-bin \
+  libgeos-dev \
+  libgmp-dev libmpfr-dev \
+  libgsl-dev \
+  libjson-c-dev \
+  libopenjp2-7-dev libpng-dev libtiff-dev libwebp-dev \
+  libpcre3-dev \
+  libpq-dev \
+  libproj-dev proj-bin \
+  libprotobuf-c-dev protobuf-c-compiler \
+  libprotobuf-dev protobuf-compiler \
+  libsfcgal-dev \
+  libsqlite3-dev sqlite3 \
+  libspatialite-dev \
+  libxml2-dev libxslt1-dev libxml2-utils \
+  libyaml-dev \
+  postgresql postgresql-client postgresql-server-dev-all \
+  python3 python3-distutils python3-pip python3-venv python3-psycopg2 \
+  xsltproc docbook-xsl docbook-xsl-ns docbook-xml \
+  zlib1g-dev
+This installs software so local workflow can exercise sanitizers, formatters, and coverage reports.
+## 2. Configure PostgreSQL for local testing
+The CI images keep PostgreSQL entirely under `/usr/local/pgsql`. On Ubuntu we
+use the packaged server binaries instead. When running as a privileged user (the
+typical situation in this environment) reuse the default cluster owned by the
+`postgres` system account:
+```bash
+export PG_MAJOR=$(pg_config --version | awk '{print $2}' | cut -d. -f1)
+export PGHOME=/usr/lib/postgresql/${PG_MAJOR}
+export PATH="${PGHOME}/bin:${PATH}"
+# Start the packaged "main" cluster if it is not already online.
+sudo -u postgres pg_ctlcluster "${PG_MAJOR}" main start
+# Allow automated tools to connect without prompting for a password by editing the existing local entries.
+sudo perl -0pi -e 's/^(host\s+all\s+all\s+127\.0\.0\.1\/32\s+)scram-sha-256/\1trust/m; s/^(host\s+all\s+all\s+::1\/128\s+)scram-sha-256/\1trust/m' \
+  /etc/postgresql/${PG_MAJOR}/main/pg_hba.conf
+sudo -u postgres pg_ctlcluster "${PG_MAJOR}" main reload
+# Make the current UNIX account a PostgreSQL superuser.
+sudo -u postgres createuser -s $(whoami)
+# Alternative: keep SCRAM authentication and set a password for automated tooling.
+sudo -u postgres psql -c "ALTER ROLE $(whoami) WITH PASSWORD 'postgres';"
+export PGPASSWORD=postgres
+Revert the authentication edits once you finish testing so other users of the system are not left with trust rules in place.
+If you prefer a completely isolated cluster, create an unprivileged build user
+and run `initdb` as in the upstream documentation. The remainder of this guide
+assumes the packaged cluster is used and listens on the default port 5432.
+## 3. Enable core dumps and logbt (optional but recommended)
+The `ci/github/logbt` helper captures backtraces from crashes. On Ubuntu you
+need elevated privileges once to reconfigure the kernel core pattern.
+```bash
+sudo ./ci/github/logbt --setup
+sudo sysctl kernel.core_pattern
+# Keep the directory writable:
+sudo mkdir -p /tmp/logbt-coredumps
+sudo chmod 1777 /tmp/logbt-coredumps
+ulimit -c unlimited
+When running under constrained CI where you cannot change `kernel.core_pattern`,
+skip the `logbt` steps; the test suite still runs but you will not get automatic
+core backtraces.
+## 4. Build prerequisites
+The following projects are detected automatically via `pkg-config` or helper
+scripts during `./configure`. After installing the Ubuntu packages you should
+have:
+* GEOS (`geos-config`)
+* PROJ (`proj` >= 7)
+* GDAL (`gdal-config`)
+* JSON-C (`json-c` >= 0.13)
+* PROTOBUF-C (for `ST_AsMVT`)
+* SFCGAL (for 3D/advanced geometry tests)
+* Libxml2, libxslt and docbook stylesheets (for documentation targets)
+* Valgrind (for CUnit leak checks)
+Verify their presence if `./configure` fails.
+## 5. Building PostGIS
+```bash
+./autogen.sh
+./configure \
+  --with-jsondir=/usr \
+  --with-projdir=/usr \
+  --with-raster \
+  --with-topology \
+  --with-sfcgal
+make -j"$(nproc)"
+When iterating repeatedly, `make clean` or `make distclean` may be necessary if
+you switch compilers or change major dependencies.
+## 6. Running the regression tests
+Tests expect the PostgreSQL cluster started in section 2 to be running and the
+current user to be able to create databases. Export the connection parameters so
+every helper uses the same cluster:
+```bash
+export PGHOST=127.0.0.1
+export PGPORT=5432        # adjust if your cluster uses another port
+export PGUSER=$(whoami)
+export PGDATABASE=postgres
+Before running the tests, install the freshly built artifacts into PostgreSQL so
+that the regression harness can locate the control files and shared libraries:
+```bash
+sudo make install
+Execute the same test targets used in CI:
+```bash
+# Standard compile + regression suite
+make check RUNTESTFLAGS="--verbose --extension --raster --topology --sfcgal --tiger"
+# Undefined behaviour sanitiser runs
+CC=clang ./configure CFLAGS="-g3 -O0 -fno-omit-frame-pointer -fsanitize=undefined" LDFLAGS="-fsanitize=undefined"
+make -j"$(nproc)"
+make check RUNTESTFLAGS="--verbose --extension --raster --topology --sfcgal"
+# Coverage build (requires lcov and a clean tree)
+make distclean
+CFLAGS="-g -O0 --coverage" LDFLAGS="--coverage" ./configure --enable-debug \
+  --with-jsondir=/usr --with-projdir=/usr --with-raster --with-topology --with-sfcgal
+make -j"$(nproc)"
+Additional targets of interest:
+* `make garden` – runs documentation and extra QA checks.
+* `make check RUNTESTFLAGS="--upgrade --extension --verbose"` – exercises
+  extension upgrade paths; make sure `sudo make install` has been executed into
+  the same PostgreSQL instance before invoking this.
+* `make installcheck` – runs tests against an installed copy (after `make install`).
+## 7. Inspecting coverage results
+Coverage builds rely on the `lcov` utilities. After executing the coverage `make check` run:
+```bash
+# Capture data from the build tree
+lcov --capture --directory . --output-file coverage.info
+# Optionally filter out system libraries and generated files
+lcov --remove coverage.info '/usr/*' '*/tests/*' --output-file coverage.filtered.info
+# Produce an HTML report for browsing
+genhtml coverage.filtered.info --output-directory coverage-html
+# Quickly spot uncovered lines in the terminal
+lcov --list coverage.filtered.info | less
+Open `coverage-html/index.html` in a browser or upload the report to your CI
+artifacts to explore missing lines interactively.
+If you rely on the `ci/github/run_*.sh` wrappers, export `PGHOME` and `PGDATA` as
+shown above and replace `/usr/local/pgsql/bin/pg_ctl` in those scripts with the
+packaged location or create a symlink at `/usr/local/pgsql/bin` pointing to
+`${PGHOME}/bin`.
+## 8. Cleaning up
+To reclaim disk space:
+```bash
+sudo -u postgres pg_ctlcluster "${PG_MAJOR}" main stop
+sudo rm -rf /tmp/logbt-coredumps
+If you created a private cluster instead of using the packaged one, stop it with
+`pg_ctl -D "$PGDATA" stop` and remove the data directory manually.
+## 9. Maintaining formatting
+Before submitting patches that modify C or C++ files, run clang-format only on
+the relevant hunks to avoid unrelated churn:
+```bash
+git clang-format
+The command formats staged changes by default. Use `git clang-format <commit>` to
+reflow a specific range, or pass `--extensions c,cpp,h` when touching files with
+non-standard suffixes. Validate that the resulting diff stays focused on the
+code you touched.
+Review STYLE file in root of the repository for other stylistic preferences.
+The Codecov upload commands in `ci/github/run_coverage.sh` and
+`ci/github/run_garden.sh` require outbound network access; they are harmless to
+ignore locally.
Summary of changes:
 AGENTS.md | 245 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 245 insertions(+)
 create mode 100644 AGENTS.md
hooks/post-receive
