[PostGIS] #6007: Diffferrent results with two version of postgis master.
trac at osgeo.org
Tue Oct 21 20:17:27 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
I checked code for ordering now.
order by ST_isClosed(geom) desc, ST_NPoints(geom) desc, cover_num desc
So I add the closed lines which have most points and then I sort based on
which order the layer have priority. So if two lines from the same input
layer have the same number of points I have a random issue in ordering.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6007#comment:5>
