[PostGIS] #6011: st_intersects segfault on ubuntu jammy (postgis 3.6.0, postgresql 18.0)
trac at osgeo.org
Wed Oct 29 09:18:08 PDT 2025
Reporter: Christoph Berg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by Christoph Berg):
{{{POSTGIS="3.6.0 4c1967d" [EXTENSION] PGSQL="180"
GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)"}}}
No crash on Debian unstable here either. It's only affecting the
mobilitydb tests on jammy, not on the newer dists.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6011#comment:4>
