[SCM] PostGIS branch master updated. 3.6.0rc2-164-g59d2f3dc7
git at osgeo.org
git at osgeo.org
Wed Oct 29 16:46:43 PDT 2025
the project "PostGIS".
via 59d2f3dc7f7bc15f1bb924c71610fbdee61a6ef3 (commit)
from 5faa572a734cce40195709a14db60301c1bf5a0c (commit)
revisions in full, below.
commit 59d2f3dc7f7bc15f1bb924c71610fbdee61a6ef3
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Oct 30 03:46:26 2025 +0400
Guard against histogram axis dimension underflow
References #5959
References #5984
diff --git a/postgis/cunit/cu_tester.c b/postgis/cunit/cu_tester.c
index b4dd46aa7..eb6ba5b0d 100644
--- a/postgis/cunit/cu_tester.c
+++ b/postgis/cunit/cu_tester.c
@@ -28,6 +28,7 @@
#include <CUnit/Basic.h>
#include <limits.h>
+#include <math.h>
#include <string.h>
#include "../gserialized_estimate_support.h"
@@ -82,6 +83,23 @@ histogram_budget_clamps(void)
CU_ASSERT_EQUAL(histogram_cell_budget((double)INT_MAX, 50000, INT_MAX), INT_MAX);
+static void
+histogram_axis_allocation_guards(void)
+ /* Baseline: evenly split a 10k target over two varying dimensions. */
+ CU_ASSERT_EQUAL(histogram_axis_cells(10000, 2, 0.5), 100);
+ /* Skewed axis ratios that collapse to tiny powers still return one cell. */
+ CU_ASSERT_EQUAL(histogram_axis_cells(10000, 2, 1e-9), 1);
+ /* Denormals, NaNs and negative ratios should not leak to the histogram. */
+ CU_ASSERT_EQUAL(histogram_axis_cells(10000, 2, NAN), 1);
+ CU_ASSERT_EQUAL(histogram_axis_cells(10000, 2, -0.5), 1);
+ /* Extremely aggressive ratios remain bounded by the square root of the budget. */
+ CU_ASSERT_EQUAL(histogram_axis_cells(INT_MAX, 2, 1.0), (int)sqrt((double)INT_MAX * 2.0));
static void
nd_stats_indexing_behaviour(void)
@@ -138,6 +156,7 @@ main(void)
goto cleanup;
if (!CU_add_test(suite, "histogram budget clamps", histogram_budget_clamps) ||
+ !CU_add_test(suite, "histogram axis guards", histogram_axis_allocation_guards) ||
!CU_add_test(suite, "nd_stats value index guards", nd_stats_indexing_behaviour) ||
!CU_add_test(suite, "nd_box ratio edge cases", nd_box_ratio_cases))
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 5c4b4387b..d616cbeba 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -1516,11 +1516,10 @@ compute_gserialized_stats_mode(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfu
* Scale the target cells number by the # of dims and ratio,
* then take the appropriate root to get the estimated number of cells
* on this axis (eg, pow(0.5) for 2d, pow(0.333) for 3d, pow(0.25) for 4d)
- histo_size[d] = (int)pow((double)histo_cells_target * histo_ndims * edge_ratio, 1/(double)histo_ndims);
- /* If something goes awry, just give this dim one slot */
- if ( ! histo_size[d] )
- histo_size[d] = 1;
+ * The dedicated helper clamps pathological floating point inputs so we
+ * do not resurrect the NaN propagation reported in #5959 on amd64.
+ histo_size[d] = histogram_axis_cells(histo_cells_target, histo_ndims, edge_ratio);
histo_cells_new *= histo_size[d];
diff --git a/postgis/gserialized_estimate_support.h b/postgis/gserialized_estimate_support.h
index 0d3a23d75..6b372a43e 100644
--- a/postgis/gserialized_estimate_support.h
+++ b/postgis/gserialized_estimate_support.h
@@ -151,6 +151,46 @@ histogram_cell_budget(double total_rows, int ndims, int attstattarget)
return (int)budget;
+ * Allocate histogram buckets along a single axis in proportion to the observed
+ * density variation. The caller passes in the global histogram target along
+ * with the number of axes that exhibited variation in the sampled data and the
+ * relative contribution of the current axis (edge_ratio). Earlier versions
+ * evaluated the pow() call directly in the caller, which exposed the planner to
+ * NaN propagation on some amd64 builds when the ratio was denormal or negative
+ * (see #5959). Keeping the calculation in one place allows us to clamp the
+ * inputs and provide a predictable fallback for problematic floating point
+ * combinations.
+static inline int
+histogram_axis_cells(int histo_cells_target, int histo_ndims, double edge_ratio)
+ double scaled;
+ double axis_cells;
+ if (histo_cells_target <= 0 || histo_ndims <= 0)
+ return 1;
+ if (!(edge_ratio > 0.0) || !isfinite(edge_ratio))
+ return 1;
+ scaled = (double)histo_cells_target * (double)histo_ndims * edge_ratio;
+ if (!(scaled > 0.0) || !isfinite(scaled))
+ return 1;
+ axis_cells = pow(scaled, 1.0 / (double)histo_ndims);
+ if (!(axis_cells > 0.0) || !isfinite(axis_cells))
+ return 1;
+ if (axis_cells >= (double)INT_MAX)
+ return INT_MAX;
+ if (axis_cells <= 1.0)
+ return 1;
+ return (int)axis_cells;
* Compute the portion of 'target' covered by 'cover'. The caller supplies the
* dimensionality because ND_BOX always carries four slots. Degenerate volumes
Summary of changes:
postgis/cunit/cu_tester.c | 19 ++++++++++++++++
postgis/gserialized_estimate.c | 9 ++++----
postgis/gserialized_estimate_support.h | 40 ++++++++++++++++++++++++++++++++++
3 files changed, 63 insertions(+), 5 deletions(-)
hooks/post-receive
