[PostGIS] #6007: Diffferrent results with two version of postgis master.
PostGIS trac at osgeo.org
Tue Oct 21 05:49:19 PDT 2025
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.1
 Component:  postgis            |    Version:  master
Resolution:                     |   Keywords:
Description changed by strk:
Old description:
> Postgis below gives one result
> https://gitlab.com/nibioopensource/resolve-overlap-and-
> gap/-/pipelines/2111443784
> POSTGIS="3.7.0dev 3.6.0rc2-55-gfda22140e" [EXTENSION] PGSQL="160"
> GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.8.0 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
> DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ
> 9.8.0) LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
> (Internal)" TOPOLOGY
> while this gives another result
> -num surfaces total|219
> +num surfaces total|217
> gap/-/jobs/11789714169
> POSTGIS="3.7.0dev 3.6.0rc2-133-gd1c28c62c" [EXTENSION] PGSQL="160"
New description:
 DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.8.0)
 while this gives another result:
 The difference:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6007#comment:2>
