[PostGIS] #6007: Different results with two version of postgis master.
trac at osgeo.org
Thu Oct 23 13:23:46 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
The difference between those two revision is the 0-tolerance:
git diff fda22140e..d1c28c62c liblwgeom/topo/
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index c0d6d5356..3e7cfdc1e 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -6764,7 +6764,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point,
double tol, int
LWT_ELEMID id = 0;
/* Get tolerance, if 0 was given */
- if (!tol)
+ if ( tol == -1 )
tol = _LWT_MINTOLERANCE(topo, pt);
LWDEBUGG(1, pt, "Adding point");
@@ -7168,7 +7168,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line,
double tol, int* nedges,
*nedges = -1; /* error condition, by default */
- if ( ! tol ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)line );
+ if ( tol == -1 ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)line );
LWDEBUGF(1, "Working tolerance:%.15g", tol);
LWDEBUGF(1, "Input line has srid=%d", line->srid);
@@ -7605,7 +7605,7 @@ lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly,
double tol, int* nfaces)
- if ( ! tol ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)poly );
+ if ( tol == -1 ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)poly );
lwt_LoadPolygon(topo, poly, tol);
See if you get the expected behaviour by passing -1 instead of 0 to your
TopoGeo_LoadGeometry or TopoGeo_Add* calls.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6007#comment:9>
