[SCM] PostGIS branch master updated. 3.6.0rc2-163-g5faa572a7
Wed Oct 29 16:16:50 PDT 2025
the project "PostGIS".
       via  5faa572a734cce40195709a14db60301c1bf5a0c (commit)
      from  be84ae80b1539e6b05a28911d765d83058ba03fe (commit)
revisions in full, below.
commit 5faa572a734cce40195709a14db60301c1bf5a0c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Oct 30 03:16:32 2025 +0400
    [doc] Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles
    Closes #5950
diff --git a/NEWS b/NEWS
index 29083c77d..5ba9497a8 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ xxxx/xx/xx
  - #5992, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)
  - #5702, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)
  - #4798, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)
+ - #5950, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)
 * Bug Fixes *
diff --git a/doc/developer.md b/doc/developer.md
index 95da8837f..550f90490 100644
--- a/doc/developer.md
+++ b/doc/developer.md
@@ -275,6 +275,27 @@ with lib xxx or higher. Also the function has to be available in the C lib, as s
 on the C lib side and very rarely on the sql files.
+Regression harness privileges
+Continuous integration workers are frequently configured with sandboxed PostgreSQL roles
+that cannot create databases or install extensions. The regression harness accepts two
+environment variables to test the complete installation flow without granting superuser
+rights to the calling account:
+* `POSTGIS_REGRESS_DB_OWNER` – instructs `regress/run_test.pl` to hand ownership of the
+  temporary regression database to a privileged role while the less privileged caller
+  maintains the session. This mirrors production setups where database creation is
+  delegated to controlled roles.
+* `POSTGIS_REGRESS_ROLE_EXT_CREATOR` – optional override when the extension creation role
+  is distinct from the database owner.
+When both roles are configured in PostgreSQL to create the PostGIS extensions, the test
+suite exercises the same upgrade and `CREATE EXTENSION` pathways as a superuser-driven
+run. This avoids the traps described in <https://trac.osgeo.org/postgis/ticket/5212>
+while keeping the CI account unprivileged.
diff --git a/doc/installation.xml b/doc/installation.xml
index e7ff09792..de6ec932c 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -758,23 +758,41 @@ CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;
 		</para>
 	  </note>
-	  <caution>
-		<para>
-		  Currently, the <command>make check</command> relies on the
-		  <code>PATH</code> and <code>PGPORT</code> environment variables when
-		  performing the checks - it does <emphasis>not</emphasis> use the
-		  PostgreSQL version that may have been specified using the
-		  configuration parameter <command>--with-pgconfig</command>. So make
-		  sure to modify your PATH to match the detected PostgreSQL installation
-		  during configuration or be prepared to deal with the impending
-		  headaches.
-		</para>
-	  </caution>
+          <caution>
+                <para>
+                  Currently, the <command>make check</command> relies on the
+                  <code>PATH</code> and <code>PGPORT</code> environment variables when
+                  performing the checks - it does <emphasis>not</emphasis> use the
+                  PostgreSQL version that may have been specified using the
+                  configuration parameter <command>--with-pgconfig</command>. So make
+                  sure to modify your PATH to match the detected PostgreSQL installation
+                  during configuration or be prepared to deal with the impending
+                  headaches.
+                </para>
+          </caution>
-	  <para>
-		If successful, make check will produce the output of almost 500 tests.  The results will look similar to the
-		following (numerous lines omitted below):
-	  </para>
+          <note>
+                <para>
+                  Sandboxed build accounts that are not PostgreSQL superusers can
+                  delegate database ownership during the regression cycle by exporting
+                  <varname>POSTGIS_REGRESS_DB_OWNER</varname>. The harness will create
+                  the temporary regression database owned by the nominated role while
+                  continuing to connect using the less privileged account. Combine this
+                  with <varname>POSTGIS_REGRESS_ROLE_EXT_CREATOR</varname> when the
+                  extension creation role must differ from the database owner.
+                </para>
+                <para>
+                  These variables allow automated environments to exercise the full
+                  upgrade and extension install paths without promoting the calling
+                  account to superuser, provided the target PostgreSQL instance permits
+                  extension installation by those delegate roles.
+                </para>
+          </note>
+          <para>
+                If successful, make check will produce the output of almost 500 tests.  The results will look similar to the
+                following (numerous lines omitted below):
+          </para>
 	  <programlisting>
diff --git a/regress/README b/regress/README
index 7e29fd909..afff17c6d 100644
--- a/regress/README
+++ b/regress/README
@@ -39,5 +39,12 @@ Notes about running individual regression tests
 The script run_test.pl can be called directly to run individual
 regression tests. Run it without parameters for info about its usage.
+When the account invoking the harness lacks database ownership or extension
+creation privileges, export `POSTGIS_REGRESS_DB_OWNER` to nominate a role that
+will own the temporary regression database. If extension installation must be
+delegated further, set `POSTGIS_REGRESS_ROLE_EXT_CREATOR`. These variables allow
+tests to succeed from sandboxed environments without elevating the calling
+account.
 Note that tests run in a staged install which is created by running
 make staged-install. This step is a part of the complete make check.
Summary of changes:
 NEWS                 |  1 +
 doc/developer.md     | 21 +++++++++++++++++++++
 doc/installation.xml | 52 +++++++++++++++++++++++++++++++++++-----------------
 regress/README       |  7 +++++++
 4 files changed, 64 insertions(+), 17 deletions(-)
hooks/post-receive
