[SCM] PostGIS branch master updated. 3.6.0rc2-155-g0c57be8a1
Thu Oct 23 16:48:08 PDT 2025
the project "PostGIS".
       via  0c57be8a1a45f2e23448a2eba0b8dc3530f822aa (commit)
      from  6ca5741c2cc58ee2ad1fdf6232c7179ea6b140db (commit)
revisions in full, below.
commit 0c57be8a1a45f2e23448a2eba0b8dc3530f822aa
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Oct 24 03:47:48 2025 +0400
    Optimize GiST index for repeated edge subdivision in topology
    If the first box is covering all the tuples on the index page picksplit
    was failing to produce two partitions as penalty with first one was 0
    for all elements.
    Closes #5992
diff --git a/NEWS b/NEWS
index 30b34a70b..b1faae2f8 100644
--- a/NEWS
+++ b/NEWS
@@ -13,7 +13,8 @@ xxxx/xx/xx
  - #5993, [topology] Add max_edges parameter to TopoGeo_AddLinestring
           (Sandro Santilli)
  - #6001, support MultiLineString in ST_MakeLine (Paul Ramsey)
- - #2858, ST_MMin and STMMax (Paul Ramsey)
+ - #2858, ST_MMin and ST_MMax (Paul Ramsey)
+ - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
 PostGIS 3.6.0
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 6e2c28e5e..3ac5a3567 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -19,7 +19,7 @@
  * Copyright 2009 Paul Ramsey <pramsey at cleverelephant.ca>
- * Copyright 2017-2022 Darafei Praliaskouski <me at komzpa.net>
+ * Copyright 2017-2025 Darafei Praliaskouski <me at komzpa.net>
@@ -1260,6 +1260,27 @@ box2df_penalty(const BOX2DF *b1, const BOX2DF *b2)
 	return 0;
+static inline float
+box2df_penalty_single(const BOX2DF *box)
+	float boxxmin = box->xmin, boxxmax = box->xmax;
+	float boxymin = box->ymin, boxymax = box->ymax;
+	float dx = boxxmax - boxxmin, dy = boxymax - boxymin;
+	float area = dx * dy;
+	float edge = dx + dy;
+	/* REALM 1: Area is nonzero, return it */
+	if (area > FLT_EPSILON)
+		return pack_float(area, 1);
+	/* REALM 0: Area is zero, return edge  */
+	else if (edge > FLT_EPSILON)
+		return pack_float(edge, 0);
+	return 0;
 ** GiST support function. Calculate the "penalty" cost of adding this entry into an existing entry.
 ** Calculate the change in volume of the old entry once the new entry is added.
@@ -1764,9 +1785,7 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 	OffsetNumber i,
 				maxoff;
 	ConsiderSplitContext context;
-	BOX2DF	   *box,
-			   *leftBox,
-			   *rightBox;
+	BOX2DF *leftBox, *rightBox;
 	int			dim,
 				commonEntriesCount;
 	SplitInterval *intervalsLower,
@@ -1790,7 +1809,7 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 	for (i = FirstOffsetNumber; i <= maxoff; i = OffsetNumberNext(i))
-		box = (BOX2DF *) DatumGetPointer(entryvec->vector[i].key);
+		BOX2DF *box = (BOX2DF *)DatumGetPointer(entryvec->vector[i].key);
 		if (i == FirstOffsetNumber)
 			context.boundingBox = *box;
 		else
@@ -1814,7 +1833,7 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 		/* Project each entry as an interval on the selected axis. */
 			if (dim == 0)
 				intervalsLower[i - FirstOffsetNumber].lower = box->xmin;
@@ -2010,7 +2029,7 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 		 * Get upper and lower bounds along selected axis.
 		if (context.dim == 0)
 			lower = box->xmin;
@@ -2065,42 +2084,43 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 		if (nentries > INDEX_TUPLES_PER_PAGE && nentries <= 2 * INDEX_TUPLES_PER_PAGE)
 			m = Max(m, nentries - INDEX_TUPLES_PER_PAGE);
-		 * Calculate delta between penalties of join "common entries" to
-		 * different groups.
+		Assert(m >= 1);
 		for (i = 0; i < (OffsetNumber)commonEntriesCount; i++)
-												commonEntries[i].index].key);
-			/** PG!6 Abs was removed in favor of standard c lib **/
-			commonEntries[i].delta = fabs(box2df_penalty(leftBox, box) - box2df_penalty(rightBox, box));
+			BOX2DF *box = (BOX2DF *)DatumGetPointer(entryvec->vector[commonEntries[i].index].key);
+			if (v->spl_nright > 0 && v->spl_nleft > 0)
+				/* Calculate delta between penalties of join "common entries" to different groups. */
+				commonEntries[i].delta =
+				    fabsf(box2df_penalty(leftBox, box) - box2df_penalty(rightBox, box));
+			else
+				/* One group became degenerate during split - distribute boxes by their size */
+				commonEntries[i].delta = -box2df_penalty_single(box);
-		 * Sort "common entries" by calculated deltas in order to distribute
-		 * the most ambiguous entries first.
+		/* Sort "common entries" to distribute the most ambiguous entries first. */
 		qsort(commonEntries, commonEntriesCount, sizeof(CommonEntry), common_entry_cmp);
-		 * Distribute "common entries" between groups.
+		/* Distribute "common entries" between groups. */
-			float right_penalty, left_penalty;
 			bool place_right = true;
-			box = (BOX2DF *)DatumGetPointer(entryvec->vector[commonEntries[i].index].key);
 			/* Recheck penalties. After we put undecided tuples to some side they're changed */
-			left_penalty = box2df_penalty(leftBox, box);
-			right_penalty = box2df_penalty(rightBox, box);
+			float left_penalty = box2df_penalty(leftBox, box);
+			float right_penalty = box2df_penalty(rightBox, box);
-			/* Check if penalty is absolutely telling a tuple should go to some side */
-			if (right_penalty > 0 && left_penalty == 0)
-				place_right = false;
-			else if (right_penalty == 0 && left_penalty > 0)
+			/* Guarantee at least one tuple on each side to make Postgres happy */
+			if (v->spl_nright == 0 && v->spl_nleft > 0)
 				place_right = true;
+			else if (v->spl_nleft == 0 && v->spl_nright > 0)
+				place_right = false;
 			/* Check if we have to place this entry in either group to achieve LIMIT_RATIO */
 			else if (v->spl_nleft + (commonEntriesCount - i) <= m)
Summary of changes:
 NEWS                          |  3 +-
 postgis/gserialized_gist_2d.c | 80 +++++++++++++++++++++++++++----------------
 2 files changed, 52 insertions(+), 31 deletions(-)
hooks/post-receive
