[PostGIS] #6009: Error of ST_Polygon(raster) function in PostGIS 3.4.3 and 3.5.4
PostGIS trac at osgeo.org
Tue Oct 21 09:04:58 PDT 2025
 Reporter:  GISuser5432                          |      Owner:  robe
     Type:  defect                               |     Status:  new
 Priority:  high                                 |  Milestone:  PostGIS
                                                 |  3.5.5
Component:  raster                               |    Version:  3.5.x
 Keywords:  PostGIS_Raster; Raster;              |
  ST_Polygon(Raster)                             |
 I tried to run ST_Polygon(Raster) on a raster table and for 3 rows, it
 produced an error.
 This is the simple query:
 {{{#!div style="font-size: 80%"
 Code highlighting:
   {{{#!sql
   SELECT ST_Polygon(raster)
   FROM error_sounding_2m
 This is the error message:
 ERROR:  rt_raster_surface: Could not union the pixel polygons using
 GEOSUnaryUnion()
 SQL state: XX000
 This is the version of the PostGIS:
 POSTGIS="3.4.3 e365945" [EXTENSION] PGSQL="170" GEOS="3.9.0-CAPI-1.16.2"
 PROJ="7.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.2.2, released
 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" RASTER
 I also checked it for 3.5 and I had the same error. Only in 3.6 the error
 was fixed!
 The DB dump is attached for 3 raw of raster in a DB called enav.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6009>
