[SCM] PostGIS branch master updated. 3.6.0rc2-166-gd0cfdb0e9
git at osgeo.org
git at osgeo.org
Thu Oct 30 09:21:41 PDT 2025
the project "PostGIS".
via d0cfdb0e97f065e1ecbdb70b0de908760b5858ab (commit)
from 520c80895c27a4720e9bf58d044f3c3de8db7d94 (commit)
revisions in full, below.
commit d0cfdb0e97f065e1ecbdb70b0de908760b5858ab
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Oct 30 20:21:29 2025 +0400
geometry_columns handles NOT VALID SRID checks without errors
Closes #4828
diff --git a/NEWS b/NEWS
index 5ba9497a8..d4e6baf0c 100644
--- a/NEWS
+++ b/NEWS
@@ -22,6 +22,7 @@ xxxx/xx/xx
* Bug Fixes *
- #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
+ - #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
PostGIS 3.6.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c1a57bc0d..dee9101c4 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6398,6 +6398,14 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
-- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
CREATE OR REPLACE VIEW geometry_columns AS
+WITH constraint_defs AS (
+ -- Trim trailing NOT VALID so metadata inference works before constraint validation (#4828).
+ SELECT connamespace,
+ conrelid,
+ conkey,
+ regexp_replace(pg_get_constraintdef(oid), $$\s+NOT\s+VALID$$, '', 'i') AS consrc
+ FROM pg_constraint
SELECT current_database()::character varying(256) AS f_table_catalog,
n.nspname AS f_table_schema,
c.relname AS f_table_name,
@@ -6409,32 +6417,30 @@ SELECT current_database()::character varying(256) AS f_table_catalog,
JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
JOIN pg_namespace n ON c.relnamespace = n.oid
JOIN pg_type t ON a.atttypid = t.oid
- LEFT JOIN ( SELECT s.connamespace,
- s.conrelid,
- s.conkey,
- (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
- FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
- FROM pg_constraint) AS s
- WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
-) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
- s.conrelid,
- s.conkey,
- (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
- WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
-) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
- s.conrelid,
- s.conkey,
- (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
- WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
-) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
+ LEFT JOIN (
+ SELECT s.connamespace,
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
+ FROM constraint_defs AS s
+ WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
+ ) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
+ LEFT JOIN (
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
+ WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
+ ) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
+ LEFT JOIN (
+ s.conrelid,
+ s.conkey,
+ (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
+ WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
+ ) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 6fd77a19d..e24bcef05 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1619,6 +1619,19 @@ SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, t
ORDER BY f_table_name, f_geometry_column;
DROP TABLE IF EXISTS test5829, test5978;
+-- #4828, geometry_columns should ignore pending NOT VALID SRID checks
+CREATE TABLE test4828 (
+ geom geometry
+ALTER TABLE test4828
+ ADD CONSTRAINT test4828_srid CHECK (ST_SRID(geom) = 4326) NOT VALID;
+SELECT '#4828', srid
+ FROM geometry_columns
+ WHERE f_table_name = 'test4828'
+ AND f_geometry_column = 'geom';
+DROP TABLE IF EXISTS test4828;
-- #5987, ST_GeometryN broken on unitary geoms
CREATE TABLE test5987 (geom geometry(Geometry,4326));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index c39981696..6637f2d89 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -492,6 +492,7 @@ public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
public|test5829|geom|2|4326|GEOMETRY
public|test5978|geometry|2|4326|POINT
public|test5978|shape|2|4326|POINT
+#4828|4326
#5987|LINESTRING(20 20,20.1 20,20.2 19.9)|LINESTRING(20 20,20.1 20,20.2 19.9)
#5962|MULTIPOINT((1 1),(3 4))|POINT(1 1)
#5754|LINESTRING(0 0,1 1,2 0,3 1,4 0)|LINESTRING(0 0,1 1,2 0,3 1,4 0)|POLYGON((0 0,1 0,1 1,0 1,0 0))|POLYGON((0 0,10 0,10 10,0 10,0 0),(1 1,1 2,2 2,2 1,1 1))
Summary of changes:
NEWS | 1 +
postgis/postgis.sql.in | 58 ++++++++++++++++++++++++-------------------
regress/core/tickets.sql | 13 ++++++++++
regress/core/tickets_expected | 1 +
4 files changed, 47 insertions(+), 26 deletions(-)
hooks/post-receive
