[SCM] PostGIS branch master updated. 3.6.0rc2-148-gb472a69c6
git at osgeo.org
git at osgeo.org
Sat Oct 18 01:31:17 PDT 2025
the project "PostGIS".
via b472a69c6d6b3975aae4fe724f506b54f5bffaa8 (commit)
from 3f2e2d575a6fe34b4cc82a97f316c3ed1b877a12 (commit)
revisions in full, below.
commit b472a69c6d6b3975aae4fe724f506b54f5bffaa8
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Oct 18 12:31:01 2025 +0400
[ci] add lang be to woodpecker config
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 9ec7caa0c..aefe46c4d 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -251,6 +251,17 @@ steps:
include:
- "doc/po/uk/*.po"
+ check-xml-be:
+ image: *test_image
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/be local-check-xml
+ depends_on: prepare
+ when:
+ - path:
+ include:
+ - "doc/po/be/*.po"
### TARGET html
html-it_IT:
image: *test_image
@@ -417,6 +428,17 @@ steps:
include:
- "doc/po/uk/*.po"
+ html-be:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/be local-html
+ depends_on: check-xml-be
+ when:
+ - path:
+ include:
### TARGET cheatsheets
cheatsheets-it_IT:
image: *test_image
@@ -583,6 +605,17 @@ steps:
include:
- "doc/po/uk/*.po"
+ cheatsheets-be:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/be local-cheatsheets
+ when:
+ - path:
+ include:
### TARGET check-cheatsheets
check-cheatsheets-it_IT:
image: *test_image
@@ -749,3 +782,14 @@ steps:
include:
- "doc/po/uk/*.po"
+ check-cheatsheets-be:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/be local-check-cheatsheets
+ depends_on: [ cheatsheets-be, build-cheatsheets ]
+ when:
+ - path:
+ include:
Summary of changes:
.woodpecker/docs.yml | 44 ++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 44 insertions(+)
hooks/post-receive
