[PostGIS] #5983: Data corruption in topology.topoelement and topology.topogeometry after upgrade to 3.6.0
PostGIS trac at osgeo.org
Thu Oct 30 07:09:24 PDT 2025
upgrade to 3.6.0
  Reporter:  packi     |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.6.1
 Component:  topology  |    Version:  3.6.x
Resolution:            |   Keywords:
Comment (by robe):
 Ah strk - sorry didn't read this before posting my pull request
 https://gitea.osgeo.org/postgis/postgis/pulls/274
 I tried to make the function name match the structure of other function
 names.
 So I called it: topology.FixCorruptTopoGeometryColumn
 We could add a version number to it, but I had planned it work for both
 upgrade and downgrade.  e.g. should we offer the option of
 topogeometry_small we might need to use it to fix the bigint
 topogeometries that's what the second casing is for.
 Regarding the above you have.  I realize now that even though you can't
 cast xmin to int or bigint you could do so by going first thru ::text
 cast.
 select xmin::text::integer from pg_proc where oid =
 'topology.st_createtopogeo'::regproc;
 So I guess it can be done.  Though are we absolutely sure that xmin will
 always be increasing?  I'm guessing so except for exceedingly large
 databases where there is wrap around.  I'm assuming that is why they never
 provided > < operators for tid types and you only have equality.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5983#comment:26>
